Question about Behringer F-CONTROL AUDIO FCA202 External Sound System
Get sound through a Behringer 1204FX mixer & FCA202 interface
I have:
a) 2 AKG 1000S microphones (they seem to be working, the LED react to sound, barely, [power & phantom power light {+48 V} are lit])
b) plugged into inputs numbered 1 & 2 of a Behringer Xenyx 1204FX mixer (maybe the problem is there?,)
c) XLR to phono plug cables which run from the MAIN OUTPUTS of the
d) XENIX 1204FX mixer to a
e) FCA202 Firewire audio interface (single firewire cable maybe the problem?) which runs to my
f) MacBook Pro firewire interface, (only has one firewire interface,)
which I want to use with GarageBand to get a second person recorded on my podcast for interviews co-host, etc.
No luck, no joy,
What don't I know about this setup to get it to work?
Pointers to schematics would be appreciated as well.
-Charles-A.
  • 20 Answers
Block diagram available here:
http://www.behringerdownload.de/XENYX_GRP2/1204FX_VIEW_Rev_A.pdf
Where are the trim controls set?
Those mics use both phantom and battery power; are the mic switches set to phantom?
Try using the CD/Tape outputs to the FCA202
Posted on Apr 26, 2009
In the instruction manual it says dont use more than one mic inputs at a time
Posted on Nov 24, 2009
Best way to connect 2 1204FX mixers together
Try running the tape out of the slave to the tape in of the master unit. This us haywire, but should work. Use a stereo RCA cable.
Aug 08, 2011 | Behringer Xenyx 1204fx
Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
What i need to conect my mixer on my pc
You need two cables to connect your L/R line output from your mixer at the two inputs of FCA202 (the numbered 1,2) and one firewire cable to connect from FCA202 to your pc's firewire port.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 04, 2010 | Behringer F-CONTROL AUDIO FCA202 External...
I cant make on microphone go thru my amp mixer
It's obvious that there is a misunderstanding. Your FCA202 is designed to get line level inputs (not microphone level) and convert the signal to digital format for the computer to "undestand", it's working like an audio card. So in your case all you need is a microphone preamplifier to pass the signal from your mic to FCA202, or an audio mixer to do that.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"????????? ???????"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Stelios
Nov 23, 2009 | Behringer F-CONTROL AUDIO FCA202 External...
Adobe Audition 3 Not Sensing Mic
Check the input and output settings. Look in the preferences or settings menu for "i/o settings" or "i/o setup." You're going to set it from the default internal mic input to this one. It sounds like it may be that simple.
Jul 29, 2009 | Behringer B-1 Professional Microphone
Behringer F-CONTROL AUDIO... Problem:
I had a similar problem where as I could use the mic no problem at all but couldn't hear anything through the headphones. The simple solution was to disable the driver for my internal soundcard. It took me 48 hours to work it out! Good luck.
Jan 05, 2008 | Behringer FCA202 - FireWire Audio...
Low audio input
You need to use a mic preamp or a mixer with a mic preamp built in. The inputs on the FCA202 are line level and they won't work with a mic directly.
Dec 02, 2007 | Behringer F-CONTROL AUDIO FCA202 External...
Behringer stalls my mac
Yes, i'm surprised it hasent kernel paniked. Is the interface bus powered? What Macintosh/ OS are you running?
May 02, 2007 | Behringer F-CONTROL AUDIO FCA202 External...
Behringer F-CONTROL AUDIO FCA202 External Sound System Logo
1,018 people viewed this question
Top Behringer Computers & Internet Experts
Seanzilla
Brett Duxbury
Brett Duxbury
Steve
Steve
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
