Question about Sony XM-2200GTX Car Audio Amplifier
Playing my music, then amp goes out? anyway to fix it?
I was in my car playing music(about half way volume) not too loud then i switch a song and the amp goes out. the LED light will not even come on and its pushing no power. is there anyway i can diagnose the problem or fix it without having to buy a new amp?
    Problem Solver:
  • 13 Answers
Looks to me like u are having a power problem. Check if power is going to your amp, if yes, check the fuse on the amp. If ok, check the powersupply section for any damage components and replace.
Posted on Dec 18, 2006
SOURCE:
I have a peavey VIP2 amp.Can I use my acoustic/electric guitar in the electric guitar setting
You can not only play it on electric guitar setting, you can play it LOUD. Its all about what YOU do and what YOU like. Dont accept it when somebody tells you that the music you're playing doesnt sound good to them. ITS YOUR MUSIC !
Do whatever you want. And NO it wont hurt guitar or amp. Rock on or whatever it is you do.
Oct 26, 2015 | Peavey Vypyr VIP 2 40W Modeling Combo...
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
Volume on the piano is less than half the volume it should be. Demo and play along songs play at full volume but keyboard wont no matter how hard the key is pressed, Is there a fix for this...
Pianos do NOT respond to keys pressed hard... they respond to FAST presses. If you have an issue with the piano, first go on record to activate your warranty. Most of these electronics DO have a setting that adjusts the "feel" which affects the loudness versus key velocity... Now here is a secret??? Shh... The manufacturers turn up the demos just like the advertisers turn up the commercials on the TV... I would suggest looking for the adjustment of feel, and if that doesn't get satisfactory results, find another and compare yours to another... if yours is still underperforming, exercise your warranty for repair or replacement.
Jun 11, 2011 | Williams Encore Digital Piano
This bass squels if you have a bass head and cabinet. i had a 100W amp and it played fine then upgraded to a head/cab. tryed playing it with loud volume, squels. anyway to fix this?
Turn down the treble gain and mid gain... you don't need it for a bass. Prevent the guitar from "hearing" the output of the amp directly. The guitar strings make a good microphone.
Feb 27, 2011 | Epiphone EBO Electric Bass Guitar...
My Dual Terror amp stops working just a few songs into my practice session. The best way I can describe it is that it's like a battery going dead in a guitar with active electronics. The volume...
Instead of waiting a day, cool the thing down as quickly as you can and try it to see if it is a therma; problem.
You MAY be driving it too hard and the amp chip is going into thermal shutdown... This is a small amp and not intended for major loud use.
TRY playing softer and see if it lasts longer before failing. If you are overheating the internal chip because you want it loud, best to get a bigger amp...
Next test is to turn it on but DON'T play for a time period of more than the usual few songs and then see if it is already dead or you have to play awhile before it fails.
Dec 09, 2010 | Orange Amps Orange Amplifiers TT15C Tiny...
How do you get your 6700 to play music etc on the headphones
Your phone includes a media player for listening to songs and viewing video clips. Music and video files stored in the music folder in the phone memory or on the memory card are automatically detected and added to the music library.
To open the media player, select Menu > Media > Media player.
Music menu Access your music and video files stored in the phone memory or on the memory card, download music or video clips from the web, or view compatible video streams from a network server (network service).To listen to music or play a video clip, select a file from the available folders and Play.
To download files from the web, select Options > Downloads and a download site.
To update the music library after you have added files, select Options > Update library.
Play songs
To adjust the volume level, press the volume keys.
Operate the player with the virtual keys on the display.
To skip to the beginning of the previous song, select icon_28.giftwice.
To rewind the current song, select and hold icon_28.gif. Release the key at the position you want to continue the music playback.
To close the media player menu, and to continue music playback in the background, press the end key.
To stop the media player, press and hold the end key.
Hope it helped.
Nov 22, 2009 | Nokia 6700 Classic Cell Phone
Marshall Amp Sound Problem
try cleaning the send and return sockets with switch cleaner or WD40
Jan 31, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
MediaPlayer problem
The music file must be corrupted..pls try to play a fresh copy of this song...
Nov 29, 2008 | Acer Aspire 5100-5033 Notebook
Alpine MRD-M1005 Subwoofer Amp Problem
He may be right! You might try finding a new source of contact for your ground cause it may not be sufficent enough to ground to, also make sure that no wires from the back of your radio have any wires sticking out touching other interfering things that could possibly be causing the noise
Sep 14, 2008 | Alpine MRD-M1005 Car Audio Amplifier
Creative Zen
Most audio software these days offer either built-in or plugin functionality that will attempt to level the volume of your MP3 files so that you aren't turning the volume up to hear soft songs, then getting blasted by louder ones. So why is it that even after turning that option on, you sometimes notice a significant volume difference between some songs? What's worse is when you're listening to songs from the same album, and the volumes jump around abnormally after applying volume normalization.
The problem is that the vast majority of audio player programs use peak amplitude analysis to determine how "loud" a song is and normalize based on that, rather than doing a more comprehensive analysis of the frequencies that impact how loud the music actually sounds. But even those that do a more comprehensive analysis fail to consider songs within the context of the album they belong to.
Luckily, there's a great little utility called MP3 Gain that does lossless volume analysis and adjustment based on David Robinson's Replay Gain algorithm, as well as allowing for the volume of entire albums to be processed. MP3 Gain has been around for a number of years, and it doesn't appear that it is being actively developed anymore, but since MP3 technology hasn't changed much either that doesn't matter for our purposes.
So, how do you fix an entire library of music? Pretty easy, actually. MP3 Gain offers batch processing options that allow you to process an entire folder at once. But if you collect music albums, you'll want to do those separately. The reason is that MP3Gain offers two modes: Radio and Album. Radio analysis and gain adjustment will adjust all songs to the same maximum decibel level. Album mode analyzes all of the songs in an album, essentially considering them to be one entire song, then adjusts them all to a maximum decibel level, but maintains their relative volume.
Jun 21, 2008 | Creative Labs Zen Digital Media Player
Sony XM-2200GTX Car Audio Amplifier Logo
111 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
