Question about Frigidaire FGFB75D Gas Kitchen Range
Covert a frigidaire stove to nat. gas
Model: mgf300pbwd need converted back to nat. gas
  • 370 Answers
Lift the top of the stove up. Then there should be 4 nuts on the backs of the burner controls. Turn them left to open the valves for nat. gas. You want just a small amount of yellow on the flame. Then take the droor out of the oven and there should be another nut close to the gas valve for your oven flow. Do the same to the oven.
Posted on Nov 20, 2008
Can I convert natural gas water heater to propane?
With knowledge of make and model, your manufacturer can supply a retailer who can provide you with proper kit...
info here...
http://www.propane101.com/lpgasapplianceconversions.htm
http://hometips.me/Mar/Convert-water-heater-to%20different-gas.pdf
Sears com
May 06, 2015 | Water Water Heaters
I have a 1920 Garland gas/wood stove that was running on nat gas and I want to convert to propane. Anyone know how this is done
To go from natural gas to propane you need to change the orffice where the gas feed comes out into burner. I the propane orifice feed hole is a different size.
You should be able to get this from a furnace contractor. They did this for me when I went back to natural gas.
Feb 25, 2015 | Garland Kitchen Ranges
Do older garland gas stoves need a conversion kit or can they be adjusted from nat to propane
They must be converted. New burner orifaces for burners, griddle, and oven and a new regulator for the gas valve.
Apr 30, 2014 | Garland Kitchen Ranges
We have a dynna glo zero clearance for Natural Gas
Before you attempt to covert to lp. You need to check the flue. Black smoke is cause by incomplete combustion. So it may be now plug with black soot. Heat-exchanger may be damage Before you invest in a lp kit. Make sure it is worth it. To convert you need the main burner orifices and lp spring for gas value. Once you replace these parts you must adjust gas pressure, nat gas is measured at 3.2 - 3.5wc lp is measured 10.5 - 11.00 wc. In my honest opinion this is to dangerous for customer to attempt. Please a HVAC contractor inspect unit and install lp kit.
Nov 20, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Tappan Range Model TGF351ESJ Nat. Gas to Propane
Yes you can convert the range
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
How do I adjust the flame on my Frigidaire model FGS383BADK stove?
its going to be listed in the installation manual ,not use and care, youre going to need to convert oven for lp gas. i would call the manufacture with the modelk number and ask for hte coorect conversin kit, for such a thing
Nov 03, 2008 | Frigidaire Ovens
Frigidaire gas range makes loud whirring sound when oven is set above 250
You don't give a lot of info here (like if the range was converted from natural to LP, or if the burners are OK, or if it is a self clean model and how the broil works, etc) and I can't guess all that, especially because a lot of people post under whatever model pops up when they enter a key word while posting a problem, but,..........
Any range that was professionally installed should have been tested for proper burner and oven operation by the installer before they left. Call the installer back and let them know you are not satisfied.
Nov 02, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Whirlpool 465 Gas Stove conversion from propane to gas?
In most cases the orifices can be removed and reversed to convert from lp to natural gas. Sometimes you will need a conversion kit and you will need to look this up by model number. 465 is the oven capacity not the model number. You can locate the model number by pulling the drawer out and looking behind it. Please let me know the model and I can let you know what kit you need. Also I should let you know that your gas company is the most qualified to convert your range, and this conversion should not be attempted by anyone who is not qualified. If this conversion is not completed properly you could be risking your life and the lives of everyone in your home, so make sure you know what you are doing!! Or get a qualified person. Good luck and please be careful making any changes to your gas appliances. Please dont forget to rate me also.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Whirlpool SF325 Gas Kitchen Range
Frigidaire FGFB75D Gas Kitchen Range Logo
153 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
