Question about E-Machines T1090 PC Desktop
Cd/dvd rom my cd/dvd rom does not work i opened the computer and saw that the "cable" conecting it was ripped in places. is this the problem i have an emachine t1090 that i am trying to get running so my son can play games on it. windows xp. also there is another "cable" in there that one end is not attached to. it says motherboard and slave on it. can i use that one
    Scholar:
  • 78 Answers
Computers typically have 2 IDE connections on the motherboard. 1 Primary, and one secondary.
Your HDD ( Hard Disk Drive) should be connected to the primary as MASTER.
Typically the CD is connected to the secondary, as MASTER
You can connect the CD to the second fitting of the primary, however you will have to set the drive as a SLAVE.. not MASTER.
I can't comment on the "ripped" cable, except that some older computer cables split the cable, and reversed the crimp to designate the A & B FDD ( Floppy Disk Diives ).
If you neet additional info, please post additional comment.
Regards,
Posted on Nov 20, 2008
    Sergeant:
  • 237 Answers
No, you cannot use that cable--it is solely for the harddrive, and should not be able to connect the cd/dvd rom. That is for another harddrive in case you decide to upgrade.
You will need to get another cable for the cd/dvd rom---if you do not know how to install and/or change the ribbon/cable, then go to an expert, such as GeekSquad to take care of it for you. You may even know a neighbor or friend who is a computer technician. Good luck!
Cdvd rom dont work on emachine, will a usb 2.0 external dvd rom drive work
If it is USB CD_Drive you can plug it in a USB port of the computer. You may have to install drivers, but usually Windows Update can download them from the Internet.
Apr 07, 2013 | E-Machines emachines (emachinees) CD-ROM...
MY EMACHINE T3306 is saying cd/dvd isnt present in my system. Im trying install windows vista. need help!!!!!
This could be due to a missing or corrupt driver. To verify (assuming you are using XP), right click "My Computer" select "Manage". On the left-hand side of the window, select "Device Manager". Check tosee if your installed device or any device for that matter is located under the heading CD/DVD drives. If there are no entries and you do have a CD/DVD drive installed on the computer, try restarting to see if it will reinstall the device. If this does not work, the drive may not be connected or is bad. Turn off the computer, open the computer and you will see a ribbon cable coming out of the back of the drive. Verify that this cable is plugged into both the drive and motherboard securely (the slots will look like long, slim rectangular boxes with tiny metal rods standing up inside of them). If the drive is securely connected and the machine does not see the device when turned on, the drive is probably bad. If the device manager does have an entry for the drive and there is a question mark next to it, this means the driver for the drive is missing or corrupt. I have checked the emachines website and they do not have drivers for CD/DVD drive for your model. You will have to check the drives manufacturer's website to see if they have a driver for you drive.
May 12, 2011 | E-Machines emachines (emachinees) CD-ROM...
How to replace compaq evo cd/dvd disk drive
hi.
open yr desktop cassing then u will see yr cd/dvd rom. then find for button to remove cd/dvd rom then pull tht tht boten and pull up yr cd rom.
new cd rom you must set jumper setting to slave then connect all cd rom cable. on yr system ten see yr cd rom will auto place in my computer.
regards
Feb 21, 2011 | Compaq Evo D510 PC Desktop
How do I open the tower to insert a c d
Open My Computer and then right click on the CD/DVD drive of your system that are define. For example: "E, or F, or G". Click on eject. or Press on the button CD/DVD-ROM. Mostly it's located in the right sight just below the CD/DVD-ROM "where the CD/DVD can insert". And if this two is not working than take a pin length around 2.5" and push inside the hole it's located in the right sight just below the CD/DVD-ROM. Hope it'll be helpful to you. All the Best!
Oct 07, 2010 | E-Machines eMachines Desktop PC
My dvd/cd rom is not working on my eMachine. When I open My Computer, it does not show an e drive.
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
Jul 17, 2010 | E-Machines emachines (emachinees) CD-ROM...
I want to watch a dvd through normal cd rom do u know any software which allows us to
You would need to upgrade your CD-Rom drive to a DVD CD-Rom drive
Or,
you would need to rip, then convert the video file from the DVD and burn onto a regular CD. Durring this process you would also have to convert the file.
If this was helpful please rate with a 4 thumbs up!! Thanks for using fixya.com!!
Apr 30, 2010 | E-Machines emachines (emachinees) CD-ROM...
Emachine W6409. will play cd. will not play dvd.
sounds to me like you have a cd-rom drive and not a cd-r/dvd rom drive? are you sure it is a cd-r/dvd rom drive? If its not it won't play DVD's because CD drives use a different codec than DVD rom drives do. CD-r/dvd drive combos use the same codec though as one.
Jun 06, 2009 | E-Machines emachines (emachinees) CD-ROM...
Emachine t6216 cd rom wont read
update your driver software for the cd/dvd drive that you have just go to the emachine support website lookup your computer and download the drivers for the drives if that doesnt work it might be a loose connection in the case open the case and make sure all the connections in the case are connected tight and right to the cd/dvd drive
May 28, 2009 | E-Machines eMachines Desktop PC
My eMachines CD ROM seams to have misplaced in my computer!
Can you see the drive in "My Computer", and did you look in device manager to see if it shows an error there.
if you cannot see the drive in my computer, but you can see it in Device Manager the instructions in this link
Feb 03, 2009 | E-Machines emachines (emachinees) CD-ROM...
DVD/CD ROM does not open
There should be a small hole on the front panel of the DVD-ROM. Take a paper clip and insert it into the hole and push to open the tray. If the DVD-ROM tray continues to malfunction, you'll need to replace it. DVD-ROMS run anywhere from $25.00 to $75.00.
Oct 01, 2008 | E-Machines emachines (emachinees) CD-ROM...
E-Machines T1090 PC Desktop Logo
73 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
