Question about HP Office Equipment & Supplies
HP Officejet 5600 will not answer fax line - HP Office Equipment & Supplies
  • 162 Answers
Connect the unit directly to the phone jack (wall), disconnect all other devices using the same phone line (telephones, answering machines only) (if you're on DSL, leave computers, routers connected).
go to faxzero.com and send a fax to your number. this way you'll be able to isolate if it's one of the equipment or a phone provider feature/service such as call forwarding.
Posted on Nov 20, 2008
Hi my hp 640 will not answer a fax call, but will answer only if we pick up the hand set.
Issue When the all-in-one product is sharing a phone line with voice calls, some calls are interrupted by fax tones. Follow the steps below to solve the problem.Step one: Check the Rings to Answer setting If Auto Answer is enabled, the HP fax product will answer the phone line when the number of rings reaches the number of rings specified in the Rings-to-Answer setting. When voice calls will be received on the same phone line as faxes, set to rings-to-answer to 6. If you do not want the fax to answer automatically, either turn off Auto Answer from the front panel and receive faxes manually (this may result in lost faxes) or subscribe to a distinctive ring service from the phone company (if available). Refer to the Answering faxes manually section below to learn how to answer faxes manually or refer to the Using distinctive ringing section below for more information about using distinctive ringing. The Rings-to-answer setting for the HP Officejet 500 and 600 series products can only be checked or set using the all-in-one software on the computer. The Rings-to-answer setting for the HP Officejet 500 and 600 series products can only be checked or set using the all-in-one software on the computer. Follow the steps below to check or change the setting for all models except the HP Officejet 500 and 600 series:
  1. Depending on the model, press either Menu , Setup , or Fax Setup repeatedly until Basic Fax Setup appears in the display.
  2. Press Enter (or Start or OK ).
  3. Press the right arrow button repeatedly until Rings to Answer is displayed, and then press Enter .
  4. The number of rings before the HP fax product answers will be displayed.
    • The setting is correct if it is 6. Press Cancel or Stop (Stop Fax) to exit the menu.
    • If the number is not 6, press the right arrow button until 6 appears in the display and then press Enter (or Start or OK ).
Aug 30, 2011 | HP 640 Inkjet Fax Machine
Cannot fax on the 5600
Please access the online instructions for faxing with your printer by clicking here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 24, 2009 | HP Officejet 5610 All-In-One InkJet...
Fax problems with hp 5600
I have fax pluged into phone line and every time I try to send it states fax failed. How do I correct
Jan 28, 2009 | HP Officejet 5610 All-In-One InkJet...
Can't receive faxes
well... check the telephone cable or conector...Rj11 conectors...
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
For about a couple of days now my fax which is a HP Officejet 5600 all-in-one, it has been showing a message that the phone is off the hook but it is not and it does not allow me to Fax anything. It is...
Plug the phone line directly into the LINE jack on the Officejet. If it works that way, buy a dual adapter and a nother line cord from your local office supply store. This will seperate the Officejet from the cordless phone.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 28, 2008 | Office Equipment & Supplies
Have to be near fax machine to recieve fax
The Rings to Answer feature might not be set to answer after the
appropriate number of rings for your office setup.
If you have a voice mail service at the same phone number you use
for fax calls, you must receive faxes manually, not automatically. For
information on how to receive faxes manually, see receive a fax
manually from a phone
on page 48.
If you have a PC modem on the same phone line with your
HP Officejet, check to make sure that the modem’s software is not
set to receive faxes automatically. Modems with this auto fax
receive feature turned on will take over the phone line to receive all
incoming faxes, which will prevent the HP Officejet from receiving
fax calls.
If you have an answering machine on the same phone line with
your HP Officejet, you might have one of the following problems:
Your outgoing message might be too long or too loud to allow
the HP Officejet to detect fax tones, and the calling fax machine
might disconnect.
Your answering machine might not have enough quiet time after
your outgoing message to allow the HP Officejet to detect fax
tones. This problem is more common with digital answering
machines.
The following actions might help solve these problems:
a. Disconnect the answering machine and then try receiving a fax.
If faxing is successful without it, the answering machine might
be causing the problem.
b. Reconnect the answering machine and re-record your outgoing
message. Make sure the message is as short as possible (no
more than 10 seconds long), and that you speak softly and
slowly when recording it. Try again to receive a fax.
If you have a special ring pattern for your fax phone number (using
a distinctive ring service through your telephone company), make
sure that the Answer Ring Pattern feature on your HP Officejet is set
to match. For example, if the phone company has assigned your
fax number a double ring pattern, make sure Double Rings is
selected as the Answer Ring Pattern setting. For information on
changing this setting, see change the answer ring pattern
(distinctive ringing)
on page 63.
Note that some ring patterns cannot be recognized by the
HP Officejet, such as those with alternating short and long ringing
patterns. If you are having problems with a ring pattern of this type,
ask your phone company to assign a non-alternating ring pattern.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 20, 2008 | HP Officejet 4215v All-in-One Printer
Printing
hi,
here are the things that i want you to follow to somehow resolve your issue.
1. On your computer, click on start then go to control panel
2. inside control panel open the PRINTERS and FAXES (XP) or PRINTER (VISTA).
3. make sure change the default printer icon to the HP Officejet 5600 series.
- right click HP Officejet 5600 series and choose "set as default printer"
4. then try printing,
note: the reason why you encounter that problem is because the default printer icon is the "HP officejet 5600 series fax".
best regards
adonscott
Apr 04, 2008 | HP Officejet 5610 All-In-One InkJet...
Fax
HI,
u can press set up go to advanced fax set or basic fax set up and then go to fax logg > press ok on that .
u can get the details of the last 10 or 15 faxes.
Thanks
Apr 02, 2008 | HP Officejet 5610 All-In-One InkJet...
128 people viewed this question
Seeker5211
Seeker5211
