Question about Microsoft Xbox 360 Console
The 360 won't turn on at all - I am sending it back to be replaced - but I want to make sure there is no game in it. Any suggestions as to how I can open it?
  • Anonymous Dec 30, 2008
    my xbox will not turn on
If you remove the front faceplate (does not void warranty) you there's a hole below eigther on the right or left depending on your model, where you can push in a paperclip and manually eject the dvd
Posted on Dec 30, 2008
  • 120 Answers
Well, if you do send it back with a game, microsoft is really good at returning the game, so don't worrie about it.
now you shouldn't have to worry.
Opening the tray without power will require you to open the xbox.
hope this helps.
Posted on Nov 24, 2008
How to fix the "open tray" error on Xbox 360
When ever you have a problem with your Xbox 360 always do these steps first:
1. Turn off your Xbox 360
2. Unplug all of your cords
3. Plug your cords back in
4. Turn your Xbox 360 back on
1. Now with your Xbox 360 on open your tray.
2. Hold your tray open while you turn Xbox 360 off making sure it doesn't close.
3. Still making sure your tray doesn't close turn it back on.
4. Have fun!!!
If this does not work you will have to send it into microsoft to fix. If your warranty is up you will have to pay $150 to fix it. Otherwise it's free
on Apr 20, 2010 | Video Game Consoles & Games
My xbox 360 turns off whenever i play a game. We have two xbox's and one turns off very quickly when playing games, and the other turns off after about 10minutes of game play. This happens with all...
There could be several causes. If you’ve managed to run other appliances with the same voltage through these power outlets without them turning off then it won’t be the outlets themselves.
It could be the power cable; try swapping them to see if this affects the frequency (10 mins vs ‘very quickly’). If this makes no difference then it won’t be them that’s at fault.
The most likely cause (unless both are simply faulty) is overheating. The Xbox 360 produces a lot of heat and there’s a failsafe built in to turn it off immediately if either the fan is malfunctioning or it’s too clogged with dust to ventilate properly.
Make sure nothing is sitting on top of them and that all ventilation areas are clear. If you think there’s a chance they might have become dusty, get a can of compressed air to dislodge any built up dust in the vents & a vacuum cleaner to remove it.
Oct 09, 2017 | Microsoft Xbox 360 Console
My 360 won`t turn on and it is plugged in
press the reset button on the power brick, if that doesn't work your power button may be broken. Unless..... RROD!!! Then just send it on its way to Microsoft for a free replacement.
Apr 19, 2010 | Microsoft Xbox 360 Console
My xbox360 just stop preading everything it runs and works just won,t play any games.
If your Xbox 360 will not play your games this is because of the sensors on the back of the drive overheating it is not normally the laser.
Luckily you can fix this yourself and get back to your games and to do this you need the proven Xbox 360 Repair guide.
Or you can send it in and they will fix it for you the repair will take about 4 weeks.
You can use the recommended guide to fix this and get back to gaming.
As long as the heat stops getting to the drive you will be fine.
Feb 24, 2010 | Microsoft Xbox 360 Console
Xbox 360 sometimes wont open or load games it has already been fixed with the ring of daeth, and now this!
older models of the xbox 360's disc drive have been reported with this problem i myself have had this problem . when you send your system out for repair they dont fix your system and send it back they send you a refurbished system. many older models had this problem . i suggest either buying a new digital drive for your xbox 360 and install it yourself or send it back out to microsoft
Dec 17, 2009 | Microsoft Xbox 360 Console
I turn it on and it says play dvd when i put a game in ??
The truth is, that this can only be fixed by Microsoft ….( or by someone who has experience in replacing players or other components on 360).
You can keep pushing that game in and out for a while, but eventually, you’ll have enough of it and the player won’t play your disks at all.
There’s nothing you can do about your xbox; there’s no fix for that, except sending it to Microsoft and have the player of your 360 replaced.
Dec 15, 2009 | Microsoft Xbox 360 Console
Xbox 360... HELP
Send the unit back to Microsoft for warranty repair.
Call 1-800- 4MY XBOX to set it up.
Make sure you remove mod before sending in as to not void warranty.
Hope this helps!
Mar 11, 2008 | Microsoft Xbox 360 Console
Discs not reading , not cutting off
Your laser/drive have gone bad. I would suggest contacting your local game stores to see if they do console repairs. If not then you would have to buy the drive/laser and install yourself, that or send it in to the dreaded Microsoft.
Jul 22, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
