Question about Logitech LX 700 9674180101
My mouse works fine, but keyboard will not function even
After checking connections and using prescribed connect procedure.
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Have you checked the batteries?
    President:
  • 8,637 Answers
Normal 0 Assuming that you have good batteries installed, turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard. Try typing, should work okay.
Hope this helps. Bud
Posted on Jan 17, 2009
My computer mouse and keyboard not functioning well. I replace the keyboard but only last a month.
Hi jhunix,
I'm going to need even more information; The devices that use PS2 connections, which device is it, and how many of those devices do you have?
One thing that might be a problem, if the issue you see is intermittent, I would check the PS2 connector and see if the pins are bent or broken. PS2 connector pins sometimes will bend or break and this can cause some connection issues if not completely stop the keyboard/mouse from working... Also given the age of your PC the PS2 port may just be bad, but this is not a fatal injury to a computer.
Replacing the Keyboard and Mouse with a standard USB keyboard and mouse, should resolve all of your issues.
PS2 is an older technology that keyboards and mice used to run on; Now however USB connections are used.
Further more, if this an HP Desktop with 2 USB ports on the front, and 4 USB ports on the back, you will want to avoid using the 2 USB ports on the front, especially on older HP and Dell Desktops, the reason is the power supplies often do not have enough power to run multiple USB devices on the front USB ports.
The back ports should be fine regardless of the number of devices.
Hope this helps.
Dec 10, 2013 | Computers & Internet
My keyboard neither mouse are not connecting my computer it just doesnt show up i have a remote that connects to the same usb sender perfectly fine but the mouse and keyboard wont. Thank you,
its hardware problem, may be water or any liquid get inside and make the keyboard not work state, do you have any function key to disable keyboard or mouse mean go to control panel -> hardware setting check whether mouse was disable or not, if it disable mean make it enable so that your mouse works good same for keyboard.
Good luck
Dec 30, 2010 | Acer NSK8458AN Keyboard
The keyboard doesn't work, even though I just changed the batteries. Now what?
>when wireless keyboard or mouse runs out of battery, you need to re-establish the bluetooth connection in order for them to be functional again. To do so, you need to press the connect button on the keyboard and the USB dongle connected to the computer at the same time for about 8-10 seconds to establish connection. After that, you can try typing again. Same thing applies to wireless mouse.
Oct 03, 2010 | Gear Head WIRELESS keyboard/Mouse
Did some work on my pc now the keyboard is not working when i type letters or use keys they are not responding but my mouse is working
You should check the connection of you mouse and keyboard to see if they are properly connected.If the connections are okay you should go to the manufacturer website and download and install the drivers for the mouse and keyboard,i cannot give you the link because i am not sure what type of mouse and keyboard you are using. If you are using wireless mouse and keyboard you should replace the battery inside both of them and make sure the receiver is turn on.After you try these solution your mouse and keyboard should work fine.
Sep 03, 2010 | Logitech S520 Mouse
I just recently purchased the wireless keyboard and mouse. Thought I was following the instructions for installing them. The computer says they are installed properly, yet the keyboard won't work. Can't...
usually these have a tiny "Connect" Button on the bottom of the keyboard, mouse, and a button on the receiver. Have you followed the sync procedure with this ?
Is there another wireless device nearby that may be interfering ?
Is it one receiver for both devices ?
Does the mouse work ?
Have you tried a 2nd set of batteries on your keyboard ??
Hope this helps.
Jul 28, 2009 | Logitech 967437-0403 Keyboard
Cordless mouse and keyboard wont work together
Hi, after experimenting a little i have fixed my problem and I think I might be able to help you.
First, try press the connect button on the receiver.. Hold it for 20 sec (might not be necessary).
Then, press the connect button on the mouse and hold it for 20 sec (is necessary)
Next, wait 20 sec (is necessary) then press the connect button on the receiver but do not hold
Finally, press and hold the keyboard button for 20 sec.
Sep 28, 2008 | Logitech Cordless Mouse
Mouse does connect but keyboard does not, vice versa
reinstall the logitech cd which came with keyboard and mouse, with the mouse pluged in. once reinstalled restart and while restart plug the keyboard in..... this should resolve the issue.
May 29, 2008 | Logitech Cordless Desktop MX 5000 Laser
Keys not functioning
I was just about to post that I have the same problem (keys not working on Y-RR54 except scroll, F Mode, etc.) But as I was posting, my keyboard started working. Here's how:
Keep your Y-RR54 connected and hook up another keyboard. WIth the other keyboard, go to Logitech.com and go to their Support section. Select your product (Keyboard and Mouse Combo -> LX700) and then go to Downloads. Download the latest Logitech Setpoint software and install it to your machine. Make sure the Y-RR54 is connected to the receiver before you install. The latest version as of this message is 4.70.213. Let it go through the install, and when you get to the program, click "My Keyboard" and it will make you go through a "Secure Connection" process. After this process was over, my keyboard worked just fine. I'm typing from it right now.
May 15, 2008 | Logitech (967572) (9675720403) Keyboard...
Keyboard stopped responding
Please re plug your cable from your usb point provided in pc.Which windows are u using if xp or vista it will re-detect.
Dec 22, 2007 | Logitech Cordless Desktop MX 967300-0120...
Logitech LX 700 9674180101 Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
