Question about Sony CDX-M8800 CD Player
Sony CDX M8800 Front Panel Problem
Whenever the front panel is opened, there is no illumination and no functions can be operated. When the front panel is closed using the remote the display does not work. You can get the display to work if you press the reset button but it fails again once you open and close the front panel. In addition the CD will not eject the CD, however this may not be related.
  • Booyow Mar 11, 2008
    When panel is closed graphics and illumination works, but when panel is open it does not light up and buttons do not work. I tried the reset button and it worked the first time but when I opened the panel again it went back to the same thing. You also cant put a cd in or take one out.
U need 2 replace the ribbon that goes to the panel to the unit.i had the same problem with mine then i went on to ebay and found the ribbon there (cdx-m8800 repair kit)hope this helps
Posted on Dec 28, 2006
    Problem Solver:
  • 4 Answers
Ribbon cable needs replacing ive done it many times i have the instructions in colour very easy for £4.99 posted to you
Posted on Jan 15, 2008
Does this fix require any soldering?
Posted on Jun 06, 2008
The front panel dont come on or no power at all do u thing that the dash receiver not good
Posted on Apr 25, 2008
I done open stereo surgery and discoverd that when face panel opens i saw a nightmare that most of us out ther who once owned a motarola flipp hand set would of remembered the same thing happening? and guess what these stereo`s have the same truble . yes you guessed it that flexible pcb which is connected between the face and the unit is splitting on the face end of the head unit . i promis that is the cause get the magnyfier out. 3am im off to bed
Posted on Jan 21, 2008
I am having exactly thee same problem!! None of the buttons on the base unit light up/work and when the cd player is closed it's just a dark screen. I cannot eject the cd that's in the cd player either. The remote seems to work fine. I have tried just about everything including changing the fuses and nothing seems to have worked at all.
Posted on Dec 26, 2006
What will cause a sunroof not to close properly on a 2007 Milan
A lot of thing's , has sensors , switches , a control module , relay's etc....
The roof opening panel is an electronically operated panel that can be opened or closed by pressing a switch located on the overhead console. It also has one-touch open, one-touch close, one-touch vent open and one-touch vent close features.
Roof Opening Panel The roof opening panel assembly uses an integrated motor and module to operate the roof opening panel. The roof opening panel motor and module are installed new as an assembly. The roof opening panel is an electronically operated glass panel that can be opened, closed or tilted by the roof opening panel switch. Actuating the switch in either a forward or rearward motion supplies a ground to the roof opening panel motor/module. The roof opening panel has one-touch open and one-touch close features that are activated when the switch is momentarily pressed to the double detent OPEN or CLOSE position. These functions are controlled by the roof opening panel motor/module.
The roof opening panel motor must be initialized whenever the roof opening panel motor has been removed from the roof opening panel system, the roof opening panel assembly has been removed from the vehicle, a new roof opening panel motor has been installed or a new roof opening panel assembly has been installed.
Plus the mechnical parts of it .
Visual Inspection Chart Mechanical Electrical
  • Roof opening panel
  • Roof opening panel frame
  • Roof opening panel drain hoses
  • Roof opening panel lifter assemblies
  • Roof opening panel trough
  • Roof opening panel air deflector assembly
  • Roof opening panel seal
  • Roof opening panel shield
  • Battery junction box (BJB) fuse 33 (20A)
  • Smart junction box (SJB) fuse 12 (7.5A)
  • Circuitry
  • Accessory delay relay
  • Roof opening panel motor and module assembly
  • Roof opening panel switch
Mar 20, 2017 | 2007 Mercury Milan
Why does the power window button blink on and off and the automatic feature doesn't work in the 2008 Toyota Sienna?
NOTE:
Anytime the batteryterminal has been disconnected, please initialize the driver's door power windowand front passenger's door power windowafter reconnecting the batteryterminal.
With ignition switchin the "ON" position, do the following:
1. Push down and hold the driver's door power windowswitch to completely open the window.
2. Pull and hold up the driver's door power windowswitch until the window closes.
Continue holding the switch for approximately one second until the switch changes from blinking to a constant illumination.
3. Check for proper operation of the "one-touch open and close" function by fully pushing the switch briefly to the "DOWN" and "UP" positions.
At this time the power window switchfor the passenger's door windowshould be blinking.
4. Push down and hold the passenger's door power windowswitch to completely open the window.
5. Pull and hold up the passenger's door power windowswitch until the window closes.
6. Check for proper operation of the "one-touch open and close" function by fully pushing the switch briefly to the "DOWN" and "UP" positions.
Feb 09, 2016 | Toyota Cars & Trucks
2002 ford expedition interior lights are not on what fuse is it?
Courtesy Lamps - central junction box. fuse # F1.21 that goes to interior lamp relay in the instrument cluster and F.24 this fuse powers battery saver relay .
Interior Lighting The interior light system consists of the following:
  • front map lamp assembly
  • front door courtesy lamp
  • generic electronic module (GEM)
  • glove box lamp assembly
  • central security module
  • interior lamp switch
  • interior lamp relay
  • illuminated vanity mirrors (Navigator only)
  • reading lamp assembly
  • rear courtesy lamp
  • running board lamp
  • underhood lamp assembly
  • The generic electronic module (GEM) illuminates the interior lamps when an unlock signal is received from the remote anti-theft personality central security module. The illuminated entry feature will be canceled when any of the following conditions are met:
    • 25 seconds have elapsed since the illuminated entry feature was activated and the interior lamp control is not activated (door ajar or courtesy lamp switch on).
    • The GEM receives a request from the central security module (remote transmitter lock button pressed) and the interior lamp control is not activated.
    • The ignition is in the RUN or START position and the interior lamp control is not activated.
    The GEM will illuminate the interior lamps when any door is open or ajar. The interior lamps are; the dome lamp, the rear cargo lamp, the door courtesy lamp and the side rail lamps. The courtesy lamps will shut off when the doors are closed and the illuminated entry feature is not active or when the vehicle speed is greater than 5 mph (8 km/h). The interior lamps will not be reactivated until the vehicle speed is less than 3 mph (5 km/h) and a new door open warning lamp switch is received.
    The GEM controls the interior lamps illuminated entry function by activating the interior lamp relay.
  • You have an electronic control module and relays involved in the operation of these lights also !
  • What
    Jan 08, 2015 | 2002 Ford Expedition
    Why door is opening without being activated by remote opener or inside garage opener;something is activating the open/close command;ther is nobody around or a neighbour that may interfere with his doo
    I had a similar problem. I discovered the illuminated door bell switch I used as the inside door control would activate whenever the wall on which it was mounted had a heavy vibration from door slamming or thunder. Could this be your problem too?
    Nov 10, 2014 | Building Materials
    The license plate new bulbs fail to illuminate an the lift gate locks whenever closed...why?
    This answer comes from BlazerForum.com (link is below) for a 2002 Trailblazer:
    "It will be a 10a fuse in the under hood fuse box, labeled TRL PRK. If you have towed a trailer lately, and the fuse does not blow when you replace it, I would check the trailer that you used. If you have not towed a trailer, I would check the trailer wiring under the LR or the truck, to make sure none of that is shorting out. Good luck, Korey."
    http://blazerforum.com/forum/audio-video-electronics-8/license-plate-lights-out-9102/
    Oct 12, 2014 | 2003 Chevrolet TrailBlazer
    How to get unit to play without remote
    You can probably use the front panel buttons (STOP PLAY OPEN/CLOSE etc) manually, the only thing you cannot do without the remote is access certain DVD menus, including subtitles/language/special features etc. You can always obtain and use a universal remote for basic menu functions later on if necessary.
    To play a DVD movie without the remote, simply load your preferred disc, wait for the player to finish reading its contents, then to skip copyright warnings and/or the 'play movie' menu screen, press STOP, then PLAY, or simply press PLAY button where 'play movie' (or whatever function) is highlighted in the menu. These buttons should be on the front of the main unit. Doing this should encourage the player to detect the appropriate title (the movie) and play it (basic playback operation may not be possible with some DVD releases due to the numerous interactive menus and title pages, such as film trailers).
    If basic manual operation is not completely possible with some DVD titles, consider a universal remote for your player if you have either lost your original, or the player was purchased/received without one. Such remotes are relatively inexpensive to purchase, and are available just about everywhere.
    Apr 22, 2011 | Panasonic Televison & Video
    I have a sharp 52". the remote will adjust the volume but, i can't change the channel. Help? Out of nowhere I could no longer change the channel. The Mrs is getting tired of standing next to the tv so I...
    Sometimes, if certain remote control keys are used over and over again the rubber on the bottom of the buttons wears off onto the inside contacts, breaking the electrical connection. This is common on power and channel keys, especially. If you can get the remote opened up, you can clean the contacts with a cloth and it might help. Otherwise, it may be worth buying a universal remote. Good luck! Der Strom
    Apr 05, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
    Door lights will not go out.
    Spray a lot of WD-40 or Blaster in the latches on the inside rear of each door. Most likely the drivers door is the issue because it sees the most use. There is a switch on the interior side of the latch that gets stuck. If that does not work, it is possible the GEM module has failed. I believe I have a couple of these if you need one, but usually the switch sticks open (on or depressed and it's normally closed) on the driver door.
    Illuminated Entry Illuminated entry is included as a function of the generic electronic module (GEM). The illuminated entry system may be activated in the following three ways:
    • Raise the outside door handle (22404).
    • Press a code button on the keyless entry keypad (14A626).
    • Press the UNLOCK button on the keyless entry remote transmitter (15K601).
    Electrical flow through the system is as follows:
    • An interior lamp switch (13752) mounted on the front door latch (21812) closes, completing the circuit of the GEM. This switches the system ON.
    • This illumination will remain on for approximately 25 seconds and then automatically turn OFF.
    • During this 25 second period, the system can be deactivated by turning the ignition switch (11572) to RUN position, locking the doors with the keyless entry remote transmitter or keyless entry keypad or by battery saver time out.
    • The system will turn on every time the outside door handles are operated.
    • Opening the front doors (20124) or rear doors (24630) from the inside of the vehicle will not turn on the system.
    • If the outside door handle is held up so that the interior lamp switch is continuously closed, the system will operate as normal and turn off after 25 seconds.
    • If the door handle is still in the raised position, the system will remain off and it will be impossible to activate the system from the other front door handle until the raised door handle is returned to its normal position.
    • This is built into the logic circuitry of the system to prevent battery discharge should the outside door handle be propped up or become jammed in any way.
    The system consists of:
    • generic electronic module (GEM).
    • interior lamp switch.
    • wiring harness.
    The GEM is mounted directly to the fuse junction panel (14A067) The interior lamp switch is retained to the front door latch by a keyed slot and is twisted into position.
    Jan 08, 2010 | 1996 Ford Taurus
    Sony CDX-M8800 CD Player Logo
    1,560 people viewed this question
    Top Sony Car Audio & Video Experts
    xxxxxx xxx
    Mike Duncan
    Mike Duncan
    Marvin
    Marvin
    Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
