Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
I dropped my camera and now the pictures are funny...
I accidently dropped my camera on a hardwood floor and then I tried to take pictures.. which work but the pictures look not normal.. It's not focused and it has little lines throughout the picture.. plleasssse help
  • Grace Mcnair Apr 25, 2008
    A friend of mine dropped my camera and it sounds exactly like your problem, little lines and looks fuzzy!! Did you manage to get your fixed? I thought I would probably have to buy a new camera, knowing my luck. I have found that if you tap the camera before you take a photo it seems to work properly, not too clever I know.
  • Anonymous Jun 12, 2008
    Hi, I had this problem when my friend dropped my camera, I took it to a shop and it was gonna cost about £85 to fix it, its the shutter... not really worth it for me so I had to buy a new one.
    Caracat
Mine did the same thing and after reading the best answer i decided to drop the camera again and try to unstick the shutter so i just turned my camera on and dropped it about 4 ft on to the floor and it worked just fine also if you look at the lens on the camera you can tell if the shutter is stuck because it should be a circle shape.  This really did work for me even though it sounds crazy
Posted on Jun 12, 2008
    Novelist:
  • 107 Answers
What you describe is the symptom of a stuck shutter. The shutter is inside the lens and must close in order for the image sensor to properly record the image. Yours is stuck open, and that is why you see the lines across your images. When a stuck shutter results from an impact it usually requires full disassembly and manual re-setting of the delicate shutter blades. This problem would require professional repair. Unfortunately damage from an impact is not covered by your factory warranty. You can find good repair services on the internet who can service your camera. David Millier Advance Camera Repair
Posted on Feb 27, 2007
SOURCE:
Which is better between hardwood floor or laminate floor??
I think.. hardwood is much better than laminate wood flooring, but each type of flooring has its advantages and disadvantages. Hopefully this article can help you to choose the floor you want.
Main Differences Between Hardwood And Laminate Flooring
Jul 31, 2015 | Building Materials
I accidently dropped my HP G71-340US notebook laptop approximately 2 feet hitting the hardwood floor. It was closed and hit the front corner. It sill works fine except all pictures have a grainy, swirling...
you have probably damaged the screen itself, try using it connected to an external monitor, if you have a good picture then your screen needs replacing
Apr 09, 2011 | HP Computers & Internet
Wont turn on
It seems as though you broke the camera through the accidental dropping on the floor. I can imagine that your parents may be upset, as it seems you and they are are responsible for the damage. You just need to ask the owner what they would like you to do to make things right. Digital cameras are not expensive these days, and you should be able to get a replacement for less than $150 or so. You should get them another Sony, and pick one with a megapixel rating that is at least as high as the one you broke.
If you are lucky, they may say that it was old anyway, and that they were going to buy another soon. (And not ask you to replace it.)
Jul 27, 2009 | Nikon D70s Digital Camera
Hardwood floor cleaner
Yes, you can use the Bruce hardwood floor cleaner. I've used it many times to clean up after jobs. It brings a nice shine to the floor and is designed for either a hardwood or laminate floor. Hope this helps.
Apr 19, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Floor nailer, 2" nail not going into harwood
sounds like a bent shaft has the driver had any nail stuck or came out the side? whats the presser on?Are you nailing over exiting floor such as v.c.t or other hardwood floor try a couple drops oil in the nailer i' ve been doing floors for over 30 years these are some of the problems i came across hope its helps some what
Dec 23, 2008 | Farberware Manual Hardwood Flooring Nailer...
Can't take Pictures.
your lense gone dead Sangita
Jul 22, 2007 | Nikon COOLPIX S7 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
278 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
