Hitachi 43UWX10B 43" Rear Projection Television Logo
Michael Musgrove Posted on Dec 31, 2006
Set turns itself on for no reason (and sometimes off)
Hello- I had Dish Network installed the other day. Not sure if they are related, but ever since then, whenever I turn off the tv, about 10-15 minutes later, it will turn itself back on. Also, like some other owners, it will sometimes turn itself off, but rarely, especially compared to it powering up every time. I have tried turning off the HD receiver as well, but the set will still power on automatically. The set is only about 5 years old. What the!? Any ideas? Thanks!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 05, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
70
Points
0
On menu, pick customize, then set the video input sensor to off.
When we watch a dvd movie our dish network symbol floats around in the background. I have contacted dish, said not their issue contact sylvania
Hello, this is Dan Busa with DISH Network Customer service, What I would check is the cable coming from the receiver to the tv make sure you only have one set. If you only have one set coming from the box, check if it goes into the DVD player. If it does, hook the receiver up separately and it should work okay.
Daniel Busa
DISH Network Customer Service
My tv2 won't work
Hello, my name is Becki Barned from Dish Network customer service. The tv2 not working could be for a few reasons. Try the basic troubleshooting steps: make sure that the cable going to the tv is tight, and make sure that the tv in channel 60 or 73. If this issue has not been resolved, and you request further assistance, blog back, or you can find us on Twitter!
I have my tv hooked to a hd dish network sat box but I i only receive 480p instead of 1080p.
Hello there!!! There are a few reasons this could be. The first step would be to check how the hd is set up on the receiver. Press Menu 6-8. You will want to make sure that the Tv Type says 1080p. If this does not work, make sure that you are, of course, using an HDMI cable, or component cables. If you are having any other troubles with this, you can e-mail me at [email protected].
Becki Barned
3helpful
My receiver turns off and on by itself and becomes very hot
Hello, Daniel Busa with Dish Network customer service here. if your 622 is overheating you should get an errpr message stating its overheated. At that point you will need a replacement, if its turning off and on by itself sporadicly then that may be remote interference. Try this link to readdress the remote.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
I have the black Dish Network remote. I pushed the "TV" button at the top to turn on the tv. It then turned red and I was able to push power and the tv was on. Then I pushed the...
Hello, the remote can sometimes have problems. If you haven't changed the batteries in 60 days, try different batteries, or even try a different brand. Sometimes also, with new remotes, the remotes can be faulty upon arrival. If changing the batteries doesn't help, then at that point, we would probably want to replace the remote again. It has been some time since you posted, but if you have yet to get this resolved, I would be more than happy to take a look into this for you. You can reach me at [email protected].
Becki Barned
No lights not working
Hello there! my name is Kimberly Escobar with DISH Network customer support, I'm sorry to hear you are having issues with your remote control. If your remote control is not lighting up we want to make sure you have fresh new batteries installed properly (they all go in the same way). You may try holding the SAT button for 5 seconds if nothing lights up your remote will need to be replaced. Please feel more than welcome to contact us directly at 1800-333-DISH so we can get that set up for you!
I can't get the dish network logo to show up on my akai television.
Hello! You probably got this resolved already, but here are some steps if you still have questions, or if this happens again. What it sounds like is that you have no picture on your screen. If this is the case, it is simple to resolve. If you are at TV1, you will want to make sure that your tv set is on channel 3 or 4. Sometimes, the tv needs to be on an input. It usually needs to be on something like video 1 or 2, etc.. If you are at TV2, then your tv will need to be on channel 60 or 73. If neither of these work, go ahead and unplug the receiver from the power source for 10 seconds. Hope this helps!!!!!!
Becki Barned
1helpful
2answers
What would cause reciever 2 to have a much lower singal than reciever 1 on a 625 reciever foe dishnetwork
Hello there! Becki Barned with Dish Network customer service here! There are a few reasons for this. There could be a problem with the receiver itself, cabling, or a component on the dish itself. Normally, it is due to a corrupted cable, or the receiver not being able to pull in signal. Unplugging the receiver for 10 seconds in most cases, will help. Blog back if any other troubles!
My receiver does not gen any signal and turns on and off by itself ....last time that that happen i unpluged the system and leave it for a couple of days thinking it was broken but it worked ...... And it...
Hello there could be a coupledifferent issues that are going on, the first is your receiver is in "BootRecovery" and it can take 45 minutes to 4 hours. The other could be connectionsfrom the back of the receiver to the wall need to be hand tight and unplugthe receiver for 10 seconds to reset.
Mike Houston of DISH Network
5helpful
5answers
Dish Network - Dish 500 Satellite 110 is not being recognized
Lonnie, You have a simple problem,the 119 satellite is lower in the sky than the 119 if you make sure the pole you are mounted on is straight and plum ,then simply raise the dish a few elevation degrees and turn the dish to the left.Your dish is aimed low and to the right.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
