Question about Kenmore 53642 / 53644 Side by Side Refrigerator
ICE MAKER NOT WORKING
I HAVE A KENMORE ULTRA FRESH SIDE BY SIDE WITH WATER AND ICE DISPENSED IN DOOR. THE WATER DISPENSES THRU THE COLD WATER PERFECTLY BUT NO ICE. THE ICE MAKER DOES NOT WORK. THERE IS NO WATER GOING TO THE ICE MAKER. HELP!!!!!
MODEL NUMBER 106 56662500
SERIAL NUMBER STO848752
  • 7 more comments
  • jannekeb Feb 21, 2009
    I am having the same problem with the ice maker not working while the water dispenser works just fine. I can feel frozen ice in part of the dispenser and wonder if it froze in there and clogged it up. I've had the fridge for 4 years and it's been fine until now
  • bballboz Mar 18, 2009
    Water dispenser works fine, the ice maker stopped making ice, no water is being dispensed into it. What did you do?
  • Anonymous Apr 04, 2009
    ice not make
  • gerand458 Apr 04, 2009
    we used all of the ice last night and the ice maker has not produced any ice since the. The ice compartments have ice in them but it is not being dispensed into the bin. Can anyone help?
  • Anonymous Apr 09, 2009
    Having same problem. No water from tubing going into ice maker. How do you get the water to flow thru tubing?
    Water dispensor working fine. Also the grey tray where water enters is extremely hot. Is this normal or due to water not getting through?
    Same problem. Water dispensor works but not the ice maker. Water not going through tubing to ice maker. Also grey tray where water goes into ice maker is extremely hot. Is this due to water not coming in or is it normal?
  • Terry Krok
    Terry Krok Sep 18, 2012
    The freezer is set to 4 degrees. So I guess that isn't the problem but thank you for your answer
  • ezekipam
    ezekipam Jan 13, 2013
    My kenmore refrigerator model number 253-5739960 is not making ice, what can I do
  • Anonymous Mar 30, 2014
    model number GSI-23
  • 370 Answers
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
Kenmore ultra fresh side side 59507990
828a4e4f-c0b3-4029-a7f5-35b92db8b7ad.jpgKenmore model numbers look like this example=> 321.1234578 Are you sure that the water in the ice maker is melting and flowing down into the ice bin? What may be happening is the water control valve for the ice maker may be allowing water to continue flowing into the ice maker tray even when off due to the water control valve being defective. If your refrigerator also has a water dispenser and the water is not continuing to leak is because the water control valve has to sides. One side is for the ice maker and the other side is for the water dispenser. I am here if you have questions, Thanks Sea Breeze
May 29, 2013 | GE Refrigerators
Water will not flow. It is a kenmore cold spot
Most likely the dual water control valve is not opening to allow the water to the dispenser if that is your meaning. Now if you mean water for both dispenser and ice maker then that would change everything. See if you can locate the model number that Sears puts on the door frame near floor. The fresh food section door at base and the number will look like this example 312.256489 With that number I can see everything your side by side came with and tell you the parts and locations. You also can have someone test voltage going to the water control valves while someone presses the dispense water switch. And with a voltage meter set to OHM's test the coils on the dual water control valves for resistance and if one has a very different number that can tell you. So we have several things to look for, water supply, dual water control, (if one works and other will not) and model number, Let me know what you find, Sea Breeze
May 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore coldspot water dispenser stopped working. Ice maker works. What could be possibly wrong?
On the rear of your refrigerator there is a dual water control valve. One side for ice maker and one side for water dispenser. I believe your side for the water dispenser has failed and they come as a set. Send the Kenmore model number and I will find you one. The number will look like this, 326.256489 for example only. Found near the bottom of the fresh food section door. Thanks, Sea Breeze
Nov 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
I have a Kenmore side-by-side refrigerator and the water dipenser quit working, the ice maker works fine. Any solutions?
Check water valves on back of fridge, one is for the ice maker and other is for water dispenser. Need to get the correct and complete model number listed on front and near floor behind the fresh food door. Problem may be the water valve in back or the dispenser switch on the front. let me know and I will try to get it going for you.
Thanks, Sea Breeze
Mar 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
2,196 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
