Question about Samsung PPM50H3Q 50 in. HDTV-Ready Plasma Television
Power on the unit was working then just turned itself off... we unpluged the unit and pluged it back in and have a steady red stby light. when we go to turn it on you hear the click of the relays then the stby red light flashes for about 3-5 sec then the light goes off and no more reaction from any of the controls until you unplug and plug the unit. ppm50h3qx/xaa h1hxa00155a md: ppm50h3q type: nt50p3 s/n: d650h1hxa00155a
  • Anonymous Dec 02, 2008
    The screen on the Samsung Plasma Display went black all of the sudden while using it. There appeared to be no power to the unit. I unplugged it and then plugged it back in and got the red light at the power button to turn on. When I pushed the power buttun you could hear the clicks from the relays and nothing happened, and the red light disappeared again.
lukster
  • 217 Answers
SOURCE: Turns off by itself 10 minutes after use, and goes on and off
sounds like a main board problem
Posted on Apr 30, 2007
  • 29 Answers
SOURCE: Samsung LNR408DX/XAA Wont power up
power supply is bad
Posted on Mar 16, 2008
SOURCE: PPM50H3Q
Samsung Part Number: BN94-00494U from partstore.com
Posted on Nov 18, 2008
Shuttle83
  • 1139 Answers
SOURCE: TV power keeps clicking off and on no picture
Hello,This problem happens when the voltage of pin 1 of IC804 is low. The low voltage is caused by pin 4 not being 20V this is caused by two capacitors not functioning properly ( a 22uf cap in parallel with a .1uf cap) replace these and replace the 24K ohms resistor with a 44K ohms resistor (as per update specs). This should bring pin 4 to 20V and allow the set to activate. Replacing the 24K with a 44K is recommended by the manufacture to prevent the cap from going bad.Or if you do not want to do this yourself have a qualified TV technician do this for you.Thank you,Shuttle83http://www.electron-age-technologies-llc.com
Posted on Jun 10, 2009
SOURCE: my tv will not turn on the red light just blinks
When checking the capacitors, If they are slightly rounded on the top where the X is, the cap is defective.
To repair or replace the board -
Faulty parts on PS board , bad press for Samsung.
Because the Samsung LNS4051D would not turn on and the power
LED would blink 4 times and the relay would click and this
would repeat again and again. I replaced power supply board
parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors,
three had their tops bulged up slightly that I missed on
initial visual inspection. After seeing the reports of
problems with these caps on
http://www.fixya.com/support/t1336881-will_not_turn_or_off ,
I replaced them with Radio Shack part 272-1032, 1000 uf, 35v.
They are slightly bigger, but fit OK. TV is working fine now.
Cost was 4 x $1.59 = $6.36 plus the time. I saved between
$100 to 300 in the process of either replacing the board or
getting the unit serviced. If you are not comfortable
replacing components which means using a soldering iron, you
can replace the power circuit board, available from
www.Samsung.PartStore.com.
Some UTube showing the problem and fix -
http://www.youtube.com/watch?v=tK7zFBBU6p4&feature=related
http://www.youtube.com/watch?v=Mm51C_RDIZE&feature=related
http://www.youtube.com/watch?v=BNHHrgX_6cs&NR=1
Posted on May 27, 2010
The lights on my hp psc 1410 all in one printer is always on and not goin off. I have manually unpluged it and pluged it back in after a few mins and all the lights appear but no sound is coming from it...
Try a Reset. This is from the HP Web Site:
Unplug the power cord from the unit. Reconnect the power cord into the unit. When the lights begin to flash, press and hold the On/Resume and Paper Size buttons. When only the On/Resume light is flashing, release the buttons. When the On/Resume light is steady, the reset is complete.
Mar 01, 2011 | HP PSC 1410v All-in-One Printer
When I turn all it does is beep have a steady red light on. Tryed unpluging everything and pluging back in no difference.
Your issue sounds as though it is the power supply that is in need of replacement.
If there is a steady red light on then the PC unit is not getting it -12/+12/-5/+5 voltage at the connectors also you may have inadvertently switched the cable connections that is pin 1 of the cables is not getting the voltage it needs to the device.
The red line on the cable or the (+) is the supply pin to that device.
1. check the power supply and all the connectors.
2. clean all dust from the inside of the the connector and around the CPU
3.check the CMOS battery (looks like a new quarter) should show 3.7 volts with a volt meter. If readings are below this you need replacement.
I hope this helps. Have a great day!
Oct 05, 2010 | Matsonic MS8137C Motherboard
Just no power. outlet is ok! reset button does nothing to help
Might be some problem with adapter. verify output voltage of the adapter with multimeter. If no output then replace your adapter.
Regards;
Hassan
Jun 27, 2009 | Linksys Wireless-G Range Expander (WRE54G)
I have a 32 Akai HD TV I found the following problem when I returned from vacation The red light is showing. I press the power button, the green light comes on for a short while and then goes back to red....
Symptoms of a Defective or dying Power supplies on LCD TVs. 1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc. 2. TV not turning ON properly. 3. TV turns OFF by itself. 4. Needs to be unplug to many times to make it work. 5. Humming or high pitch noise heard through speakers or at the back of the TV. I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Jun 12, 2009 | Akai LCT3201TD 32 in. LCD Television
When I turn on the tv, green light blinks for a
Its your ballast. it has as short. i recommend changing the ballast. while you are inside the set, i would run a break point test on the power board to be safe but, im sure its the ballast.
Mar 09, 2009 | Televison & Video
Akai lct3201ad red standby light turns green then red again!
Feb 22, 2009 | Akai LCT3201AD 32 in. LCD Television
RED LIGHT IS ON BUT IT WILL ON TURN ON(GREEN)
Feb 18, 2009 | Akai LCT2715 27 in. LCD Television
Xbox 360 power brick turns rd when connected to console
When the light turns red that means the power brick is to hot.
Dec 26, 2008 | Microsoft Xbox 360 Console
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
4a fuse blown
1)pull chassis.remove power PCB==the one with large heatsink w/convergence IC's on it 2)Observe four regulators also on same heatsink Remove solder from all reg. pins-clean PCB 3)Resolder 4)solder any/all bad connects 5)replace 4 amp fuse 6)reassemble & test
Oct 05, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Samsung PPM50H3Q 50 in. HDTV-Ready Plasma Television Logo
Jerry Greenberg
Jerry Greenberg
