Question about Akai CFTD2052 20 in. EDTV-Ready LCD TV/VCR/DVD Combo
Power-up, but no picture
Have been using this new LCD TV (AKAI2016) for two weeks. All of a sudden, no red-light indicator is showing, and no AKAI logo on start-up. Just a blank (white) screen. Then screen goes off in about a minute. Picture won't appear. Batteries okay in remote. Using cable TV system. Troubleshooting section in TV manual does not address this problem. Stumped!
Not turning on
The power supply has failed.
Nov 27, 2012 | Akai LCT3201AD 32 in. LCD Television
Is it a Fuse or the Power Supply
It's not the fuse. Chances could be your PSU
Oct 13, 2017 | Akai LCT3201AD 32 in. LCD Television
I was watching a dvd on my week-old Sony Bravia XBR-52HX909 for the past three hours when the screen suddenly went blank. The standby indicator light in red started blinking. I attempted to turn on the...
This tv only a week olds,should never having this problems already.The tv should be return and get a new tv for the replacement,this tv have tv Tuner signal board or tv power supply board distrubution problems.Even when the store test it out it work,don't take that tv back.Insit they give a new tv for the replacement.
Dec 13, 2010 | Sony Bravia XBR-52HX909 52 in. LCD HDTV
Lcd akai 2715 blinking red light
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 19, 2008 | Akai LCT2715 27 in. LCD Television
TV ON STANDBY MODE
The blinking light on the front indicates a shorted part in the power supply. The power board will need to be replace or repair to restore the LCD functionality.
Let me know if you required further assistance.
Oct 06, 2008 | Akai LCT3701AD 37 in. LCD Television
Picture washed out, can't get it right
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Sep 21, 2008 | Akai LCT2715 27 in. LCD Television
Akai PT5598HDX/SMS won't turn on
Its busted. Try resetting it as a last resort, unplug the AC, wait 1 minute, then plug back in. If that doesn't work, its in need of professional service.
Jul 29, 2008 | Akai LCT2715 27 in. LCD Television
Akai TV troubleshooting
I have the same problem. My Akai 27" flat screen shuts off inconsistantly. Sometimes it will stay on for hours and then we have to turn in on every 2 minutes. It seems to be getting worse. Is there anyone who has found a way to fix this?
Oct 19, 2007 | Akai LCT2715 27 in. LCD Television
TV Akai CT29X4AV
Have tried checking if the Power Plug is fitting tightly in the Power socket? Could be that it is loose?
May 27, 2007 | Akai CTS2550 25" TV
Initial power-up
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Dec 17, 2006 | Akai LCT2060 Television
Akai CFTD2052 20 in. EDTV-Ready LCD TV/VCR/DVD Combo Logo
215 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
