Question about Kitchen Ranges
I have a black stove which has slight scratches on the edge. Is there a way of removing or reducing the appearance of the scratches?
  • 370 Answers
Go to your local parts store and see if they have black brush on paint for appliances. This will color the chip/scratches and make them less noticable.
Posted on Nov 20, 2008
Can the cooktop surface of my Kenmore gas range model 790.72903011 be removed
Most stove tops are removable for that very purpose.... after you remove the burners and the grills above the burners.... look for an edge and inch or inch and a half below the top... get something strong like a large screwdriver and place cloth over the tip to prevent scratching the stove top. there are VERY STRONG CLIPS holding the stove top to the stove, pry upward until the clips release. then slowly remove the spark igniter (TAKE A PICTURE WITH YOUR CELL TO REMEMBER HOW PUT BACK TOGETHER)
Jul 30, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have black swirl scratches from using abrasive sponge on front of black oven door
There is this white stuff sold for glass-top stoves. I presume it is good old iron cleaner, a very mild cleaner/polish. Also consider toothpaste.
Dec 01, 2013 | Amana 30" Self Cleaning Electric Range...
Fix scratches on stainless steel appliance
The professionals in order to remove the scratches from st. steel they use special metal wire meshes like soft scotch bride attached on special rotary milling machine. They brush it in the direction of the grooves on the st. steel surface. They start with a hard brush and they reduce the strength until they finalise it as the original finish. If it a brush surface this is more easy than a polished mirror surface. These procedure need experience and care so you will not end up with more damage than the original one.
Dec 29, 2012 | Electrolux 30" Electric Hybrid...
I have a GE Gas Stove & we bought a steel and black. Scratches show on the stove top. What products will help me. I do not want scratch the stove top. But is still gets scratch. Prob Any...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Frigidaire 30" Self-Cleaning Slide-In Gas...
WHEN PRINTING FROM CS3 ILLUSTRATOR DIRECTLY TO OUR EPSON 4800, OUR EDGES SEEM TO BE SLIGHTLY JAGGED, AND NOT SHARP LIKE IT USED TO BE WITH FAST FILMS - ANY FIX?
Try reducing the amount of ink coverage. For instance, instead of using Rich Black (60/60/60/100) try using True Black (0/0/0/100).
Have you changed print materials lately? The amount of ink coverage could be causing the edges of your material to roll up and prevent the the ink from being sprayed properly.
Nov 10, 2010 | Epson Stylus Pro 4800 InkJet Printer
Scratched ceramic hob - how can they be removed/reduced in appearance
they can be polished out with a metal polish like brasso use a drill with a polishing pad but stick some card to the pad as card is slightly abrasive and will remove or reduce scratches
Feb 25, 2010 | Rangemaster Range Cookers Kitchener 110...
I have scratches on the edge of the oven in front
Use 3m Scotch brite #7447 or 220 grit sand paper depending on the severity of scratch. Always finish any sanding by blending with the #7447 pad. Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Jan 27, 2010 | Thermador PSC364GDZS Gas Cooktop
How do you remove scratches on a black flattop stove?
Homedepot has scratch repair kits, they work half the time but its cheap and worth it if the scratches are bothering you.
Nov 06, 2009 | Washing Machines
I have a Tappan gas stove. Don't know how old the stove is as the stove was in the home when I purchased it. Six years ago we had a power outage. When the power was restored the clock started beeping. Only...
Try disconnecting the AC to your range and leaving it overnight. If this doesn't help, the clock has probably been damaged by a power surge during one of the dropouts.
Oct 25, 2009 | Kitchen Ranges
Kitchen Ranges Logo
121 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
