Question about Kitchen Ranges
F-9 code with lock sign coming on
Maytag gimini oven that displays f-9 and then lock sign appears on control board, model mer6772bas cant use oven
  • 370 Answers
Check for obstruction in door lock mechanism. The celenoid is behind the back panel of the stove.
Posted on Nov 21, 2008
Maytag Oven model MER5755QAQ has lock on the display and the oven will not operate.
If one of the position switches on the latch assembly is not reading, the control will sometimes lock because it "thinks" a clean cycle has been initiated, if replacing the control did not fix the lock icon, test the switch... Incorrect temp probe and thermostat failures can also make a control "think" it is in a clean cycle. Maytag Range Stove Oven Door Lock Motor and Switch Assembly WP74008702 Maytag Range Stove Oven High Limit Thermostat 74008715
Jul 06, 2016 | Maytag Kitchen Ranges
Maytag range model mer6750 - I tried to open the oven door too soon after a self cleaning cycle Now door won't open and fault code F9-2 appeared. What to do? THANK YOU
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
F9 Door Lock Warning Check door lock circuit or Replace Clock
F-2 Oven temperature sensed by electronic control Replace the clock/relay board.
Here is the part you need to order.
May 18, 2013 | Kitchen Ranges
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
Display codes
what kind of oven and model, run this on a computer, just put it in the browser, i can run it for you but need the type, maytag or other ect. Matt
Oct 29, 2017 | Maytag MER6772BAS Gemini Electric Kitchen...
MY OVEN DOOR REMAINS LOCKED AFTER CLEANING. I GET A F1 DISPLAYED. I LEFT IT UNPLUGGED ALL NIGHT AND IT STILL SAYS THE SAME THING AND IS LOCKED. IS THERE ANYTHING I CAN DO?
I could be more specific with a model number from the range.
The F-1 code on most ranges is a bad electronic control board. The oven lock is controlled through this board.
If you replace the board you should be able to open the oven.
You may also have a blown thermal fuse behind the rear panel on the oven as a result of self-cleaning.
Self cleaning is a nice feature but is not recommended by appliance repair technicians.
Sep 04, 2011 | Maytag Microwave Ovens
The F-9 code comes up when we try the oven. We
Hi tessjon,
The F9 fault code is about the door latch, please check the door latch components.
Hope it helps.
Thank you for using FixYa.
Jan 09, 2010 | Maytag MER5775Q Electric Kitchen Range
Range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Readout is stuck on 5Ab. Can't do anything with it
Hi.
I am publishing this tip because of the many users asking me about the code 5AB on Amana, Maytag and other ovens.
Error 5AB in fact does not exist , and what you see written on display isnot 5AB.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Depending on the model, there may also be a beeping sound when you try to operate the oven.
Push and hold the Clock button for about 10 seconds, until the display clears, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
Jul 09, 2009 | Maytag MEW6530D Electric Single Oven
CODE F1-1 STOVE MAYTAG GIMENI/ WHIRLPOOL S/S NO ICE TO ICE BUCKET
Sorry i still have this problem with code f1-1 appears on the screen panel especially when it get warm or hot and still need help. thanks
Aug 08, 2008 | Kitchen Ranges
F9 Code after power outage - Model JGR8855ADS
Generic:
Fault Code Interpretation Components To Check
F-1 Communication error between touch pad and ERC (clock)
Replace the touch pad or clock.
F-3 Open oven sensor or harness. Replace the oven sensor
F-4 Shorted oven sensor or harness Replace the oven sensor
F-5 Power to element relay disabled in cook mode Replace the clock/relay board
F-7 Shorted touch pad key sensed for 32 secs. Replace the touch pad/control panel
F-8 Shorted meat probe Replace the probe jack.
F-9 Door lock safety circuit on ERC sensed Replace the door latch assembly
F-C or F-0 Communication error between boards Replace the relay board
Maytag-Maycop-Magic Chef-Jennair-Admiral: Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
Mar 09, 2008 | Jenn-Air JGR8875QDS Gas Kitchen Range
Kitchen Ranges Logo
124 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
