Question about Zebra 105SL Thermal Label Printer
After cutting the label the printer pulls media back about 1/2''
Zebra 105sl
I noticed that when printing labels let say 10 2" long after each cut the printer pulls the media back through the cutter then prints.
doing this each time actually pulling it so far back its no longer in the cutter housing.
I was wondering if this is correct and if it could contribute to the labels (media) bypassing the cutter?
esspecially if the heat seal media sticks to the roller?
Thermal-trans print method
    Champion:
  • Zebra Expert
  • 285 Answers
You can adjust the tear off position.
check if need the backfeed and what setting, if you need, you be able to stop doing that (no back feed) but can change the print on the lable.
Posted on Nov 13, 2010
Zebra 105sl printer labels print too small
There are 3 different DPI Printheads for Zebra printers if you print a label set up for a 200 DPI Printhead on a printer with a 300 DPI Printhead installed it will be about 66% of the size.
Feb 13, 2014 | Zebra 105SL Thermal Label Printer
Zebra 105sl - printer does not print correct size
This sounds like a mismatch between the printer settings in the print driver and the label settings in your label design software.
In the printer driver - printer preferences- set the physical label dimentions.
Also set the printing defaults to the same settings.
In you design program ensure your label size is the same as the printer driver and also you can set the print preferences in the same program, ensure they all match and hey presto it works. But if nt then contact www,lancerlabels.co.uk, they will talk you through the problem on the phone. They will not charge for the advice.
Mar 17, 2013 | Zebra 105SL Thermal Label Printer
We have a Zebra 105SL thermal printer. When I print to it with any application, the data light comes on, but it doesn't print. It has ribbon, media, calibrated, no error lights
The data light indicates that the printer is receiving data. Hold the cancel key for 10 seconds while powering on. This will print printer configuration. Use to troubleshoot. If the data or format is wrong it will not print as you send data. Make sure you are using the 105SL printer driver. To test the printer functionality you can go to www.teklynx.com and download a demo copy of labelveiw, select the 105SL printer and try to print a simple label. If you can print with labelveiw then it is not a printer problem. Double check your driver and label format.
Nov 12, 2010 | Zebra 105SL Thermal Label Printer
Zebra 105SL is cutting off bottom line
check the length and the with from the driver, if is the correct with the current label. check the length and the with from the printer setings.
Nov 04, 2010 | Zebra 105SL Thermal Label Printer
The top portion of my print on my zebra 105sl is cut off. How do I adjust so I can see it.
Calibrate media. Double check your label size. Make sure top position parameter is set to 0.
Press cancel key while power on to print configuration.
Oct 12, 2010 | Zebra 105SL Thermal Label Printer
I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this issue?
I am trying to print a label on the zebra 105SL but the font ...
www.fixya.com/support/t5406223-am_trying_print_label_zebra_105sl
Jul 11, 2010 - I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this ...
db:: 4.67::Crystal Report Label Won't Send To Zebra k9
www.hivmr.com/db/k99xad9dfspspddfs1scm9fzxxkdz9dj
My routine can print the label to any other laser printer, but the Zebra. ... I am tryingto find a way to print actual time a smartform label gets printed out on a zebra ... In this i want to changeCross Tab expert Row Label Font,Cross Tab expert ..... And labelpaper too. ..... DB:2.73:Zebra 105sl And Crystal Report Label Issues 1d.
db:: 5.16::Help My printer is printing in 3x5 documents and I ...
www.hivmr.com/db/xkzpajp81937ap7zdf87sdmsxmcm179m
DB:4.06:Printing 3x5 Continuous Feed Labels On Hp Officejet 6100 d8 ... Are they toosmall? ... I want to help you but I am not sure I can be of much help until I know what kind ... If the paper size is 3.5x5 but you are trying to print a 3x5 photo (which seems to be ...... I have a label format issue on a Zebra 105SL label printer.
db:: 4.15::Custom label sizes md - Hivmr
Jul 11, 2010 | Office Equipment & Supplies
Zebra 105SL prints 90 degs to what's on the screen
Print out a Cancel Self Test label:
1. Turn the printer off
2. Press and hold the CANCEL button while you turn the printer on.
If the label that prints out looks normal, you have a config issue in either your printer driver or your label software's page setup.
Mar 04, 2010 | Zebra 105SL Thermal Label Printer
Zebra 105SL Thermal Label Printer Logo
276 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
