Question about Garden
Mountfield sp470 my lawnmower wont start, put a new plug, but still the same, put petrol in ,but not fresh petrol, checked air filter and its covered in oil thanks
  • Anonymous Mar 16, 2014
    went to start after winter and mower wont start so draind old petrol out put in new and still wont start
    i have put new petrol in and it still wont start
  • 37 Answers
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
Posted on Nov 23, 2008
Clarke 2200kw generator will not start Have changed spark plug checked flters put in fresh petrol
are you getting spark , is the on switch on , some people forget to do this
Jan 19, 2015 | Electrical Supplies
Toto lawn mower wont start
Hi, do it have a spark plug
Sep 23, 2012 | Garden
1997 Mountfield 21" Emporer Petrol
check the FUEL plug. when unscrewing the fuel bowl it is the nut holding the bowl on. It sounds like it may be clogged
Jul 17, 2011 | Garden
I am looking for a Mountfield HP 470 Lawnmower instruction manual
I have a Mountfield HP 470 Petrol Mower 8 years old and I have started it the for the first time and it runs but seems to be hunting or missing as I cut the lawn.
Mar 24, 2011 | Garden
Draper petrol lawnmower wont start
Check the fuel...most often stale fuel creates havoc...YOU MUST FLUSH THE TANK donot add to old crumby gas, YOU MUST clean out the carb(remove the fuel bowl and carb spray all the tiny openings,orifices, check the air filter, check the oil, Add NEW fresh fuel, and hit with a quick spray of starting fluid just prior to restarting...should run out well.
Jul 24, 2010 | Garden
Running problems with Mountfield HP454 petrol lawnmower
First thing to check is the air filter. It may be plugged.
May 28, 2010 | Mtd 22" Yard Machine Push Mower
Brand new Pope Spitfire 40 lawnmower won't start
Caren,
Drain the fuel completely if it is older than 1 week. Make sure you undo the bolt at the bottom of the fuel bowl to ensure all old fuel is drained. Refill with fresh fuel (premium unleaded) and try again. If it still does not work then remove the spark plug and rest it on the metal of the mower while still attached to the silicone ignition wire. Have someone hold the cut out bar to the handle (as you normally would to run the motor) and pull the cord. You should see sparks being emitted from the spark plug. (Make sure there is no fuel nearby) If you cannot see any sparks then replace the spark plug with a new one and repeat this process. If you still cannot see any sparks being emitted after attatching the new plug to the silicone wire, resting it on the metal of the mower, and pulling the cord to start it as you normally would, the mower will need to have the resistor and capacitor checked by a professional repairer as no spark is being generated.
Good luck.
Allan
Jun 06, 2009 | Garden
What fuel do use in the mountfield HP470 petrol lawnmower is it a 2stroke mix?
No. This is a 4 stroke engine and it uses regular gasoline, not a mix.
May 06, 2009 | Garden
Garden Logo
2,249 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
