Question about Pelco DX1000
DX 1000, popping sounds and no camera picture
Cannot access any video from cameras, popping sounds (capacitors?) Do they make replacement boards for the power side?
    Scholar:
  • 64 Answers
Yes contact service repair at 1-800-289-9100
Posted on Oct 22, 2009
How to repair a tv LG plasma 60pv250
Sounds like your Power supply is still good. but maybe the board for the video is bad.. (maybe the main board other than power supply. If you do a search on the internet for "60pv250" and "board". you can find replacement parts. If you are capable or know someone with some electronics skills you should be able to see if any parts on the existing boards are popped (sounds like a capacitor went) and then buy the right board
Feb 03, 2016 | LG Televison & Video
Why is flash is making a popping sound
A popping sound is indicative of an electrical arc over. A capacitor is the probable source. Although you camera runs on 6 volts, the electronic flash fires at a much higher voltage. Circuitry in you camera boosts the voltage and capacitors often are used to double that voltage. Capacitors do not last forever. Your problem is that the L110's is an older and not a high value camera. It may be more expensive to have repaired then a new replacement will cost. If you know electronics and camera mechanisms you could take a crack at fixing it yourself, but the chance of your success is probably low.
Jun 19, 2014 | Nikon Coolpix L110 Digital Camera
Picture but no sound
the loud pop was a capacitor or a resistor popping, it will need replacing.
Jun 19, 2017 | Vizio JV50P 50 in. Plasma TV
How to replace the capacitor in kodak easyshare z981
flow two numbers. 1. what's volt -( 6.3v upto use 16v )
2.what's capacity - ( .22uf/ Mfd upto 1000 uf /Mfd have above big uf /mfd.
mach two number.
May 30, 2012 | Kodak EasyShare Z981 Digital Camera
Kodak DX 6490.Am having trouble with the 'shooting' button. It's working very slowly- resulting in camera shake as I have to press so hard, to make it work. What could be the problem-dirt?
Hello, The switch on the upper circuit board is worn and not making a direct contact. The only cure is replacing the board. I have these in stock for the DX6490 if you feel creative ? The camera body needs to be separated to gain access to the board, pretty expensive repair at camera shop.
Best Regards, Russell hounddogellie@gmail.com
Aug 13, 2010 | Kodak EasyShare DX6490 Digital Camera
Was taking a video. Finished it and then went to
Doesn't sound promising at all. The only thing I know of that could "pop" is the flash capacitor, but it would have to be shorting someway. Time for a new one, most likely. Olympus has 12.1 mp cameras for $69 on sale, can't repair one for that!
Mar 13, 2010 | Olympus FE-170 Digital Camera
Our sanyo dp42746 went black made a pop sound and would not turn back on no power light or nothing
Most likely a power supply board went bad. the pop sound is bad capacitor on the board. Most bad capacitors will look like this: 18976c2.jpg
The other picture below shows a normal capacitor in the middle, but two bad capacitors on the sides of it. One with the dome top and one leaking. 5d53c3a.jpg
You can try repairing the board by replacing the capacitors or replace the whole power supply board. Most replacement boards can be found at a good price at Shopjimmy.com or Ebay.
Dec 29, 2009 | Sanyo DP42746 42 in. Plasma Television
Will not focus and the "push reset button" message pops up then powers the camera down. Needless to asy pushing the reset button makes no difference. Is this worth repairing?patyson
Sounds like one of the capacitors on the electronic circuit board is defective. Power is not getting to the auto focus motor. Was the camera dropped recently or placed in a wet/moisture-rich environment? Try taking the battery out and leaving the camera in the open, exposed to light and flowing air for a day. If it is a board problem, the cam will need to be opened and the board tested and certain parts replaced....an expensive proposition. Cam replacement will be a much cheaper solution. Check ebay or craigslist for a cheap replacement. Good luck....
Jun 12, 2009 | Panasonic NV-GS150 Mini DV Digital...
RAZR Camera Not Working
simply return to tmob for a replacement unit. 15% of motorolas are Dead on Arrival (have issues).You have the guarantee on the phone ...
dont' pay anything to exchange it
Jan 23, 2008 | Motorola Mobility RAZR V3
Pelco DX1000 Logo
134 people viewed this question
Top Pelco Televison & Video Experts
Are you a Pelco Televison and Video Expert? Answer questions, earn points and help others
