Question about Toshiba 13A26 13" TV
Green screen Had tv less than 5 months. Green screen started. Tried to adjust color nothing happened. Took it back to Best Buy. They tried to degauss it. Did not work.
  • kohawkmike Jul 12, 2008
    TV turned on and was running fine for about 15 minutes when it suddenly turned to a green screen. Picture is still slightly visable through the green. Have tried adjusting the color, brightness, etc with no results. Is there anything I can do short of taking it to a technician to fix it?
CHANGE 18K RESISTOR 1 WATT, LOCATED KINESCOPE MODULE.IT IS LIKELY OPEN. IT IS A B+ RESISTOR THAT SUPPLIES VOLTAGE TO GREEN VIDEO OUTPUT TRANSISTOR COLLECTOR.
Posted on Apr 03, 2008
To clarify the repair the video board sets upright verticile that plugs onto the (main board) horizontal with locking tabs just lift up off clean pins with emery board spray socket with abrasive cleaner called (blue stuff )
I also checked for bad solder connections on the crt board and resoldered some connections on main board where the pins go in to the upright video board I hope this clarification is more complete
I am an engineer electronics tech for 27 years servicing
good luck people
Posted on Dec 11, 2007
    Sergeant:
  • 308 Answers
If you can still see the video and some fine white lines running diagnally across the screen, it is very likely the picture tube itself which would likely be covered under warranty. If it is a solid green screen with no video, it could be a defective driver transistor or IC going to the picture tube.
Posted on Dec 18, 2006
We have a panasonic ct-36d31e that has developed a degaussing problem now. Rainbow colors - magnets haven't helped neither has power drill placed near the screen. Is there a degauss button on this model...
Hi Tracy,
Unfortunately magnets etc will most likely do all but improve the problem. When a T.V set is turned on it automatically degausses (demagnetises) the tube. However, if the screen does not degauss, its most likely a small electronic component in the degaussing circuit which has burnt out. This component is usually black in color, is rectangular and about the size of of the T.V. screen displayed alongside your question. Its inexpensive to replace(less than $5) and can be found at most electronic component stores.
Please let me know if I can be of any further assistance.
Best wishes,
Graemevm
Dec 23, 2009 | Panasonic CT-36D31 36" TV
Lightning changed colors on my TV
You need to degauss the CRT, there is a built in degaussing coil but its needs more power . this is simply magnetizm that needs to be removed . see if you can before a coil somewhere.gd lk
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 21, 2009 | Toshiba 32A33 32" TV
Color problems??
There doesn't happen to be a speaker nearby does there? I've seen this a lot with center channel surround sound speakers. It goes like this because of the magnet in the speaker. Try moving the speaker if there was one (or anything else near the TV that may have a magnetic field). Then, every time after you turn your tv on it should get slightly better thanks to the built-in degaussing coil in your tv. If not, find a TV/Appliance repair man near you, and he will have what's called a De-gausser and will probably charge around $30 to use it on your tv. You'll be watching 2D TV again in no-time!! ;-)
Jun 05, 2009 | Hitachi 43FDX01B TV
Color problem with the samsung 46" PCK520R TV
There are a few possible causes for this
-Picture tube has become weak after long useage
-A fault with the automatic degauss circuit could be causing the color problems.
-The color drive circuits may be out of adjustment.
I don't have instructions for you on how to fix this, I would recommend you either buy premium assistance or contact
another expert with long tv experience to possibly get details
on how to correct this problem.
I would recommend you contact your dealer for repairs if you have warranty. If you don't have warranty it may be cheaper to ask around.
Jun 09, 2008 | Samsung PCK5315RX TV
Tv color messed up
There is the chance that the yoke has sliped and a purity adjustment is in order, since you would be dealing with voltages that could kill you if you don't know haw to do this the safest bet would be to take it to the shop
Jun 03, 2008 | Symphonic ST420FF 20" TV
Color problem with TV
Are you getting Green or purple or pink patches all over the screen?
This could be a problem of Degaussing. Have you placed any Magnetic source near the TV recently? Some Tape recorder or walkie talkie or a Speaker, etc? The Magnetic field created by any of the above sources can cause coloured patches over a colour TV screen.
It also happens if you shift the TV from one location to another.
The third possibility is that the Picture Tube's Red Output stage gone faulty. Unless you are a trained Solid state Electronics Technician, there is nothing you can do. Better go for a trade in.
Feb 22, 2008 | Panasonic CT-27G21 27" TV
Red,blue,and green separating
I think it is a degaussing problem which is due to magneic effect. if you can 1 check any magnetic thing is mot close to tv. 2do not change the direction of tv while watching. 3call tech to degauss it by a coil called degaussing coil. good luck.
Sep 27, 2007 | Samsung PCK5315RX TV
Re Degaussing
Now Degaussing and convergence are two different things, if you say its degaussing then you should have just a color differential in a certain area, meaning the color should not be arched, everything that passes through should pass throu only with the changing of color. Now if its a convergence the the color may lift upward in an arch, likely separated from the other colors, Red, Blue,or Green. So now which do you think you have? Deguassing usually give you a highish green color or yellow
Sep 11, 2007 | Panasonic PT-47WX52 47" Rear Projection...
Toshiba 13A26 13" TV Logo
286 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
