Question about Motorola Mobility RAZR V3
I would like to remove the opening ring tone from new phone
When you turn the phone on, before you get anything on the screen,a welcoming ringtone/alert is played.I would like to be able to turn the phone on in silence if poss
  • 32 Answers
Go to phone settings under ringing tune u we see welcoming tune off tune that where u will set it
Posted on Nov 20, 2008
Hi just got a alcatel 2036x cheap phone but cant change ring tones can i do it on this cheap phone thanks
go into settings, ring tones , and change it there , can only change to those listed,
Oct 03, 2016 | Alcatel Cell Phones
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 | Nokia 2600
I want new ringtones for my nokia 1661 cell for that what i hav to do?
hey welcome to fixya.:) i hope u 'll be fine. Dear your problem is not a big issue u can download new and latest ring tones for your nokia 1661. Just follow the site
http://www.zedge.net/ringtones/2606/nokia-1661-ringtones/
copy this link and paste in browser, a lots of new ringtones are available there. just click on get the ring tone then the page 'll open that download on PC or download from mobile web. Then u can easily download it. i hope u can easily get it.
IF u r satisify with solution do rate me. THANKS
Jan 28, 2010 | Nokia 1661 Cell Phone
My phone fell and now the screen is blank at first you could not see anything but you could hear when it rings now you don,t
To help you with this problem, I want you to know that when a cellphone got fell, the main problem will be make is lost in display,you will not see anything but you can hear something like message tone and start-up tone, you can also receive calls. Don't be worry with that kind of problem. To tell you whats happening inside your phone is your LCD of display connection is only misaligned. Get it to the nearest cellphone repair center to get cellphone to be open by a technician and probably they will do dismantling your phone and fix the problem. Hope this could help. Don't forget to say thanks..:-)
Oct 25, 2009 | Nokia 2610 Cellular Phone
Not ringing for incoming calls or text. When I select Tones menu the screen goes blank and the phone then reboots back to welcome screen. I do get tone sounds when press the keys on the...
Hello !
Your phone has software problem the chip( EPROM )is corrupted ,it needs flashing (reinstallation of software.
This chip contains function program of the phone if corrupted the phone does not function well
If no change I suggest a new phone .
Good luck
Sep 28, 2009 | Nokia 1100
Have a new v3c phone that will only vibrate..no ring tones and cannot get it to ring
A couple of things could b set wrong. First, make sure you're volume is turned up. Flip phone open and push the top button on left to raise the volume. Second, open phone, go to menu, cursor to settings, sounds, call ringtone, single tone. Now cursor down thru the selections to pick a ringtone. Make sure the "no ring" selection is not selected. (The current selection will have a check mark on the right side.) Select the tone you want and push the center button to save it. You can then select all your other ring tones, such as message alerts the same way.
Sep 15, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
LG Scoop after using BitPim
i never had that problem but after i put ringones on my phone, my screen started freaking out and kept getting worse and now after 5 days it's completely white. i ordered a new one and should be here soon but do you think it was just a unstable phone to begin with? (the side buttons didn't work before) or should i not try it with the new one too?
thanks
Aug 03, 2008 | LG VX8300 Cellular Phone
Phone not ringing
Just recently the Innovage LED touch screen phone stopped ringing. It has worked perfectly as a home office phone since Oct. 2005. Cannot find anything in the tiny manual to correct this problem.
Dec 26, 2007 | Vtech VT-9118 Cordless Phone
Text alerts
pleace go to your phone menu and then select profile and open it then you see ring tone,ring tone volume,massage alert,massage tone,etc open massage alert and off it.
Jul 23, 2007 | LG CG225 Cellular Phone
Motorola Mobility RAZR V3 Logo
37 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
