Question about RCA F32444 32" TV
Guide plus and main menu problems!
When the tv is turned on the guide plus menu comes up or the main menu comes up.When the main menu comes up and you try to move the arrow,it is as you are pressing the enter button and it goes where ever it wants too in the the menu.When the guide plus comes up and you try to get it off,it goes off but comes rite back.The buttons on the set are also inactive most of the time now.Please help!
    Novelist:
    Champion:
  • 236 Answers
One of you control buttons may be stuck. I found this problem once.
Posted on Jan 12, 2007
RCA Home Theater Premiere 36" TV comes on automatically
Only two possible reasons I can think of for this--
ONE: you have looked in the customer menu and there is no item listed as Timer?
TWO: Does THIS SET HAVE THE GUIDE PLUS LOGO ON THE FRONT OF THE SET? IF IT HAS THE GUIDE PLUS--YOU WILL FIND IT IN THE MENU ALSO---
LET me know if it has the guide plus feature and I can tell you how to end the problem--most of these the set will come on at the same odd time and usually with volume up high.
SD TECH
Dec 26, 2009 | RCA P52937 52" Rear Projection Television
Guide plus stopped working on my rca tv
Can you please inform us the brand and model of your unit so we can help you better...
Sep 28, 2008 | Televison & Video
How can I turn off guide plus so it doesn't come on everytime I turn on the TV? I think This is the model#
Hi my name is Eric,
I can help you with your issue ,
Using the original remote enter quide plus menu , under setup tab look for general and set the default to off.
like a little on/off switch it turns off the guide plus
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 06, 2009 | Proscan PS36700 36" TV
How do I remove the guide plus from coming on at power up?
I found the solution!
With the remote, press the Guide button. This should bring up the Guide Plus+ screen. Press the right arrow to move the cursor all the way to set up and it will ask, "What would you like to do?" Arrow down to "Review Options" and press OK.
The first question is, "Guide Plus+ System Auto Display? On / Off"
Arrow down to Off and press OK.
Jan 01, 2009 | GE 32GT740 32" TV
Guide Plus crashing
This problem is possibly a failure on you digital main pcb. Hoping its not hardware, best thing is to try to totally reset the guide plus. Go into the guide plus menu and find the setting to reset or restart setup. If this does not solve you issue, try hard booting the tv (unplug for 2 minutes) and try again. In quite a few cases, the manufacturer of the tv will have a software upgrade that may fix guide plus issues. Contact your manufacturer for that information
Dec 07, 2008 | Televison & Video
Can't get the Guide Plus screen to go away
Try these options
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
May 16, 2008 | RCA F27649 27" TV
RCA TV f27422 TURN OFF THE GUIDE PLUS
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
Jan 17, 2008 | RCA F27442 27" TV
Rca tv f27628
http://sci.tech-archive.net/Archive/sci.electronics.repair/2006-12/msg01203.html
Turn on the TV
using original remote:
Bring up TV Main Menu and select option 7 (TV Guide Plus Menu)
Select option 1 (TV Guide Plus Setup)
Find the MENU, GO BACK and Input button on your remote
Press the MENU Button then immediately:
Press the GO BACK button then immediately:
Press the INPUT button.
Note: It is important to press the Menu, Go Back and Input buttons quickly (within a second of each other)
Nov 11, 2007 | RCA F27628 27" TV
RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select Setup.
Select Options.
Select Off.
Option B:
Select Off.
Option C:
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Oct 27, 2007 | RCA F32450 32" TV
Guide plus flashes on the t.v.. how do you turn it off
you are that clear
but if you are talking about flashes on the t.v then it is due to sparking is taking place in your plug & socket.
if it is ok then there is a sparking in high voltage section in tv which is called fly back section.
good luck.
Oct 17, 2007 | GE 32GT740 32" TV
RCA F32444 32" TV Logo
115 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
