Question about GE Energy Star WCVH6260F Front Load Washer
GE WCVH6260 stops unexpectantly
We just installed a GE WCVH6260 washer. It was purchased over a year ago but hadn't been installed until this past weekend. It worked great for the first five loads. Then it would start, do its couple spins, unlock the door, relock the door then stop and do nothing. The door remained locked. I've cleaned out the filter (there was nothing in it since it is only five loads old). I've disconnected the power for about 20 minutes. This got it working again until it tried to drain. Then it stopped and all the LEDs on the front went blank. It would periodically run the pump for about 3 seconds. Water would gush out of the discharge hose then stop when the pump stopped. A red light flashed briefly on the LED panel but otherwise it stayed dark, except for the door locked light. Help!
  • cjames651 Nov 20, 2008
    After plugging it back in after waiting another 30 minutes all the controls work until you press the start button. Then the time LEDs go blank but the door locked light stays on. Seems like maybe an electrical problem but I'm up for suggestions...
    President:
  • 1,294 Answers
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped.
Check your drain with a good pour of water from a bucket, it must clear fast. It it doesn't snake it out; the prob lies there 99%. And don't push your exit hose too deep into the standpipe, 4 to 5 inches & not air tight.
Posted on Mar 26, 2009
Front Load wcvh6260 GE front load washer.
I dont think this is a problem with the motor or inverter board.
Check if there is a control device in the machine that is stopping the motor half way through the wash cycle
Apr 27, 2012 | Exercise & Fitness
How old is my washer? When were these made?
You need a serial number to tell for sure.
They probably stopped making those a few years ago.
And the oldest one I've seen it about 10 years old. So probably between 2-10 years old.
GE washer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | GE WJSE4150B Top Load Washer
Washer, Front load #WCVH6260 F W W - trying to
use a theromstat screwdriver,
ver small flat head, push it betwen the detent
and the clamp it should release right away
Oct 03, 2009 | General Electric WSSH300G Front Load...
Ge washer wcvh6260 ...... start/pause button flashes, won't start
Does the 'door locked' light come on? If not, check the switch and it's actuator (a pin that is part of the door latch).
Aug 22, 2009 | GE WCVH6260F Front Load Washer
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
I have front loading washer/dryer;need to install pedestals.
Yes!!!! Do not lay the machines on their backs with out the shipping bolts/hardware installed..Major damage will occur!!!!!
clarkco
Feb 28, 2009 | GE WBVH6240F Front Load Washer
My 2 year old front load washer, model#WCVH6260, just stops while running, usually during spin but now during a rinse just as often. lights look normal but nothing happens. If I unplug it and wait a...
I think that you need a new control board if it is electronic if it is analog then it may be faulty wireing or since it is a front loader it may be a door sencer problem there are a number of reasons why you just need to find out which one
Hope it helps
Jul 09, 2008 | GE Washing Machines
Philips Iron easy care 3232, sole plate careezo purchased July th 2006. It has stopped steam ironing ages ago and I have repeatedly tried to de-scale it.
To clean your Philips Easycare 3232 go to
http://www.p4c.philips.com/files/g/gc3260_02/gc3260_02_dfu_ind.pdf it works a treat. I hadn't cleaned mine for a couple of years, but these instructions resolved it! On no account use any cleaning additives or vinegar!!!!!
Jun 06, 2008 | Heating & Cooling
GE Energy Star WCVH6260F Front Load Washer Logo
238 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
