Question about Golf
Club car golf cart will only travel 3 ft. then cuts off.
I ckecked the batteries, 48 volts, and found they are good. All checked 8.4 or so except for one that was 6.5. There are 6 batteries. It does this in reverse and forward. Any suggestions?
  • 100 Answers
From your description, I would say you have one or more bad batteries. Try this, connect a voltmeter across one suspect battery, while looking at meter,key switch on, f/r switch in forward, step on pedal just enough to move cart, see if voltage drops while under that load. Do this on each battery. Replace all batteries that drop significantly.
Posted on Nov 08, 2009
1996 48 volt Club car has clicking sound in rear that comes and goes. What is the cause?
Posted on Dec 28, 2008
  • 56 Answers
See if the motor is bad. If the motor is getting really old the bearings in it may be getting to where they do not turn so easily anymore. On some electric golf carts there is a pressure switch under the seat that if you are not sitting in the cart it will stop the motor for safety reasons. If this switch goes bad then the cart does not know if you are sitting there or not. We used to test these switches by jumping the wires of the switch together to fool the cart into thinking that we were always sitting on the thing. It is a good way to test the switch but not a great way to keep it that way, that switch is there for a reason. If it is bad then get a replacement.
*NOTE: Not all carts have this switch, check with the manufacturer.
Posted on Nov 22, 2008
My cart has 6 8volt batteries that are dead my manual shows 4 12 volt batteries should I replace the 6 8 volt with 4 12 volt batteries
make sure that they are in fact 8 volt batteries
You can replace them with 6 by 12 volt batteries as the end voltage (48 volts ) is the same
Mar 22, 2016 | Golf
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
Solenoid clicks. Why doesn't it go?
Need to know what kind of cart you have. Ezgo, Club Car?
36 volt, 48 volt ? for ezgo look at manuf. code, for club car serial number has the year. Then maybe we can figure out something.
Sep 09, 2015 | Golf
Charger works but cant get it to charge when plugged into my cart 48 volt
This can be one of several problems. Make sure charger works on another cart first. If it does then check total voltage of your cart, has to be at least 42 volts before charger will turn on. If you plug in the charger and it does not turn on then listen for a small click from inside the charger. That would be the relay and if it operates then your voltage is ok and you have something else wrong. If you don't hear the click then check the small gray wire at charger receptacle. It sometimes breaks just inside the receptacle, Without this sense lead, charger will never turn on. If all batteries, wiring, sense lead, fuse in the sense lead are ok, then it might be the OBC (on-board computer).
May 13, 2015 | Golf Cart Parts & Accessories Energy...
How do you check output voltage from generator to battery in an club car golf cart
if you look at the charger plug there is a small switch it can either be held down with the cover off or with it on. It should read you between 48 and 50 volts DC with that switch in that switch will keep you from charging the batteries if it is faulty. These chargers are really rather simple and golf cart King has the motherboards cheaper than anywhere else that you can buy them. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Oct 31, 2014 | Golf
Wiring diagram
dave, the link below contains electric golf carts wiring diagram, one here is almost the same with your 08 Precedent like the one below.
good luck
Wiring diagram
Jul 24, 2008 | Car Audio & Video
Golf Logo
745 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
