Question about Fujitsu AMILO PC Laptops
MY SCREEN HAS BROKEN DOWN
I was sitting in my room and my 12 month old brother had pushed a laptop of my little table and my screen has broken down it went all black and would not work !
can you please help me and tell where can i fix it and how much it would cost .
PC Laptops
407127 FUSI AMILO LI181
  • Anonymous Mar 29, 2009
    I slammed my laptop fugitsu closed a little too hard, now the screen doesn't work. how much does it cost to repair a screen?
  • 395 Answers
Where are you located in the world so i can get you to the closest repair center.
Regards
Posted on Aug 21, 2009
  • 134 Answers
Well the cost of the screen is about $20 so you can reach at your local pc vendor for help.
Am so sorry for the accident pls dont be to angry.
Posted on Jul 08, 2009
  • 31 Answers
I have an hp so idk if this will work . . . take the battery out of ur laptop and let it sit for at least 5 hours ............ and then put it bak in . . . if it still dont work . . . . check the side of ur screen . . . if u see a little hole in it and beside it is a picture of a lock . . . get the smallest flat head u can find or a strong needle and switch it up . . . wait an hour and switch it back . . . one of those two solutions should work if not write me bak and i have a few more things for u to do and it will work urs hopefully - eli (write me bak )
Posted on Jun 16, 2009
2 Suggested Answers
  • 357 Answers
SOURCE: MY SCREEN HAS BROKEN DOWN !!!! Help ...
If you have access to a monitor, connect it to your laptop, you may need to hold down the function key and press the "CRT/LCD" key which may be F8 or F7 key, and see if you are able to see anything.
If trhis works, you need a new display, take it to your local computer repair shop.
I hope this helps.
Good Luck.
Posted on Mar 15, 2009
I have an Acer laptop, that has suddenly got a black screen, and I can't turn it off.
It should have a 12 month warranty, if it does contact Acer for a warranty return label..
Feb 10, 2017 | Acer Computers & Internet
Toyota yaris problem
Do Not do that!! Anything foreign in the sump is a really bad idea.It way make its way to the oil pickup screen and partially block the flow of oil.This has the potential to damage your engine. At the bottom of the dipstick tube is usually a small bolt that attaches the tube to the side of the engine.I would remove this and see if I can fish it out then.Failing this you will have to drop the oil pan and get it that way.I know this may seem like a trivial thing but the potential is there to do a lot of damage.
If bits of plastic get past the screen and get into your engine any cost to get the stick out will seem very minor. good luck
May 07, 2014 | 2001 Toyota Yaris
Laptop white screen, please help
Yes! the video graphics card is usually built into the motherboard, from the description it took a high static charge in the main board and is causing cascade failures, I would consider a new computer.
Mar 04, 2012 | Dell Latitude D830 Notebook
I have a dv2000 hp laptop & the screen doesnt work properly when i open the computer. it acts up when the the screen is moved back & forth
Your computer your laptop will just shut itself down and get a black screen unexpectedly, which is due to: power overload in the AC adapter, overheated processor / clogged fan, overheated battery, pushing the power button, Windows telling it to, the BIOS telling it to, loose wires (especially the power cord), or intermittent short circuits. The most common problem is cooling. the battery should be removed from the laptop and allowed to cool to room temperature before attempting to use again. Notice if the fan is broken or clogged with dust.
From: http://www.papatek.com/Knowledge/Battery-knowledge/Knowledge_194.html
Nov 15, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Oscillating table fan makes banging noise when rotating
mcdevito75 here, Sounds like that oscillating swtich is either a little loose or could use a drop or 2 of 3 in 1 oil. Try to twist offf the oscillating swatch button and see if you can tighten it or put a drop of oil on it.
Jul 24, 2010 | Holmes Products Holmes HASF1304S-UC 12",...
I hope this helps.
Good Luck.
Nov 20, 2008 | Fujitsu AMILO PC Laptops
IBM T-40 Thinkpad Stopped Working
IBM's are famous for this ...that's why they've changed their keyboard configurations so frequently, because palm pressure would either a) prematurely damage the hard drive or b) cause problems with the AC/DC card (IBM's term, not mine).
My guess, since I used to repair IBM laptops for a living, is the AC/DC card. It directly controls video output to the LCD. You can probably find one "pulled" on eBay for around $50, and probably $50-100 for someone to install it for you.
Hope this helps - remember to rate! :)
Scott
Oct 01, 2008 | IBM ThinkPad T40 2373 Notebook
Advent laptop overheating
Check the jack on the machine to see if it's loose or broken. Use a small screwdriver, and see if you can move it in any direction. If it is loose or broken, get it fixed imediately. A loose or broken jack can create an electrical arch which can do severe damage to the machine.
Jul 22, 2008 | Computers & Internet
Acer 5650 Nvidia 7600 grapgics card. On DOS screens some characters are changed eg format becomes dormat. Initial splash screen has broken red lines down it. Restored from dvd but will not pick up...
Unfortunately you have to change the mainbord cause your nvidia crad has broken down and its sticked with the mainbord
Had the same problem and waitde for 1 1/2 month in order to take it back fixed....Good luck and be patient...
Apr 25, 2008 | Acer Computers & Internet
Touch screen broken
i would say that the screen got cracked
Feb 16, 2008 | Nintendo DS Lite Console
Fujitsu AMILO PC Laptops Logo
89 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
