Question about Sub-Zero 690 Side by Side Refrigerator
Ice maker not making ice
I get a "EC 38" Message with "service" flashing. The ice maker is not making ice. any suggestions?
SOURCE: Sub-zero 632 error code 24
clean out auger bucket ec-24 is defrost underheat,to clear press and hold bell on/off key for 15 seconds.
ALL APPLIANCE REPAIR L.L.C
HOT SPRINGS
Posted on Jul 16, 2008
SOURCE: 550 Ice Maker Making Hollow cubes or Small Cubes
Hollow cubes are usually a result of lack of water supply
Posted on Jul 19, 2008
  • 56 Answers
SOURCE: The ice maker not making any ice. Screen reads "service ice".
Call the factory at 800-222-7820. But first turn the unit off for ten seconds then turn back on. Now press the Ice on/off button and the word ice should leave the display. Press it again and the ice should reappear. We have reset the computor at this point. Let the unit run for three hours and check it. Normal harvest time is an hour and a half but we are giving it more time. There is more you can check if you are comfortable or call a tech out. Reply if you want to do more.
Posted on Dec 10, 2008
  • 1218 Answers
SOURCE: My subzero 650 ice maker drips water w/o making ice
Good day,
No, a new water valve should solve that problem. The diaphram in the valve is not completely closing.
Very common problem.
Thank you for using FixYa
Posted on Dec 24, 2009
Testimonial: "If this works, it makes for a wonderful Christmas present. thsnks!!"
  • 71 Answers
SOURCE: water leaks into ice maker bin
2 possible causes. 1) tehe tube is not inside of the ice maker. 2)the ice maker has acrack. better to call a tech
Posted on Apr 01, 2010
Have installed a new ice maker, it still will not work.
Soulds like the your model has a electronic eye that monitors the ice level has failed. Page 6 in the Click Here=> GD5SHAXKQ00 Parts List Location number 38 is the 2198585 Ice Level Control Board
Whirlpool Ice Maker Infrared Electronic Eye Technical Information I am here should you have questions, Thanks Sea Breeze
Apr 15, 2013 | Whirlpool GD5SHAX Side by Side...
"service" flashing also what seems to be an error
Service flashing- 1. Ice maker not working 2, Rise in temperature 3. Condenser needs cleaning
To Clean Condenser 1. Remove Grille 2. Brush with a soft brush 3. Vacuum being careful not to bend fins.
Jul 07, 2011 | Sub-Zero 650/SRH Stainless Steel
Ice maker does not make ice. Water supply works, but ice machine is dry.
if it is the ice maker in the door, it's a bad ice maker....we do a lot of them
Nov 12, 2009 | LG LSC26905TT Side by Side Refrigerator
Ice maker not filling with water or making ice- GE pfss6pkwss
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 01, 2009 | Refrigerators
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
May 30, 2009 | GE Profile PSW26P Stainless Steel Side by...
Sub Zero model # 695 is flashing EC-40 error message. No ice.
When our Sub-Zero Model 650 quit making ice, and the SERVICE ICE lights started flashing, we called our technician who said, "You can pay me $178 for a service call or have another option - you have 2 seconds to decide. Oops, your time is up, I will decide for you!"
"Open the door and push the REFRIGERATOR UNIT ON / OFF message button; wait 30 seconds and push it again. About 95% of the time, the unit creates the glitch, and you are simply rebooting the computer. If that doesn't work, call me. I hate to take your money to come out to push a button."
IT WORKED! The warning message turned off and the freezer started cranking out ice.
Dec 18, 2008 | Refrigerators
HOT SPRINGS
Feb 28, 2008 | Sub-Zero 632 / S
Ice maker not making ice.
These Icemakers have plastic gears on the modules that are breaking, also some have thermostats that are malfunctioning. I recommend haveing an experianced tech look at the unit to see if you need the new upgraded indoor ice maker.
Jan 14, 2008 | Kenmore 21.7 cu. ft. Top Freezer...
Sub-Zero 690 Side by Side Refrigerator Logo
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
