Question about HP LaserJet 3600n Printer
Hp 3600n repl. cyan cartridge & mach. is in continual calib mode
I replaced cartridge with an aftermarket one and the machine stays in calibration mode.
HELP PLEASE !!!!!!!!!!!!!!!!!!!!!!!!!
  • napostolou Dec 09, 2008
    I have the saem problem
    Novelist:
  • 91 Answers
This is an answer to most of the problems of "continuous calibration" in the HP 3600.
When the printer begins to constantly calibrate and falls in line so we have a problem, there are several causes for that problem and must be discarded from the simplest solution to the most complex.
Let's begin:
SOLUTION 1: The first thing to do is turn off the printer, and remove the cartridges, toner dirty or if the internal parts of the printer remove the excess, if there is dirt in the transfer belt clean.then close the front cover and turn on the printer without cartridges. then open the lid, place the magenta cartridge, and close the lid again, and so putting the four cartridges. If the problem persists try the next solution.
Solution 2: We must be alert to any strange noises in the printer, it is likely that one of the sticks is failing, if we are a strange noise came from, and replace the cartridge.
SOLUTION 3: There are times that it is software problem can be solved with a "COLD RESET" to do this we must turn the printer, and press the green button several times in the main menu until you see some options, navigate to the Down Arrow button until COLD RESET appears, press OK. the printer will restart and initialize. then restart and probably reached OK status.
SOLUTION 4: Sometimes by changes in temperature and environment where the printer is out of calibration sensor, to do a need to upgrade the firmware of the printer, usually ends the problem here. To download the firmware of the printer with the improvement because of "Countermeasure for multiple Successive Causing Environmental Sensor Calibrations." Is in the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=501044&swItem=lj-44336-1&prodNameId=501046&swEnvOID=54&swLang=8&taskId=135&mode=4&idx=0
SOLUTION 5: If any of these options serves, it is likely that the mirrors of laser printer are dirty, this requires us to print a sheet to observe defects in print (moved, blurred, misplaced shadows), if any of these defects appear we disassemble the printer for cleaning the laser ... in this link are instructions
http://ingenioysoluciones.wordpress.com/2010/04/12/limpiar-espejos-de-la-impresora-hp-3600n-para-corregir-impresion-defectuosa/
Posted on Apr 15, 2010
I installed new cartridges (4 colors (B, Y, M & C) and closed the top cover, it calibrating continuously for a week and more. So, please help me to solve this issue. My printer model is HP Laser Jet...
Hi I'm sorry to say its normally a faulty cartridge.
You now the black belt in the front of the machine well the machine when it calibrates prints a pattern on the belt and it uses this pattern to calibrate its self but if the pattern is not on the belt it can not finish the calibration.
solution replace the toners one at a time until you get it going
yours Ian
Mar 08, 2011 | HP LaserJet 3600n Printer
HP LaserJet 3600n I replaced the black cartridge. The new one was defective and continuously calibrated! - so replaced it with another one. Before figuring out that the cartridge was the problem I...
Yes,
Go to Computer, then System Properties, The Device Manager. Down the list of devices you will see "Imaging Devices". Open the category and dowble click on your printer. Go to the Driver tab, open and,
Marcus choose.."Rool Back Driver" and follow the instructions.
Regrads
Sep 28, 2010 | HP LaserJet 3600n Printer
I replaced all 3 color cartridge with origanal hp products, even after calibrations (3 times-full mode) only cyan and black are printing nicely. red and magenta colors are not printing.this is not driver...
This is a common problem with this model of printer. The scanner optic degenration is due to dust buildup on mirrors and lenses. Since the most vulnerable mirror reflects its laser beam to the magenta toner cartridge, red tones are the first to show fading. Colours shift: purples turn blue and oranges turn yellow. The printer optics will need to be cleaned by a technician to resolve this issue as it means dismantling your printer deep into the optics to fix the problem.
Jun 07, 2010 | HP LaserJet 3600n Printer
Have HP3600n over just 1year. Having trouble after startup gets stuck in calibration and won't go any further... any thoughts? Have tried cold reboot w/all unplugged several times...Mike
Start by removing the formatter. Have paper in tray 2.
Print an engine test. You should see repeating lines of cyan, magenta, black and yellow. If any of the colors are missing - run the Disable Cartridge Check. Run the engine test again with the previously missing color in another slot. If that color fails again, replace it. If the issue stays with the slot replace the laser scanner. If the engine test is good now, install a new formatter, power up and see if the calibration hang is gone.
Jan 26, 2010 | HP LaserJet 3600n Printer
Cyan is offset about 3/16"
check the locking tabs on the cartridge, sounds like they are not locking down the cartridge.
Jul 31, 2009 | HP LaserJet 3600n Printer
Can't stop the printer calibrating
No guarantee this will fix your problem, but the last time I experienced this problem it ended up being one of the toner cartridges. I replace her refurb. toners to OEM brand.
Jun 02, 2009 | HP LaserJet 4600dn Color Printer
Have a Color Laserjet 3600n printer. It keeps on calibrating without stopping when I switch it on. why ? thank sin advance.
600 Hp Continuous Calibration 1 Votos
This is an answer to most of the problems of "continuous calibration" in the HP 3600.When the printer begins to constantly calibrate and falls in line so we have a problem, there are several causes for that problem and must be discarded from the simplest solution to the most complex.
Let's begin:
SOLUTION 4: Sometimes by changes in temperature and environment where the printer is out of calibration sensor, to do a need to upgrade the firmware of the printer, usually ends the problem here. To download the firmware of the printer with the improvement due to "Countermeasure for multiple Successive Causing Environmental Sensor Calibrations." Is in the following link:
May 26, 2009 | HP LaserJet 3600n Printer
If the calibration is taking a long time that can be related to the ITB belt. If the printer doesn't think that the calibration is correct it will keep trying until it sees a correct image(color)
Mar 13, 2009 | HP LaserJet 4600dn Color Printer
HP Color Lserjet 3600
We found that we had a defective cartridge. We returned it. A replacement cartridge did not cause the printer to callibrate continuously.
Jan 10, 2009 | HP LaserJet 3600n Printer
Magenta doesnt print in proper place
Sounds like the new cartridge has been sitting around for too long. The solid lines are usually due to the drum being exposed to light for too long. The other reason could be the charger roller has been in contact with drum (in the cartridge) for a very long time and probably heat has a part in it as well. Try another cartridge.
Jan 09, 2009 | HP LaserJet 3600n Printer
HP LaserJet 3600n Printer Logo
405 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
