Question about Dayton (3E379) Heater
I have a Dayton gas heater Model 3E225
Burners will not ignite when turned on. (Pilot light is lite).
  • rainyhal Nov 20, 2008
    The fan runs but the burns still don't ignite. Could the heat sensor on the left-side of the heater be bad?
  • allen78j20 Dec 21, 2008
    I am having the same problem. Pilot is lit and then the fan kicks on but the main burner does not. Sometimes if you let it run the main burner will kick on after 5 minutes or so. Any ideas?
I Need a wire Diagram for a Dayton Heater mode # 3E225
Posted on Oct 10, 2012
    Problem Solver:
  • 16 Answers
Does the main blower fan kick on? Also, if the heater is vented outside via a flue pipe, there may be a small (about 3 or 4 inches in diameter) vent fan that kicks on to ensure the exhaust fumes are evacuated through the flue pipe. If there's a problem with that fan, the burner won't light either.
Posted on Nov 20, 2008
  • Kory Ginther
    Kory Ginther Jan 25, 2014
    The burners are lite but I was wondering if there is a way to adjust them to get more heat out of them ?
Why does burners and pilot forced off after burners are engaged
We get asked this question many times.
If you light your pilot light, hold in the button and then when you release it and the pilot light goes out, generally you need a new thermocouple. Gas repairs can only be undertaken by a qualified gas technician so you can't do this job yourself.
The thermocouple is a safety device that recognises that the pilot has a good flame and is enough to ignite the main burners. The thermocouple open that valve to the burner.
In limited circumstances the thermocouple doesn't need replacing, either the shield that aims the flame to the thermocouple has become dislodged, or the pilot jet is a little blocked by debris. Either way, having the appliance serviced by a qualified gas fitter is the way to go. I am sure you will have seen news stories about explosions caused by gas leaks and faulty appliances.
Jan 18, 2016 | Procom Heating & Cooling
Pilot light stays lit but burners do not ignite
check to see if pressure switch wires are tight and pressure to pressure switch then check safety circuit make sure wires to gas valve are tight
May 23, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
We have a late ignition on start up, we cleaned the burners and replaced gas valve and still has late ignition.
if it has a pilot light is this too small causing it to light with a bang is what you mean with late ignition ??
Aug 22, 2011 | Dayton (3E227) Gas Radiator Heater
Have a dayton 3F405D propane greenhouse heater don't know where to light the pilot light.
Find where the gas line connects to the gas valve on the back of the heater, from the gas valve, follow a small aluminum tube going into the back of the heater. There may be a removable door to access the pilot assembly. If there is no aluminum tube, the unit has electronic ignition and no pilot lite. Turn the gas knob to off, then to pilot. Hold the gas valve in and with a long match or gas grill lighter, light the pilot. Continue to hold the knob in for about 30 seconds. After that, release the knob and check to make sure the pilot stays lit. If so, rotate the knob to ON. The thermostat will kick the burners on.
Mar 30, 2011 | Dayton (3E405) Gas Radiator Heater
Pilot stays lite but fan comes on without burners lighting
On older systems the fan is controlled by a time delay relay which will turn of the blower after a preset time when a call for heat is present regardless if there is a burner function or not.
Need to check why the main gas valve is not energizing, there are to many configurations for a complete diagnostic without further info, Model, Brand etc.
Feb 25, 2011 | Dayton Gas Furnace Heater
Have dayton heater,model #4LX41A heater comes on,pilot lights but no gas ignition ? Already cleaned injectors, and made sure i have gas. Mike M.
try cleaning the thermocouple or even replacing it because if the thermocoulple doens't sense the pilot light then it won't open the gas valve.
Jan 24, 2010 | Dayton (4LX41) Heater
Rheem imperol 80 pilot light turns on but the burners will not light
HAVE YOU TURN THE GAS VALVE TO ON WHAT MODEL DO YOU HAVE HAVE YOU RAISE THE TEMPETURE CONTROL IF YES THE GAS VALVE OR THE IGNITION CONTROL ARE BAD
Nov 29, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Model 3E225 fan comes on but main gas will not ignite
loose and corroded wire on back of the main valve
Sep 30, 2009 | Dayton (3E379) Heater
Can't re-light the pilot light
THIS HEATER DO NOT HAVE A PILOT YOU MUST HAVE A DIFFERENT MODEL. DO YOU GAS? TURN KNOB TO PILOT PRESS. LIGTH PILOT WAIT FOR 60 SEC AND RELEASE IF STAY ON TURN KNOB TO ON. IF TURN OFF PILOT MUST BE REPLACE
Jun 20, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot light
Hi the thermocouple is a long copper wire that goes back to the gas valve from the pilot .
i would clean the flame senser first , then check the pressure switch jump this out , then check the fan control or snap disc jump this out see if it runs if you need A THERMOCOUPLE then honeywell universal will do
Apr 07, 2009 | Dayton (4LX41) Heater
Dayton (3E379) Heater Logo
901 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Tim Whalen
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
