Question about HP OfficeJet 6110 All-In-One InkJet Printer
Installation of HP printer-I/O aborted beacuse of thread exit
The install of the HP 6110 goes well until it always issues an error message "The I/O operation has been aborted because of either a thread exit or an application request". Any ideas about what is causing this? I understand that MS Installer.exe gives out the message.
  • Anonymous Dec 13, 2008
    I have the same era message except that its on my hp DV 1000 while attempting t install my audio driver ....
  • Anonymous May 06, 2009
    I am now getting this on USB for brother printer, apple ipod, and similar error trying to run downloaded software
2 Suggested Answers
SOURCE: the I/0 operation has been aborted because of either a thread eixt or application request.
hp deskjet d2360 free
Posted on Aug 19, 2008
HP 6110 Officejet printer has error message "Check cartridges/missing
are you using refill cartridge, replace the problem cartridge and check for the results, if you are still getting the message then the issue is with the printer hardware, contact the manufacturer for options.
May 26, 2014 | HP OfficeJet 6110 All-In-One InkJet...
I accidentally deleted my hp officejet 6110xi all-in-one. Now I can install it, but it doesn't print. Error message comes up in the box. I am running Vista Home Premium 64 bit. Thank you,
Go into your [Device Manager] Expand the Universal Serial Bus Controllers section and you should see USB Print Support. Double click that and under the Driver tab, click on the [Uninstall] button. After uninstall, power reset the computer. Once powered on, plug the printer back into the computer. This should re-do the installation process properly.
Mar 01, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Need installation cd for my printer
you can download the driver at
www.hp.com
Click on download and select your operating system.
Take care.
Jul 25, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Displaying error message "incompatible print cartridges"
Click here for instructions on resolving this issue.
Reply to this post if that page doesn't help.
I am an HP employee. I do not represent HP on this site.
May 26, 2010 | HP Photosmart C4580 All-in-One - InkJet...
Printer driver installation error ?
log in first with administrator then install
Sep 04, 2009 | Office Equipment & Supplies
Installation failure Error Situation Code 11612095
formet the hdd and install the win xp and after install the HP J4680 driver in pc and ....check
Jul 15, 2009 | HP J4680 Office Jet All-In-One Printer
Printer message is 'remove and check cartridge'. have done that and put in new cartridges but message stays. can print a test page but it will not print anything else
I assume something has happened during a print job and you are seeing this message on the 6110's control panel display. Either there's a "clog" in the flow of ink or an issue with the electrical contacts between the cartridge and the print carriage. Unfortunately, HP.com doesn't list this error message on the web page for 6110 errors.
You can go to the following web page and follow the instructions to clean the electrical contacts I mentioned. The problem you are seeing can also be caused by an incorrectly installed ink cartridge or one where the protective tape strip was not removed before installation.
The latter is likely if you see this error message right after you've put in a new ink cartridge. It's easy to put the cartridge in incorrectly or not to correctly latch it in place. It's also really common to forget to take the tape off before installing the cartridge.
Here's the relevant link:
Cleaning the Print Cartridge
Good luck and post back your results.
Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 Prints very slow then aborts about 1/3rd way through print
I identified this issue with my Officejet 6110xi All-in-One as firmware corruption. Attempting to install the supplied firmware update gave the error that "no hp device connected to the computer would benefit from it at this time." Attempted to power down the printer using #9 keystroke and got "FULL RESET" message, but problem of extremely slow printing and erratic behavior of the print heads persisted. I solved the problem by putting the printer outside in cold weather for two (2) days. This frequently resets firmwares with software corruption back to their embedded EEPROM state. Hooked the printer back up and worked fine. If cold weather is not available you could try other creative methods of cooling the device, just use a plastic bag and with ideally some drying packets thrown in to prevent excessive moisture buildup in the cold environment. The colder it is the faster the firmware resets.
-Paul Ronco, Computer Technician
www.paulronco.com
Oct 29, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
793 people viewed this question
Ben Johnson
