Question about RCA F35760MB TV
Picture is wider than the screen
You can not see all of the picture in the screen, picture is to wide for the screen. thank you James Ratliff
0 characters
1 Points
Picture is wider than screen
Hi JC,
please google this with tv model number
mitsubishi xxxxxxx tv servise mode code.
go to servise mode and do the adjusment.
good luck.
Jan 27, 2014 | Mitsubishi CS-40505 TV
I have a 20F42OT - is there someway to change the screen so the entire picture shows? for example, if there are sports scores on the bottom of the screen, you can see only top half. Screen should be...
does the remote have a aspect button? or maybe it is in the menu? If not let me know and I'll look it up. I have worked on some of these but dont remember them being wide screen
May 03, 2011 | RCA 20F420T 20" TV
How do I change it from wide screen to regular? I have a black area above and below the picture.
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
How to get the wider screen on all channels sometimes I can only get 3/4 of the picture. I don't have dish or cable. Is it still possible to get a full screen picture?
It depends on the age of your tv. The problem is that some channels are broadcasting in HD 16:9 mode and some are not. It may be that your tv is not capable of showing true HD. Check your owners manual and see what aspect ratios it is capable of. Thanks.
Nov 01, 2009 | Standard (CRT) Televisions
Picture is only in middle of screen, top and bottom of screen is blacked out
If you are watching widescreen format movie or tv programming on a non-widescreen tv, that is how it will appear. The widescreen is a wider picture so to show it on a less wide screen, it has to shrink down to fit. and leave blank space top and botton.
If not, sorry.
Sep 12, 2009 | Toshiba 36A40 36" TV
Picture wider than the screen
hello. can you tell me do you have your manul that came with your tv.? if not that's ok . we can fix it . it's in your tv's menu set up. you need to bring up up on your screen and scrol down to the video setting and there you will need to change the size of it's format. witch will have diffrent setting in size. and they could say setting for STANDARD or THEATER FULL OR WIDE . !!! or it's could have set of number's like your computer use's like 800 by 600 , or 1024 by 768 and you have the ideal what i "am saying.? you need to change this to fix your set. you should set it to standard.!!! in the menu. some set's have a Demonstration mode you can use to to see how your tv work's for setting it up.? so go try what i have told you and get back to me and let me know . ok "GOOD LUCK" and THANK YOU FOR USING FIXYA.COM
Jan 01, 2009 | Philips 32PT6441/37 32" TV
Wide black area top of the screen.
More than likely it's not the crt. If the picture has "foldover" at the top of where the picture is currently, then more than likely there are bad caps. in the vertical scan circuit. If not, the vertical sizing probably just needs to be adjusted. You will have to get in to the service menu to do that.
May 26, 2008 | Philips Magnavox 27MT5405 TV
Mitsubishi CS40509
Opeen the back panel of the tv,
near the coil you would see 6 potentometeres, (small turnng things) one is written vhold and and the other horizontal scroll, adjust these to set the picture,, Be careful nt to eletricute your self..
Jan 10, 2008 | Mitsubishi CS-40509 40" TV
Akai tv picture problems
i want the cercit digram for akai tv ct-t29sa3a
Nov 16, 2007 | Standard (CRT) Televisions
My Picture is wider than the screen
How much wider are we talking about? It is normal for all TV's to be a bit overscanned anyway.
Apr 18, 2007 | Apex Digital GT3215 32" TV
Standard (CRT) Televisions Logo
22 people viewed this question
Top RCA Standard (CRT) Televisions Experts
John mullen
Are you a RCA Standard (CRT) Television Expert? Answer questions, earn points and help others
