LX-300 Printing Problem
I am using the Program developed in VFP, from the program i need to print checks of 4x8 size but when i m printing using custumized page setting priter still rolls up to the size of A4 and then prints the 2nd chk
How cn i stop the priter tractor as soon as printing is finished
Can any please help solving my this problem ASAP.
  • Fawwad Nov 21, 2008
    I have selected the customized paper size of 4x8 which i have created using
    Start ==> Setting ==> Printer & Faxes ==>File ==> Server Properties
    but when i am selecting custumize paper size and the printer i want to print on it prints on right printer with right width but after printing first check printer rolls the page up to 11 inches rather than rolling it to 4 inches and then it should print the 2nd check as i have 3 check per page in tractor paper.
    I have tried to change the defualt setting of printer as well but even that didn't work.
  • 1,879 Answers
Printer & Faxes ==>Printer Properties - use created custom paper size
Program Print settngs
Posted on Nov 21, 2008
  • 162 Answers
Go to the printer properties and set the correct paper size. printer and application paper size must match.
Posted on Nov 20, 2008
Epson lx 300 printing a4 size
my minonlte is showing code co4
Aug 01, 2013 | Office Equipment & Supplies
Custom size doesn''t present on your driver on Form to Tray Assigment in
Hi, I can't understand what "Custom size doesn''t present on your driver " means. the drver is just the piece of sofware used by windows to make your printer work. Custome size setting should have nothing to do with the driver.
Feb 23, 2008 | Epson LX-300 Matrix Printer
How to get 300 dpi with canon sd630
Dots per inch is a measure used by printers when printing a picture. As such, it is irrelevant to the camera when taking a picture. There's no way to change the value the camera inserts into this field. Your photo editing/printing program will let you change this value if you need to. However it is usually more convenient to specify the output size instead of the resolution. For example, you might specify a 4x6 or 8x10 print and let the program figure out how many dots per inch it needs to use to produce a print of that size.
Aug 02, 2011 | Cameras
Hi, One of our client using epson lq-300+II dot matrix printer to print their invoices in custom defined paper (using crystal report). It was working fine when they were using windows xp. Now they...
Hello, Please, if you can change back to the former operating, is either the printer type is not compactable with the new windows(Windows7). But first you have to check the net to see if you can try upgrading the software of the printer. Please if you've done this let me know what happened next.
Mar 26, 2011 | Epson LQ 300+ Matrix Printer
I am using Epson LX-300+ Matrix Printer. But it is printing very slow on foxpro. Even I am using basic fonts. How to increase the speed of printer.
best way to come out of this problem is to fire your printing using an batch file
set print to scrn.txt
set prin on
? 'hello'
? 'welcome to fast printing'
set prin off
set prin to
run fastprin
create fastprin.bat file
edit fastprin.bat
@echo off
type scrn.txt >PRN
then execute the above program
Feb 25, 2009 | Epson LX-300 Matrix Printer
The printer cant print at all from an accounting program
If it is printing from Windows and other apps then the accounting program (app) is not selecting the printer. I don't know what program you are using but you should have a pop-up when you select print inside the app that will allow you to select the printer you want to use. There is a difference between selecting the print icon in the app and selecting File on the toolbar and then print under file The last method (File-Print) should give you the pop-up to select your printer and other options as well..
Jan 20, 2009 | Epson LX-300 Matrix Printer
you must enter at the set up program of the printer and change paper size,hold the font button and turn on the printer,then folow the setup
Feb 01, 2008 | Epson LX-300 Matrix Printer
Epson lx300+ii with serial port to fujitsu pc
use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Jan 28, 2008 | Epson LX-300+ II Matrix Printer
Paper size problem
hi there, your problem is in page setup. make a custom size and it will print inside your paper sheet. ty
Dec 24, 2007 | Epson LX-300 Matrix Printer
Page Setup
I am unfamiliar with this machine now - it has to be 10 years since I saw one. What sort of setup arrangemt for printing does the program allow- that is a word or spreadsheet in the file menu has a print set up panel - anything like that there. Failing that a an E-mail to Tech support Epson Also look up
May 16, 2007 | Epson LX-300 Matrix Printer
374 people viewed this question
