Question about GE Profile JGS968SHSS Gas Kitchen Range
Burners fine but keypad says loc on
SSIA I can't turn on the oven. Keypad states that the "loc" is on. I have tried holding various keys down for 3 seconds and also I have tried to unplug it to 'reset". No luck so far
  • 1 more comment
  • kevin scully Dec 18, 2006
    thanks
  • lockon Dec 13, 2007
    Oven will not turn on. Self-cleaning function still works fine, but when I try bake or broil function, a picture of something appears on keypad (possibly a lock)and says on. It's some kind of lock and I've tried unplugging, pushing broil and bake button at same time, etc.... all to no avail.
  • Anonymous Mar 08, 2008
    I am having the same problem. The range works but unable to turn the oven on. LOC lights up when I hit any button. Tried flipping the circuit breaker but no luck.
    President:
  • 878 Answers
The lockout for this oven is 9 and 0, press and hold the 9 and 0 buttons at the same time for 3 seconds...Catriver..post back.
Posted on Dec 18, 2006
  • nanhug44
    nanhug44 Oct 04, 2015
    WOW,thank you so much ,could not figure it out ...i was getting so upset .i will write this down in case it happens again..had stove 11 yrs..first time it has happened..you are a life saver for sure!!!!!!
The person who gave gthe solution to press "9" and "0"for 3 seconds deserves a commendation. My wife experienced the same problem and got so upset I almost called 911.
Many thanks.
geocon4
Posted on Oct 05, 2008
SOURCE:
When I attempt to enter anything with the keypad the display says "locked". Is there some way to unlock it.
Many microwaves have children locks. Of course they are for safety reasons. they are for tricking the little kids from playing with the big people toys.
Process A
To Turn the Control Lockout Feature On or Off:
  1. Make sure the microwave oven and timer are off.
  2. Press and hold the CANCEL keypad for 3 seconds.
  3. 2 tones will sound and "LOC" or a padlock icon will be displayed (indicating the control is LOCKED).
  4. Repeat to unlock. Again, 2 tones will sound.
Process B
  2. Press and hold the START keypad for 5 seconds.
  3. 2 tones will sound and "L" will be displayed (indicating the control is LOCKED)
Hope this helps?
Jan 12, 2016 | Microwave Ovens
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
The oven is giving error code LOC
amana self cleaning convection oven displays an F9 code.
Sep 06, 2011 | Maytag Kitchen Ranges
Microwave is locked up. Says Lock on screen and cannot get it to go away after hitting Clear several times. How do I get it off "lock" status?
HELLO.
GE manufactures various models of microwaves with a range of features.
Among them is a child safety feature that allows parents to lock the keypad. Though children can still open the door, the keypad lock prevents them from starting the microwave. The lock is in the form of a keypad code that renders the buttons inactive.
* 1 Press and hold the "Clear/Off" button on the microwave's keypad.
* 2 Hold the button down for three seconds.
* 3 Wait for the "L" on the keypad's display to disappear and display the time instead, signifying that the device is no longer locked.
Willing to help solve more problem.
Thanks.
Aug 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have to turm the oven off at the braker box. it comes on by itself. when I turn it on to cook it will not stay on gos off and beeps. Shows C7 or F7
This is usually a keypad stuck key error, usually caused by a bad keypad or sometimes caused by your control board.
F7 usually means a stuck key on the keypad. I've also seen it caused by a greasey buildup on the keypad connector into the control board. Try pressing each button on the keypad followed by cancel. See if the buttons are registering with the control - should get a beep or some function (execpt up/down buttons need a cook or time function enabled first). If one of the buttons seems inoperative it may be stuck, in which case you probably need a new keypad.
Best Regards, Diana
Jun 15, 2010 | GE JKP20 Electric Single Oven
PLATE NOT ROTATING AND THE KEYS NOT FUNCTIONING
If keypad is locked, hold down clear button for 3 seconds to unlock keypad.
May 12, 2010 | GE JVM1542 Microwave Oven
Oven Door panel is showing LOC position but can be opened and closed so not locked. Unable to use oven for cooking
What is the exact make and model of your oven? Unplug the power cord for one hour to reset the display
Mar 18, 2010 | Kitchen Ranges
Driver for PAUK10 keypad with Mac OS 10.2
Hold down the NumLock key for 4 seconds or more and then it should work.
Also try holding down the NumLock key before you connect it.
Nov 25, 2007 | Targus USB Ultra Mini Keypad Keyboard...
Burners don't receive gas though oven/broiler does
tommi, this model has a cooktop lock-out solenoid feature. Try pressing and holding the top light keypad for 5 seconds and see if the top comes back to life. If not, check your owners manual, it may be a different key. The lock-out solenoid is in the back behind the outer panel. The cooktop lockout valve has been redesigned from a AC to DC voltage because of complaints of chattering. The new part number is 8184768. Lets hope you don't need it and just have the top locked out.
Apr 10, 2007 | Kenmore 75844 / 75849 Gas Kitchen Range
Oven
Neal, the only thing I can bring up with that model number is a built in wall oven. You said the top burners work fine, so we are missing something here. Sounds to me like a stuck or shorted keypad. Catriver..post back
Sep 14, 2006 | GE JKP15 Electric Single Oven
GE Profile JGS968SHSS Gas Kitchen Range Logo
502 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
