Question about Homelite Consumer Products MightyLite Handheld Gas Blower with Quicker, Easier Starting
Mightylite 26 leaf blower
It starts easily at full choke, but stalls immediately if I adjust to partial choke or full run. Is there an adjustment I can make or an easy solution? Thanks-
  • 2 more comments
  • Anonymous Jan 01, 2009
    I have had the same problem since it was new. Only runs if choke is almost full.
    Doubt it would be a clogged air filter out of the box, or a fouled/worn out plug.
  • BMDub Jan 02, 2009
    I'm having the same problem. My blower is new and has only been used aprox 6 or 7 times. The blower starts easily on full choke but will not run at 1/2 choke or run. I disassembled part of the carb and the air intake but looks clean and no noticable defects.
  • dwandy Jan 03, 2009
    I have to run the unit on half choke the whole time.
  • Anonymous Mar 15, 2009
    There's nothing more to say on my part. I have EXACTLY the same problem as aforementioned. I've only run it about two to three times.
    Problem Solver:
  • 8 Answers
Actually a dirty filter should only choke the engine more by restricting air flow. My Homelite is new and acts like it is starving for fuel. It will run fine once started and warmed up. If it dies then it mus tbe choced again. Its always acts hungry for fuel.
Posted on Sep 28, 2009
  • 163 Answers
Have you tried changing the air filter and spark plug?
Posted on Nov 29, 2008
New carburetor - starts with full choke
Try you tube to see if they show you how to adjust it
Aug 21, 2015 | Garden
Chokes and Dies when cutting
Adjust the choke or carburetor. In case your chainsaw stalls when the engine is idling, ensure that the choke is set properly. To do so, first try releasing it to adjust it, and then move the plate and tighten all screws once again. To loosen any grit, spray carburetor cleaner spray on the choke's shaft. The carburetor may also need to be adjusted; consult your owner's manual which will guide you on resetting the idle mix screw.
Mar 13, 2014 | Ryobi 940968018 C4620 Label
Ryobi CS30 Trimmer starts and runs in full choke and half choke but stumbles and stalls on run. Not up to full rpms when in full choke and half choke....
You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
May 21, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Trimmer will only run in choke position
You have a few possibilities. Make sure you have good fresh gas in the tank. You're not getting enough gas, so choking helps get more gas than air, making it run better. Could be the carb diaphram (not very expensive if you replace yourself), when they get old they don't perform like they should. Could be the filter in the gas tank is bad, plugged. Also might be just an easy adjustment on the carb Low, and High speed screws. The choke has three positions, full choke, partial choke, and no choke, which means run position.
Apr 28, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
Engine does not continue to run
Are you laying off the choke at any point? Full choke should only be used when starting a cold engine, it should run with no choke on full throttle. If there is not enough throttle i'd first try adjusting the tiny black screw on the carb beneath your air filter while you have it idling, letting the throttle have a little bit more room. If this doesn't work and you're running it properly than you may need to make some adjustments to the H L settings for your gas/air mix. This is also done while idling mind you and only with a clean air filter.
Apr 02, 2010 | Honda 25cc 4-cycle Mini Tiller
ONAN GENERATOR STARTS THEN ONLY RUNS WITH CHOKE ON
This sounds like a problem with fuel settings or dirt in the jet.
If you can find the carb adjustment screws, with it runing on full choke - screw it in fully untill it stalls, then back out to original position, then restart.
Take off choke and adjust setting untill it runs well when warm with choke fully out.
You can then try and make it run leaner without stalling.
Feb 07, 2010 | Watts Onan Portable Generator - 4000 ,...
Carburetor adjustment for Homelite 2 cycle engine The product doesn't start easy, and it does come to full throttle. If I run it on partial choke it runs fairly good, but it has been getting worse. Last...
I have the same problem with my MightyLite 26cc Blower/Vac. If it does start it runs rough on full choke and stalls on 1/2 choke or run. I've tried everything, fresh fuel, Seafoam, etc. Nothing works. First time I used it the exhaust burned a hole in my brand new Carhartt hooded sweatshirt. Best solution, throw it away, never buy another Homelite product and tell anyone who will listen what a piece of junk Homelite products are.
Sep 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Fuel Adjustment for a Homelight Edger
Does it operate well with the choke full off or do you have to have it partially choked to get it to run? Also, how old is the gas and have you tried to run any cleaner through it b/4 messing around with the carb? Your local auto parts store sells a product called Sea Foam Cleaner. You can add that accordingly with your oil and gas mixture to help clean out any dirt in the carbs.
Aug 08, 2009 | Homelite Consumer Products Tiller...
Ryobi 720r trimmer starts ok but stalls when the
The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
Jul 05, 2009 | Garden
31cc Ryobi weed eater engine will start, then stall shortly after
you need to adjust the carb ,look for small screws around carb turn out 1/4 to 1/2 turn good luck
May 24, 2009 | Black & Decker 19" Electric Lawnhog...
Homelite Consumer Products MightyLite Handheld Gas Blower with Quicker, Easier Starting Logo
1,546 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
