Question about HP Pavilion dv6000z Notebook
My hp dv6000 monitor wont turn on.
The computer is on but the minitor is off.
i've tried replace the batterry, tried a diferrent charger and i even pluged it to a PC destop's monitor, the screen stays black.
please help
  • amb706 Feb 26, 2009
    my dv6000 laptop does the same thing.. i try to turn it on and nothing comes on the screen and it keeps cycling on and off. :-(
There is a recall on hp dv6000 mother boards for this problem. and its free!!!!!!! call 18004746836 go through the steps and they will send out a return box for you, absolutely free!!!
Posted on Nov 21, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
It sounds like a fault in your screen displays, or worse your motherboard. Take it in for a look because the problem is hardware and it needs to be checked and replaced.
Hope This Helps
HP pavilion dv6000 speakers wont work
If you've check the Audio and Sound properties in the Device Manager then maybe the speakers are shot. Click Start/Control Panel and look for Sound or Audio and check the properties and settings. You can also click the Megaphone at the bottom right near the time. Make sure the Volume is turned up and not on Mute.
You can look on ebay and purchase replacement speakers based on a HP DV6000 Speakers search. You'll have to take the laptop apart to install them.
You could try downloading and reinstalling the Audio Drivers.
Get online and got to www.google.com In the google search box type: "HP Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Audio drivers.
Try using the VLC Player. It comes with drivers and codec. I've seen it solve many sound issues.
Try using VLC as your player. Go to www.google.com and in the search box type "download vlc" (without the quotes). Look for the Video Lan download from site www.videolan.org/vlc Download and install it. It downloads and installs in 3 minutes or so. It's a very fast player, smooth and it can play just about any type of dvd formats and media. It's totally FREE.
May 13, 2012 | Computers & Internet
I have a crack screen on my hp w2558hc minitor and need tor replace it. Where can I get the parts?
There aren't any - when the LCD screen is defective it's cheaper to replace the entire monitor.
Sep 02, 2010 | HP w2558hc 25.5" Widescreen LCD Monitor
Hp pavilion dv6000 battery not chargering
First try to reset the battery to see if it helps any by doing the following: Turn off all power saver settings on your laptop, disconnect the laptop for the ac adapter. Then use your laptop and run the battery down ignoring any low battery messages until it dies. Then let it fully charge for a night without turning it on, and see if it has saved any charge. If it still hasn't saved any charge, it seems like the only option is that its a dead battery and needs to be replaced. Best of luck!
Jul 14, 2010 | HP Pavilion dv6000z Notebook
My camera battery ran out and when i plug it in to charge it with the original charger nothing happens at all, cant switch it on and it doesnt charge, it wont do off the computer either, i tried it with a...
yes replace both ,batterry and the charger,thath way youl be shure and the new battery must be charge for 12 hrs ...
and should works fine after ..
hope that will help you
regards Alan..
May 27, 2010 | Kodak EasyShare M863 Digital Camera
My hp dv9000 wont start,even with the battery or with the charger IS PLUG it doesnt still start up.THE LIGHTS WILL JUST BLINK FOR JUST 2 SE4CONDS AND IT TURNS OFF AGAIN.
Unfortunately it sounds like your motherboard is toast. The DV9000 and the DV6000 use prmarilly the same motherboard and these have been fraught with problems that HP has been unwilling to fix. The good news is these are relatively easy to replace with a good guide, basic tools and patience. Below is a link to the service guide that will help with the disassembly....
http://h10032.www1.hp.com/ctg/Manual/c01311536.pdf
Jan 11, 2010 | HP Pavilion dv9000z Notebook
Disable sleep mode for HP w1707 LCD minitor
Read -> this <-guide on how to disable sleep mode/hibernation
Aug 14, 2009 | HP W1707 LCD Monitor
Wont charge
check voltage with volt ohm meter , you probably need a new charger, ebay less than 30 bucks
Don
Apr 02, 2009 | HP Pavilion dv4000 Notebook
Pavilion dv6000t screen won't come on.
I had this exact problem with a customers computer andi found out that HP put faulty motherboards in the DV6000, DV9000, Compaq V6000 Series Computers. Thankfully HP fixing all computers for free and extending the warranty even if the warranty has expired they will ship you a box and you ship it off and they fix it at no cost. the turn around period is about 7 days.
Here is a link to an article that talks about it
http://mattsblog.ca/2007/12/14/having-problems-with-your-hp-pavilion-dv6000-dv9000-or-presario-v6000-series-notebook/
Hope this helps!
NosirromNet
Dec 14, 2008 | HP Pavilion dv6000t 15.4" Notebook Laptop...
Hp screen problems
Pls check if the connections are proper and if the monitor is turned on.
Once you have checked the above thing, if the screen still doesnt come on, then the monitor has to be serviced or you may try connecting another cable from the monitor to the computer.
Jan 08, 2008 | Gateway FPD2275W LCD Monitor
HP Pavilion dv6000z Notebook Logo
446 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
