Question about Hotpoint VBSR3100D Top Load Washer
How does one test the relay?
The washer will spin but not agitate. my guess is the motor start relay located in top panel
  • Hotpoint Master
  • 3,463 Answers
If the washer spins, then it is highly unlikely the relay will be faulty
Posted on Dec 01, 2008
When i start the washing machine it fills up with about 3inches of water then does nothing.it does not spin at all
No agitation or spin? try these:
WATER PRESSURE SWITCH: This switch keeps your washer from overflowing. It is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has been reached. Meter check ur water pressure switch?
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash starts - then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open.
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub)
Remember to check the agitator spline as well for worn broken teeth.
By the way my advice is free cuz God is good!
May 20, 2015 | Washing Machines
Whirlpool sm#8525147-A. After filling with water, why won't it agitate, drain or spin?
May 16, 2015 | Whirlpool Washing Machines
I'm trying to fix my top loader washing machine. Maytag ensignia. It is not agitating the cloths correctly. Like it is not catching. The arm might not be set. Or it is off. Any one with help
MOST LIKELY THE CAM DOGS?
Apr 19, 2015 | Maytag Washing Machines
I have a Smash washer it only runs on rinse how do I fix it?
Apr 15, 2015 | Washing Machines
My roper washing machine is a top load washer around 5 to 10 years old. It will fill with water but won't agitate, rinse or spin. It will drain. It makes a horrible noise during all cycles except when...
Mar 18, 2015 | Roper Washing Machines
My beko wm6111w lights all on but won't spin or wash !
Feb 22, 2015 | Beko Washing Machines
No Agitate / No Spinning
If it is a top load washer I would check the lid switch, you should hear a click everytime you close the lid. If that is ok, there is a coupler between the motor and transmission, if it is a whirlpool, maytag, estate, admiral or kenmore.
Jan 26, 2014 | Washing Machines
Lg front load washer fulls but would not wash
Nov 28, 2012 | LG WM3431 Front Load Washer / Dryer
Washing machines can't wash and spin
Aug 18, 2012 | LG WM Washing Machines
WASHER WON'T SPIN WHAT COULD IT BE MOTOR SOUNDS LIKE IT KICKS ON BUT NOTHING
If your washer doesn't spin but DOES make noise when it SHOULD be spinning, it's most likely the motor coupler. It's located between the motor and the transmission and it takes the place of a belt. If this part is out, your agitator will not agitate either. To test for this problem you can start your washer and use a screw driver to gently press down on the lid switch so that the machine will try to agitate. Do this test with no clothes in the washer so you can see clearly. If it does not agitate you know this is the problem. Hope this helps. Motor coupler is part number 285753A and should cost $15-$25 depending on where you get it.
May 26, 2010 | Estate TAWX700JQ Top Load Washer
Hotpoint VBSR3100D Top Load Washer Logo
66 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
