Question about Acer Aspire 5100 Notebook
Acer aspire 1 internet connection
I disconnected the pwr supply and the unit shut down even though battery was 100% charged. re connected and now I can not for some reason gain access to internet nor can I open the network centre icon in settings. The wireless internet indication light is on but the internet icon on the menu bar is not visable. This is a Linux system
  • Anonymous Dec 21, 2008
    same problem as well did you solve the problem ????
  • 162 Answers
Os malfunction, reload.
Posted on Nov 22, 2008
Acer aspire 4743 not charging but all Okay.....
The solution to your problem lies in one of the following three areas:
1.) Your acer aspire 4743 charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
Feb 18, 2013 | Acer Pwr Ac Adapter For Aspire As 5349...
Hi It is connected to the internet, but just shows homepage. If I disconnect the battery, the computer goes off, no longer how long it has been charging, even though it says it is fully...
First you need to check if there is some thing wrong with the Acer Aspire one battery or Acer Aspire one charger from your description, it seems there is nothing with the charger, if your battery had been used about 2 years you can replace it for a new one
Aug 15, 2011 | Acer Aspire One PC Notebook
I own an Acer Aspire 5810-TZ. The battery seems to be 100% charged but if I unplug de ac cable, the computer shuts down.
Battery is expired. Get new one or get yours rebuilt (about half the price and the cells are better than new) They are on the internet, look up Laptop battery refurbishing. Or outside chance that the charging circuit in the laptop is bad.
Oct 19, 2010 | Acer Computers & Internet
My computer is randomly shutting down. Sometimes it will work and other times it will not. I think the processor is overheating and causing it to unexpectedly shut down. the screen goes black, the power...
Few reason for the shut down
Could be heat, electrical,
1. try cleaning all vents with compress air in order to remore dust and fuzz that can be cloging the vents.
Once this done, verify that fans works proprelly,(check air flow coming out of vents) if they dont they will need to be replace or cleaned out.
2. Check power supply unit, and battery.
Sometime power supply unit is defective, getting too hot and power output is not stable and shuts down the laptop. ( change power supply unit) check if battery hold charge. if not change battery
3. Check connections for looseness and contact
If all seems normal,and none of the mentionned point seem to be defective, the cause is deeper and would need to be looked at by a technician.
Sep 29, 2010 | Acer Aspire 7520-5185 Laptop
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
Power supply connector on the on board broke off
Well it depends on how much damage is/has been done. I often fix damage such as this. You can often effect a repair by bridging the broken PCB by soldering, wire bridges over them, sometimes I have even totally removed broken pwr socket and soldered the power wires directly into place, if a new socket can't be obtained. Make sure you trace out whats what though first draw it out. Remember sometimes, there is sort of a switch in the pwr socket that cuts battery in & out. So, as long as you can get a Positive connection & then any earth connection will do for the Minus. Then it should work... Be Careful.
Jan 30, 2010 | Acer Aspire 5500 5570-2609 Laptop
My aspire one d-250 battery doent charge
My problem was: Although the Batt Light shows the "charging" the desktop indicators show the battery is at 100%. If you dscinnect the power supply the computer dies.
SOLUTION: I found this worked on both occasion it happened to me occasions.
1. Shut down the netbook.
2. Remove battery for +- 15 min.
3. Replace battery.
4. Do not switch on netbook, ie boot up, until charge light goes to green ie indicates fully charged.
Dec 28, 2009 | Acer Aspire One PC Notebook
Battery fully charged but still shutting down when disconnected from mains
Find another battery it says like the one you have is faulty. If you try another known good battery and that fails just like yours then try a know good ac adaptor. If that fails, then its a problem with the motherboard not charging batteries properly but it really does sound like a faulty battery from my experience.
May 08, 2009 | Acer Aspire One PC Notebook
Computer shuts off
Maybe it's your power supply, I suggest you get a voltmeter and check the voltage on the power supply.
Good luck
Nov 07, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 5100 Notebook Logo
102 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
