Question about Garmin nuvi 200W GPS Receiver
Broken USB Connector (Garmin nuvi 200)
The USB connector is loose. If I plug a USB cable in, the unit turns on. But it won't go into computer connect mode.
  • kytex Jan 21, 2009
    I also have the same problem.
USB connectors are too fragile for the constant in-out service they get. But I have solved the problem, at least for standard Type A. The plug end (its steel case slips into the port end's steel case) is functionally female; it accepts the 4-pin tongue of the port and squeezes it between the 4-pin tongue of the plug end and the steel case of the plug end. So when the plastic tongues wear down, the squeeze isn't tight enough. Solution: take a small vise-grips and make the plug's steel case a little thinner, like a weight on a grilled cheese sandwich you're making. Then when you plug it in, it will resist a bit and feel tighter. And it will now work!
Posted on Feb 17, 2011
My nuvi 260W displays the computer plug in sybole then turns of both while move and sitting still an d is connected to power supply. I have bought new connector for power supply.
Whenever you see the computer to GPS symbol pop up while using the DC car charger, this is an indication of a loose USB jack (bad connection) between the jack and the printed circuit board.
You should only see this symbol when connected to the PC using the USB cable. You should never see it when using the charger. Please see this link for more information and how to have it repaired:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Apr 09, 2014 | Garmin nuvi 260W GPS Receiver
Battery
The unit will take a very slow charge via your computer. I tell most people no it doesnt charge VIA your PC just because it takes soooo long. I recommend getting a new power cable from GPSCity. Just call them up or follow the like to the cable you need.
** This cable is for the Nuvi 200 series GPS units
http://www.gpscity.ca/garmin-mini-usb-12v-cigarette-lighter-adapter-for-nuvi-in-web-packaging.html
Cheers
Jul 13, 2010 | Garmin nuvi 260W GPS Receiver
Can't connect garmin nuvi 660 to PC USB
Your Nuvi should be Off before connecting....
My Nuvi came with a patch cord that connects from Nuvi to laptop
its a usb cord, same usb cord you find for cameras
Your computer should see that a usb cable is connecting
go to.... www.MyGarmin.com and update maps
Mar 24, 2010 | Garmin Nuvi 660 GPS Receiver
My Nuvi 200 will not charge and the USB port
My condolences. I would suggest you plug the unit in to your computer's USB port using an appropriate data cable (in case you no longer have the Garmin data cable, there are lots of devices, including cameras, that use such a cable with the large USB plug at one end and the mini-USB at the other). That would give you a handle on where the fault lies -- in the auto charger cable itself vs the nuvi's socket. If the nuvi charges from your computer, you're halfway home; if not, I suspect the cost of repairing the nuvi's USB jack could exceed the cost of a replacement unit.
Mar 16, 2010 | Garmin nuvi 200W GPS Receiver
I have a Garmin Nuvi 750. It went dead suddenly.
THERES A GOOD CHANCE THAT THE CABLE IS DAMAGED OR EVEN WORST THE CONNECTOR WITHIN THE UNIT IS DAMAGED OR BROKEN. TRY USING THE OTHER CABLE IE THE CAR TO UNIT CABLE OR THE USB TO UNIT CABLE IF EITHER ONE WORKS THE OTHER IS DEFECTIVE, IF NONE OF THEM WORK THERE GOES TROUBLE.
Mar 05, 2010 | Garmin (010-00583-00) for nuvi 750/760/770
USB connector in the back is loose and will not
If the connector in the back is loose, its not a Nuvi 350. A nuvi 350 has the connector on the side. In any event, please see this link:
http://www.sharc.net/gps_charger_repair.htm
- Jim
Oct 16, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin Nuvi acts like its plugged to a computer in the car
This is the problem with the Nuvi 2xx series... the charging port connector on the rear is weak and eventually the connections fail. It does not have a quick disconnect port like the Nuvi 3xx, 6xx or 7xx series.
The connector has to be either resoldered or replaced. The bad connections are whats causing the problem, making your Nuvi think its connected to a PC rather than a true charging power source.
Please see this link for more info:
Read the section on broken USB ports
- Jim
Sep 25, 2009 | Garmin nuvi 250W GPS Receiver
I have the Garmin 200 and the unit requires a map update. I paid for the download and have it on my PC WinXP. The download requires a USB connection.The model does not have this port. How can I transfer...
You should have received a USB cable with the unit. It has a USB plug on one end and a trapazoidal connector on the other end that plugs into your Nuvi.
- Jim
Nov 02, 2008 | Garmin GPS
Can I find a copy of the Garmin Nuvi 350T manual online please?
Yes. There are 3 ways to charge the Nuvi. Computer USB cable, 120VAC transformer wall plugin, and the cigarette lighter DC 12V plug for your car.
May 24, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
497 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
