Question about Sigma EF-500 DG ST for Nikon Flash
Parts where i can get a strobe bulb for sigma EF-500 DG flash JT
Но у меня есть опыт по ремонту нужна маркировка лампы могуя поставить на замену MF32/45 FT-3648 ST
Posted on Dec 07, 2009
  • 22 Answers
Unless the flash tube is cracked or broken there may be other reasons why the unit is not working. Try this- power up the unit and hold the back of it near you tear, If the ready light goes on, fire it- if you hear a slight clicking sound- the unit is working but the flash tube is either dead, broken or out of the circuit.
Unless you are experienced in electronics, the flash tube in you unit is NOT user changeable, soldering equipment skilsl are required to replace parts and even small units can harbor lethal voltages that can cause serious injury or even death- even after the unit is switched off.
Consult you local dealer or the distributor for repair services. Ed
Posted on Nov 20, 2008
Need manual for sigma ef-500 dg super minolta version
You may download a copy of the manual from here. It's for the Pentax version of the flash, but I don't see anything in it that's Pentax-specific except for the mention that's it's Pentax-specific.
Apr 02, 2013 | Sigma EF 500 DG ST for Minolta TTL Flash
Working instructions for Sigma EF-500 flash gun
Unfortunately, the manual for this model is no longer available online (even on the Sigma website). Try searching torrent sites and ebay as a last resort.
Jan 11, 2011 | Sigma EF-500 DG ST for Nikon Flash
Sigma ef-500 dg st won't work with my d300 or 200 in ttl mode
This Sigma flash is not Ittl compatible. The D300 and D200 Nikon must have Ittl compatible flash to operate in any of the Automatic modes. It is a great flash but will not work on those two cameras.
Dec 14, 2010 | Sigma EF-500 DG ST for Nikon Flash
Can I use a sigma flash EF 500 with Sony Alpha 350
Yes, if it has a Minolta/Sony mount. The Sigma EF 500 has been producedin different mount, so that the model can fit different cameras from different producers. A Sigma flash for Sony should have SO-ADI written on it.
Apr 25, 2010 | Sigma EF-500 DG for TTL Flash
Sigma EF-500-DG, does not charge and does not become ready
Hello
Thank you for using FixYa for your problem
Always check the batteries first - make sure they have full charge (in the wrong way can discharge them) but if is it still giving the same fault, your flash is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Sigma EF-500 DG Super for Canon EOS TTL...
1. Sigma EF-500 DG ST 2. Quantaray 7500A
A: For Sigma issue:
The Sigma EF-500 flashes have very small chromed contacts for the batteries. Even though they may not look corroded, they may not power up or conduct enough power to fully cycle up. Use a polishing tip in a dremel or an ink eraser tip to clean the internal wire contacts and the flat contacts on the door. I use dielectric grease on a q-tip to apply a coat to all contacts and cleaned battery terminals to minimise future issues.
Nov 20, 2008 | Sigma EF-500 DG for TTL Flash
Broken shoe mount on Sigma ef-400 dg super Flash
Contact Holly Enterprises- The manufacture a metal foot to replace broken plastic ones on flash units. The made one specifically for some of the popular Vivatar flash units and I am not sure if theses can be used with your flash unit ro if the have others that are made especially for you strobe. I also don't know if the are user installable.
If you have to take the unit apart to do this procedure, you have to consider the high voltages that can remain in the unit even after is it turned off, If Holly can not assist you, check with the distributor of the flash- It may be better to have it professionally repaired in case there are other issues such as disconnected or broken wires that may have been damaged when the base was torn off.
Please let me know if you have any lick with this. Ed
Nov 15, 2008 | Sigma EF-500 DG Super for Canon EOS TTL...
Bulb replacement for Sigma EF-500 DG Super
So I had fixed the problem this morning, since the warranty has expired, I opened up the flash to take a peak on the inner workings, and found that a wire had come loose, got out the soldering gun and repaired the connection and all is good.
Sep 28, 2008 | Sigma EF-500 DG Super for Canon EOS TTL...
Replacement shoe for Sigma EF-500
send it to a sigma agent thay can replace the broken part
Nov 02, 2007 | Sigma EF-500 DG for TTL Flash
Problem with underexposed pictures
I've got the same problem with my new ef 500 dg super and my ef 530 dg super. It occurs on all nikon camera's I could get.
D70, D80 and Fuji S5 Pro. I don't have this problem with an old (4 years) sigma ef 500 dg super.
I will try to contact Sigma for this problem.
Nov 01, 2007 | Sigma EF-500 DG for TTL Flash
Sigma EF-500 DG ST for Nikon Flash Logo
278 people viewed this question
Top Sigma Cameras Experts
Steve
Doberman
Are you a Sigma Camera Expert? Answer questions, earn points and help others
