Question about HP OfficeJet 6110 All-In-One InkJet Printer
Paper comes out blank
Machine looks and sounds as if it is copying but paper comes out blank
Chances are the ink cartridges are stopped up with dried ink. These printers have this problem if you don't use them often and just let them set up. Try folding a couple of paper towels so they will be several thicknesses, then wet the paper towels with water and place in microwave and heat them up really hot. Take you ink cartridge and place the ink exit area on the paper towel and rub it back and forth. This will wick the dried ink out of the cartridge exit. Put back in printer and try it. You may have to do this several times to get it back to good condition. Hope this helps.
Posted on Nov 22, 2008
Blank page when I copy or print reports
Re check all the connections. When taking off the paper feed assay, other parts and plug and jack connections were needed to be taken off first.
Make sure the drum seats in its correct position, silver grounds are not bent.
The copy cartridge and Dev housing are not connecting very good somewhere.
Make sure the machine is unplugged.
Try running copies.
Apr 21, 2010 | Xerox WorkCentre Pro 580 Plain Paper Laser...
How do u load paper? front or back side up?
Hi, It dosen`t matter how you load paper, Copy paper are blank on both side, now if you are reusing paper with prints on one side then you do it by trial and error.
Now if you meant how to load document on top, then that`s a different story, most fax machines require that you put the document face down. I would suggest that you make a copy from a document face down and if it comes out ok, fine, if the copy comes out blank then you need to put the document face up instead.
Hope this helps.
Mar 13, 2010 | HP 1040 Plain Paper Inkjet Fax
Second blank page comes out after copies
check paper size setting and paper pickup
Jun 27, 2009 | Canon PC1061 Copier
Xerox Copycentre C20 Prints nothing but blank pages
Is the paper (copy) truly blank? Please look very close at the page. It sounds like the coratron (charge) wire (s) are broken. These are thin wires this use electrical charges to transfer the image onto the paper. You can go online and order a small spool of the wire and restring the wire. You do not have to be a doctor to do this repair but a steady pair of hands is very good. NOTE:::::: pay attention, most of the coratron units use tiny springs... so look and listen in case it falls out. You can restring with out the spring but it is better with the spring. Remember when stringing the wire, not loose but do not over tighten.
Dec 26, 2008 | Sharp AR-M455N Copier
All copies are blank
What happens when you print a report? Do you get print then? If you can print reports and then you get blank copies the problem is your scanner. If you can't print or copy, then the problem is in either the drum, I would say 30 percent, or laser probably 70 percent.
But we have to find out if it will print a report. Do you use the machine as a fax ? Do they print ok?
Sep 29, 2008 | Xerox WorkCentre M15i Laser Printer
We have a Minolta DI250 and when we copy a document comes ot blank in the middle of the paper. Does anybody knows what could be the problem?
Blank in middle could be lack of toner or developer in the developer unit. Also bad charge or transfer coronas. Is paper
wrinkled? You might make a copy and stop the copier before thapaer goes into the fuser, and see what kind of copy on the paper. If complete problem is in the fuser such as warped rollers, etc.....
Aug 28, 2008 | Minolta Office Equipment & Supplies
Sharp Al-800 Skewed Copies
one problem with this machine, a small pin comes out on the paper release handle in the back, which lets on side of the paper lift tray to come up higher than the other. might look in that area. good luck
May 15, 2008 | Sharp AL 800 Copier
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
HP OfficeJet 6110 All-In-One InkJet Printer Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
