Question about Philips AZ1030 Cassette/CD Boombox
CD will not play
CD does not play (no audio). But, the disc is turning. All other functions work: am, fm, and tape player.
0 characters
1 Points
Cd player only shows
You will need to check the swith that change from Tape to CD to other functions. If the switch is good. Then the next thing is to check for tape function. Can you try to fast forward, reverse. If these functions are working properly then the pinch roller ( the little wheel that is pulling the tape need to be replaced). If nothing moves then you need to replace the belt and the wheel and possible the motor at the same time
Nov 17, 2011 | Lenoxx Electronics CD-102 Cassette/CD...
How do I get it to record a voice?
Many portable 'boombox' recorders do not include a microphone for recording ambient sound, but can only record from one internal source to another, like radio or CD to Cassettte. Some do include an input jack for microphones or other audio sources, but you'll need to check your device's specs/ports to be sure.
May 18, 2011 | Sony CFD-F10 Radio/Cassette/CD Boombox
How do you start a tape to play ok..i turn on...put in a, how do i get it to play
Look for a symbol that looks like this >I. or just this>, and push. Make sure you have selected "tape" function
Apr 10, 2010 | Sony Boom Box With CD Player & Cassette...
My Sony CFD SO1 keeps skipping/display light keeps flashing
That is an electronic problem. Probably a just-about-to-break cable in the motor of the CD drive, that sometimes causes a short and turns off the unit, or sometimes makes it to comport erratically and produce the buzzy sound. If you have electronics knowledge, then you may open and check the wiring harnesses. If don't, take it to your local electronics repair.
Nov 20, 2009 | Sony Boom Box With CD Player & Cassette...
Cassette players jammed
actually you can not lubicate the cassette players. it has to do with a belt inside. your players may need to be demagnitized. i would go to radio shack or electronic store and try a cassette cleaner/demagnitizer and see if that solves the problem. i would even try different batteries or a ac power adapter if you have the plug. some batteries make units run slow. i would even get a can of dust cleaner that you find in the electronics section. you spray it in and it cleans the inside of the dust that may be inside.
Mar 22, 2009 | Sony Boomboxes
Cd player on boom box
Hi I don't have a boom box, but i do know a little bit about CD players, and i think first the CD you are putting into the player as to be a proper bought CD, you know official CD, if you have done that, and still have the same problem, then its because the laser light is faulty, which basically means the CD player needs replacing.
Jun 10, 2008 | Boomboxes
Cd's wont play
can you please post here the model and the part # of the cd player.. & please kindly inform me the type of cd she play in the unit, is it a Audio CD..?
Apr 16, 2008 | Boomboxes
My Discs not recognized after loading, do i have to fix the CD or the disks? jWIN CD-977. Still get 'error' message when trying to start the 'play' function. Unit has never consistently worked since...
hi you could try cleaning the laser lense with dust free cloth but soft one if this dont work try cleaning your cd you can run it under cold water tap and then dry with soft cloth make sure their is no scratches on disk surface if this still dont solve problem then you find the laser itself needs replacing.
But the problem with this is replacing the laser and getting it calibrated will cost more than a new stereo thats why knowbody repairs these kind of problems let me know if you need further assistance
Feb 11, 2008 | Jwin (JX-CD512D) Sports Portable CD Player...
Cd player cant read disc
Check that the disk is still spinning. If not then suspect the spindle motor
Mar 23, 2007 | Sony CFD-S350 Radio/Cassette/CD Boombox
Philips AZ1030 Cassette/CD Boombox Logo
24 people viewed this question
Top Philips Boomboxes Experts
Jonathon summesfield
Are you a Philips Boombox Expert? Answer questions, earn points and help others
