Question about Apex Digital GB5108 51" Rear Projection EDTV-Ready Television
Convergence toshiba 50a62
The convergence appears to be off on my big screen, there appears to be a blue halo around white lights or letters, and the red and green look like they are in 3-d. I tried to manually adjust the convergence in the menu, but nothing happens. What else can I do to fix this problem?Most places want 400-600 dollars to fix this, and I don't have that kind of money.
  • livier12 Apr 03, 2009
    When I try to manually adjust the convergence, the red won't move at all for some of the positions, therefore I see red parts on the picture.
  • Apex Digital Master
  • 3,459 Answers
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Mar 25, 2010
Toshiba big screen Model TZ50V60 Convergence Issue-Chips Replaced
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Red/Orange looking picture
You can see some more examples and find a fix here
Mar 29, 2010 | Toshiba TZ50V61 50" Rear Projection...
Sony KP-65WS500 Rear Projection TV About a week ago the left side of the screen started to a slight blue halo over faces, hands, and some of the white letters were light yellow. I adjusted the convergence...
Thats a convergence failure issue. The Sony Type 1 convergence repair kit available from www.tvrepairworld.com is the kit your model uses. The kit contains the parts and the CD with instructions.
Dec 20, 2009 | Sony KP-65WS500 65" Rear Projection...
50inch toshiba color problem
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 03, 2009 | Toshiba 50A62 50" Rear Projection...
White halo around lettering
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 24, 2009 | Philips 55PW9363 55" Rear Projection...
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
heres a simmilar repair on a pioneer. I can help with specifics if you attempt
Jan 09, 2009 | Televison & Video
Blue halo on bottom 1/3 - Convergence issue with my 43HX70
HELLO SOUND LIKE YOU NEED TO CHANGE YOU IC CHIP'S ON THE CONVERGENCE BOARD.1!1 THERE WILL BE THREE OF THEM .!!! CHANGE ALL OF THEM AND THIS SHOULD FIX YOUR SET. "GOOD LUCK"
Aug 13, 2008 | Toshiba 43HX70 43" Rear Projection...
Blue Halo - convergence issue with 43Hx70
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Blue Halo, Tried to adjust on Projection TV
The convergence issue you have will not adjust out....repair
of the convergence circuit will be necessary....then adjust...T.
Dec 01, 2006 | GE 46GW947 46" Rear Projection Television
Apex Digital GB5108 51" Rear Projection EDTV-Ready Television Logo
327 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
