Question about Hotpoint WMA64 Front Load Washer
Drum on my wma62 won't turn
I have a hotpoint ultima extra wma62. The drum doesn't turn anymore - even manually.
I have tried taking it apart but cannot get access to the back to the drum - to check the spider and brushes. I have removed the belt and the motor turns very easily, so I can only assume its the drum/its axis.
I have removed the top panel, the front, the door - but cannot get the back off so that I can undo the nut that seems to be holding the drum together. It looks like its one wrap around panel-back and sides, and is welded to the actual frame.
can anyone offer any advice a to what the problem might be and how to get to the drum?
All other parts work fine (although it is very very noisy when it spins fast.)
  • Hotpoint Master
  • 3,463 Answers
Hi.
The main drum bearigs have failed, you have to disconnect everything you can to enable you have to
remove the whole drum and container through the top of the m/c.
It is quite an involved repair, and could prove to be expensive. more so if the drum shaft is worn.
Good luck.
if you need any further info, let me know
Posted on Nov 20, 2008
My hotpoint washing machine wma64 will not spin
Dear Blaze,
Here is a link for a service manual Hotpoint WMA64 Installation And User Instructions Manual
The drum motor, its brushes, the belt, or idler arm roller, and the drum roller bearings can all be suspect. Here is a link that supports the statement Hotpoint Ultima Extra Wma64 Drum Not Turning E32 Fault Code Hotpoint...
Here is some conversation not relevant to your statement but maybe associated later on Faulty Hotpoint WMA64 DIYnot com DIY and Home Improvement .
I suggest when it is repaired to do a service wash to clear the drum of buildup.
Fare. Well.
Dec 28, 2014 | Hotpoint Washing Machines
Wf865 drum won't turn in programme
have you checked the motor brushes there are 2 of them they are located on each side of the motor you will have to take the motor off and you will see them at the back of the motor undo the 2 screws on each one and take out the carbons should be 25m long and shinny and spring in and out freely I can supply new ones if you need them
Sep 27, 2012 | Hotpoint Ultima WF865 Front Load Washer
Where the pump on a hotpoint ultima wt960
Unfortunately the manual link won't help on this problem, it doesn't give the answer. However if you remove the rear panel ( plastic and two screws ) where the waste hose comes out, the motor will be seen on the left, the pump is on the right at the bottom corner. Hope this helps, I am unable to go further as I don't know the problem.
Apr 25, 2012 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMA62 washing machine door won't release
If the machine didnt finish the cycle due to the pump being clogged the door will remained locked also if the lock mechanism went bad, the machine will stay locked. Remove the top of the machine by taking the screws from the top back out. Once removed look down the right hand side and you'll see the lock mechanism, usually with a plastic tab you pull to manually release the lock.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 24, 2012 | Hotpoint WMA64 Front Load Washer
Ultima extra wma64 drum is loose and rattling
Your bearings have broken up in the drum. This is a very difficult DIY fix since it involves stripping the front from the machine, taking out the drup assembly, splitting it, knocking the centre spindle free and then knocking out the machine pressed bearings and replacing them.
It CAN be done by an ameture. I do it occasionally when I am repairing machines and I constantly moan about the fact that I really need to build or buy a tool to knock the bearing out. Despite the fact that the new bearings will cost about £20 ($30) ish, this is a nightmare job. Your local repair man will probably come and fit a refurbished drum for you (Then take yours away and refurbish that for his stock when he has time).
If you have never done anything like this, my best advice is that this is NOT the time to start!
Get a quote, then decide if you want the machine repaired, or to go buy a new one I'm afraid
Jun 21, 2011 | Hotpoint Ultima WF860 Front Load Washer
E15 code on display of Hotpoint ultima extra WD72.
E15 means that it is not draining fast enough. As well as checking the outlet pipes, check the filter leading to the pump. Disconnect the power and pipe. If possible take outside because there will be a residual amount of water. Remove the back panel, then disconnect the locking rings holding the tubes on. Your main target should be the big downflow rubber tube from the drum, in here is a plastic filter. In mine I found a child's sock... plus buttons...plus slime. Problem solved.
Dec 20, 2009 | Hotpoint Washing Machines
Hotpoint washing m/c WMA62 - door won't open
sounds like you have a blocked pump or discharge pipe
Oct 12, 2008 | Hotpoint Ultima WF860 Front Load Washer
WF865 noise when spinning
Washers have to be balanced. Some have balance adjusters either inside the dryer as explianed above or on the bottom to level the washer. try to balance it by turning the bolts slightly or the bottom portion of the washer to level it. Or else they want to shake apart. Also by distributing the clothes evenly so it won';t be all to one side can help. do not tighten the screws all the way. Just tighten them to the point of getting the right balance.
Jun 16, 2008 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint WMA64 Front Load Washer Logo
244 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
