Question about Panasonic PanaFax UF-8000 Laser Fax
I need to enable the journal print feature
I need the manual steps for enabling the journal print feature, so a xmission journal prints after each fax
    Genius:
  • 2,120 Answers
Press:
Function
74
set
12
set
set
stop
Posted on Nov 20, 2008
How to print electric journal for sams4 ER-265
On the 265 you will need to enable this feature first in the program flag setup. Once enabled, print journal by turning key to X and pressing 300 CASH. Then to clear the electronic journal, turn key to Z and press 399 CASH
Mar 15, 2014 | Sharp XE-A402 Electronic Cash Register
Need to know how to do two-sided copies
Will depend on what type of printer you are using.
If you are using photo paper the back side will not accept ink. You will have to use a paper that accepts ink on both side.
These are the steps to use if you are printing from Acrobat.
Options such as duplex printing and stapling are controlled by the printer, not by Acrobat. The information for such options is stored in the printer driver and PostScript Printer Description (PPD) file associated with a particular printer. If your print driver supports these features and you are using Windows, you must also make sure the features are enabled.
To enable duplex printing and/or stapling:
  1. Choose Start > Printers And Faxes.
  2. Right-click your printer and choose Printing Preferences.
  3. Click Advanced.
  4. Expand Document Options > Printer Features.
  5. Select the desired options and then choose On from the drop-down menu.
  6. Click OK, and then click OK again to exit the dialog box.
To print duplex on Windows:
  1. Choose File > Print.
  2. Click Properties.
  3. Click the Layout tab.
  4. Make a selection from the Print On Both Sides pane.
  5. Click OK, and then click OK again to print.
Nov 26, 2009 | Office Equipment & Supplies
It rings but wont pickup unless you pickup handset and press start fax
Your machine has the Easy Receive function. Although it's enabled, there's another setting the turns the feature ON, OFF, SEMI. To set the machine to automatically accept/print ALL faxes, do the following:
  1. Press Menu, 2, 1, 3. you will see 3.Easy Receive in the window
  2. Use the <--> keys to change from OFF to either ON or SEMI (in your case you want the feature fully enabled so change it to ON)
  3. Press Stop/Exit.
Your machine should now accept and print faxes automatically.
Oct 27, 2009 | Brother IntelliFAX 4100 Laser Fax
I am still unable to receive faxes that are printed automatically when they arrive. they mst be going to memory and i cannot get them to print out of memory. can yo please help me. i paid for this service...
If you are getting a low ink message no you will not be able to fax until this is resolved. Once you replace the ink cart. then you can get to the steps where you can clear the fax memory until then the steps that we would give you will not work.
You can visit www.canon.com click on your printer model then on support and you can download the manual in this manual there will be step by step instructions on how to clear the memory on the fax. this can also be cleard once you print them keep that in mind. so first purchse ink then your going to print your faxes by hitting that button twice the reason why it will not work now is because your low on ink.
If you like this solution please hit accept.
Thanks
Jul 17, 2009 | Canon MX310 Office All-In-One Printer
Need to print out a transaction sheet from a fax
It may be too late. Try
Function
61
set
select print journal
Usually only the last 50 transactions are printed out.
Jul 16, 2009 | Office Equipment & Supplies
How do you turn off the in use/memory light?
This of course depends on why the light is on! If you had a fax come in and it is in memory, you will need to print the fax and clear the memory before the light will go out. The LCD Display should be telling you why that light is on.
1. There is a fax or print job in memory waiting to be printed.--> See steps below
2. There is a paper jam --> Open printer - Remove all paper - Close printer - press OK button
3. You are out of ink or the cartridges are low. - Change Cartridges
Solution: Printing reports and lists MX310
The table below shows the reports and lists that can be printed from your machine.
Report or List Description ACTIVITY REPORT Shows recent facsimile transactions performed by your machine. You can enable or disable automatic printing of this report after every 20 transactions. You can also manually set the machine to print it. CODED SPEED DIAL
LIST
Lists the destination numbers and names registered for coded dial speed dialing. USER'S DATA LIST Lists the current settings of your machine and the registered sender information. MEMORY LIST Lists the documents currently stored in the machine's memory. TX (Transmission)
REPORT
Prints after transmission of a document.
You can enable or disable this feature, or set the machine to print a report only when an error occurs.
You can also set the machine to print the first page of the document under the transmission report to remind you of the contents of the document.
RX (Reception)
REPORT
Prints after reception of a document.
To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
Mar 24, 2009 | Canon PIXMA MX310 All-In-One Printer
How can i get a fax from memory.
Printing reports and lists The table below shows the reports and lists that can be printed from your machine.
LIST
REPORT
RX (Reception)
REPORT
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these
instructions to enable fax confirmation before sending any faxes. Select either On
Fax Send or Send & Receive.
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send &
Receive
Prints a fax confirmation report for every fax you send and
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Can't print e-mails
go to start>>program>>printer and Faxes.
right click on the printer, select porperties.
select printing Preferences, Orientation is portrait, Page Order is Front to back.
click on advance. maek sure all underlined feature are enabled.
check the box labelled as "Enable advanced printing features" click OK
click on Print test page.
Nov 11, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Panasonic PanaFax UF-8000 Laser Fax Logo
313 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
