Question about Frigidaire Affinity ATF7000E Front Load Washer
I tried holding down the 2 keys as suggested but it doesnt work
My door wont open on my new washing machine. i tried the suggestion to hold down the options and select key and after several seconds the machine beeps then the spin only cycle lights up and the screen says loc 12 ?????? help- i dont want to get another machine!!!!
  • 2 more comments
  • suztad1014hf Nov 20, 2008
    my washer has a panel that almost surrounds the door, except the top part, which is the control panel. i attempted to take it off put i cant see a way that wouldnt damage the panel. just consider me a total idiot and then try to explain what to do.... that way i might get it. thanks!!!! =^;^=
    since its inside the door im not sure if its atf7000es or atf 6000es
    As you can see, thats what I did in the beginning and the result is that the panel flashes 12 LOC 12 LOC 12 LOC.....
    I ORIGINALLY TRIED THAT, BUT IT DOESN'T HELP. AT THE END IT JUST GOES BACK TO THE DOOK LOCK SIGNAL BLINKING
    Genius:
  • 1,239 Answers
Hi
On many front load washers, the latch engages a switch to activate the timer and other control components. If the latch is not completely engaged or if the switch is faulty, the machine will not operate. Here's how to test and repair a door switch:
Step 1: Latch the door and hold the latch tightly in the closed position. This works best on a unit with a lever-type latch. Then turn the control to the ON position. If the unit works, the problem is probably a misaligned lock unit. Adjust the lock unit with a screwdriver. If this doesn't solve the problem, the switch may be faulty.
Step 2: Test the switch with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Remove the panel covering the door switch and remove one of the electrical lead wires of the switch from its terminals. Clip one probe of the VOM to each switch terminal and shut the dishwasher's door. If the meter reads zero, the switch is working. If the meter reads higher than zero, the switch is faulty and should be replaced.
Step 3: Replace the switch with a new one of the same type. Connect the new switch the same way the old one was connected.
Posted on Nov 20, 2008
  • 10,515 Answers
The solution was that the door latch needed to be replaced.
Apparently u might have tried to force the door open while it was locked. When this happens, it breaks an electronic part of the latch and it stays in locked position.
U can call the technician as they wld solve replace that and it wld be absolutely fine..
If u wish i can send u a manual how to replace latch but i wld advz that a technician wld change that.
Thnx.
  • 4,806 Answers
"The control panel may in *LOCKED* mode.
Press the *OPTIONS* and *SELECT* buttons at the same time and hold for about three seconds to unlock the control panel.
Make sure the detergent tray is fully closed too."
hope this works
    Genius:
  • 1,550 Answers
Switch it off from the main power supply and on again and run another wash (the shortest cycle on your dial) and it should open next time.
Sometimes it just "forgets" to activate the latch.
  • SAM ANDERSON Nov 20, 2008
    A door interlock that will not allow the door to
    open if water is in the machine.
    Make sure the machine is
    drained of water.
    • Door interlock jammed
    • Door catch, handle, or mechanism broken
    You need to call technican to solve this problem .
  • 734 Answers
Please give the model number ..
  • 2 more comments
  • futureloginn
    futureloginn Nov 20, 2008
    Plug off the wall, check to see if any wire has come loose at the door switch. If it is okay it could be a door switch failure, and should be replaced.
  • futureloginn
    Unplug the washer and remove the panel under the door. There are three torx type screws located under the bottom edge of the lower panel. HINT: Propping up the front feet of the washer can make accessing the screws much easier - I use blocks of wood. With the screws removed, the panel should drop down, then come off. Sometimes the panel may stick. A slight tap on the sides can dislodge it.
    Now, reach behind the front panel from the bottom on the side where the door latch is located. Feel for a round tab at the bottom of the door latch and pull straight down. This the manual release for the door. Hopefully, all you had was a glitch that caused the door latch to jam. Try restarting the washer to see if the problem persists.
  • futureloginn
    another try--
    there is a small hole in round acess door, use a pointed tool or instrument of improvision to stick into hole, turn whole access door. once opened(removed) you will see a manual drain . turn the large cap inside cc wise.have plenty of towels ready.once water drains make sure it is clean inside (of lint,or any other foreign objects. reassemble and se if it works.
  • futureloginn
    1 more try--
    The most common type of door interlock is a heater operated delay lock, which is why some machines take a time for the door to release. So make sure you have waited a minimum of 2 minutes before you open these or conclude that they are faulty. This type of interlock cannot be repaired and quite simply have to be broken loose from behind the front cabinet, and replaced. With the power isolated you need to remove the top cover and put your hand down behind the front panel to where the door lock is located (directly behind the hole where the door catch enters the cabinet). The door catch then has to be prised away from the front of the cabinet until the door opens or the interlock breaks.
    Some machines will not let you open the door if the machine has water in it, or the drum is turning, so first make sure the water has been emptied from the drum, then check the mechanism which detects the motion of the drum. This motion detector can be attached to the motor or the drum pulley, and is a mechanically operated lever attached to the door lock by a cable.
    If there is resistance to the cable being shortened then the door will open, however if the cable offers no resistance the door will not open. The mechanism on the motor or drum pulley consist of a lever with a ****** assembly at the end. The lever is pulled towards the belt when you try to open the door. The ****** at the end of the lever is at right angles to the belt and is what provides the resistance to the cable, but if the belt is moving the ****** gets pushed to one side and the cable has a fuller range of movement, hence offers no resistance for the door to open. Sometimes the ****** assembly can break and needs to be replaced, otherwise it is just a matter of adjusting so there is a miniscule gap between it and the belt.
  • 370 Answers
Pull the bottom panel off the bottom of the machine and pull the manual unlock cord. There will also be a tech sheet inside the washer side walls. It will tell you what the code means. let me know and i will tell you what to do. First try unplugging the machine for 10 minutes and let it reset.
  • 1 more comment
  • Justin Duby
    Justin Duby Nov 20, 2008
    Depending on the model and brand it may not have an unlock cord. But try resetting it by unplugging and running through another cycle.
  • Justin Duby
    Find the tech sheet inside the washer and it will tell you how to run a diagnostic cycle. This then will tell you exactly what is wrong. If it will not acces the diagnostic cycle and you are doing everything correctly, The board must be replaced. Have you tried replacing the door lock mechanism?
  • Justin Duby
    Frigidaires are known for the door lock mechanism failing. Also the control boards.
Siemens iq500 washing machine. WD15G460GC PLEASE ASSIST!!! I've seen previous responses where to solve the problem people suggest holding start/reload, however this isn't helping. The key symbol is...
not sure if this was suggested but Siemens suggests unplug the machine, plug it back in and wait a few seconds, then select a cycle. The locked door should release.
Feb 06, 2018 | Siemens Washing Machines
AEG Lavamat washing machine model 76850, shows a blinking key and makes clicks and after that shows E40. Thanks John
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensing circuit faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Aug 02, 2014 | AEG Washing Machines
How do I change the language on my new Hotpoint TCUD93BG, I pressed it by accident and its now unreadable, I tryed to reset it by holding 3 buttons but it doesnt work
Turn on the machine with the door open using the on/off button
Press and hold the childlock,temperature and spin buttons at the same time for approx 5 seconds. The sceen will flash.
Scrollup/down using the temperature or spin buttons until the required language is seen in the display.
Press the child lock button to save the new setting.
Dec 04, 2012 | Washing Machines
Key Symbol appearing and cycle wont start
Please see if there is a lock installed into for safety. Press and hold power/start/pause as power is plugged.
Make sure that the door switch is working open and close once again to check as this can also stop the machine from operating.
Mar 02, 2011 | Bosch Classixx WFL 2066 Front Load Washer
I have a 99 vw jetta and the battery died we disconnected the battery to get a new 1 but he key wont open the door how do i get the door open to reconnect the new battery?
try this,reconnect the new battery and then lock/hold the key over for 30 secs,then unlock/hold the key over for 30 secs,the windows will go down if its trying to reset.then lock/hold over the key again,then press/hold the unlock button on the remote,this will fully reset the cental locking/alarm/immobiliser system.
Jan 09, 2011 | Volkswagen Jetta Cars & Trucks
Keys shift to shift doesnt work gota be stiky keys
hold shift down try and see if turning it on and off will work. If that doesn't work then try opening task manager with alt-ctrl-del then end the possess tree of "Explorer" then wait 2 minutes and then go to application -new task -then type explorer and see if that works...if that doesnt work witch i doubt it wont. try very carefully to pop the keys off that dont work and clean under them.
Aug 23, 2009 | Computers & Internet
Duet HT GHW9300PW4 - The control lock is on
Hold down "end of cycle" button for 3 seconds.
chrisxx
Jun 03, 2009 | Whirlpool GHW9300 Duet Washer
Bosch WFK 2401 Need to slam door several times to lock door
Sounds like you need the electric "door interlock" replaced. It is a simple matter of seperating the front of the machine enough to unplug the interlock mechanism, remove the two screws holding the mechanism in place and remove it from the back, reverse the procedure to install the new "updated" replacement part (- Bosch #170935 btw. about $37.00 from Sears). - time: approx 1/2 hour if you aren't mechanically inclined.
Jan 24, 2009 | Bosch Classixx WFL 2462 Front Load Washer
Renault Megane key will not open doors
work it manually and it should work ...ie put the key in the door and open and lock the door 3 times slowly then jump in and try to start within 15 secs .if it doesnt work then be prepared to be fleeced and lay the golden egg at the dealers
Oct 07, 2008 | 2000 Renault 181
Frigidaire Affinity ATF7000E Front Load Washer Logo
22 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
