Compaq Evo D500 PC Desktop
Problem for Compaq Evo D500 PC Desktop
I cannot open my compaq evo d51s, any ideas?
By emmacanty on Nov 20, 2008
I've removed the one screw showing at the back and pulled off half the front faceplate. The silver bit won't come off. I can see screws under it but it feels like its screwed on itself. I've removed one rubber foot from the bottom but no screw under it. I cannot find a service manual anywhere. Want to upgrade the RAM and change the disk drive. Just stuck at the opening stage!
Comments:
Nov 20, 2008
- Thankyou for your swift reply. If its the screw I thik you're talking about, I definitely do not have the tool to open it! Do you know which number torx screwdriver I need for it? I have three torx screwdrives but they're all the wrong size and don't have a hole in the middle which this one seems to need as the middle of the screw is like a pin. Any more help would be much appreciated! :-)
Solution #1
posted on Nov 20, 2008
Somewhat Helpful)
leecom72
Rank: Guru  Compaq Computer Hardware  Expert
Rating: 89%, 2472 votes
if you look at the back of the workstation you will find a hidden screw next to the air vents, locate and unscrew, the casing should slide back away from the front and lift off to access the optial drive and ram
hope this helps
regards
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 25, 2009
Not Rated)
Pyxi
Rank: Guide  Computer Hardware  Expert
Rating: 79%, 3 votes
The front, top and sides come off forwards.  No screws to undo, hold it with the silver face towards you, tip the front up, push in the side buttons and pull towards you whilst pushing the buttons at the side.
Was this helpful?
Yes
No
Solution #3
posted on Jun 22, 2009
Not Rated)
dgh24
Rank: Apprentice  Computer Hardware  Expert
Rating: 0%, 0 votes
All you have to do is push the two side buttons and pul it forward no screws to remove
Was this helpful?
Yes
No
Solution #4
posted on Jun 09, 2009
Not Rated)
Funkygraz
Rating: 0%, 0 votes
I just removed the one screw on the back (dont think it was needed) and push the buttons on the side, the whole top part should slide forward (its not the screw with the pin in the middle) I did push a scredriver under the top from the back to give it some wiggle room. it was a very snug fit
Was this helpful?
Yes
No
Popular Solutions for Compaq Evo D500 PC Desktop
Questions and Unsolved Problems for Compaq Evo D500 PC Desktop
Do you recommend Compaq Evo D500 PC Desktop?
Answer
Answer
i have gate way e series one day i turned it off to move it when i went back to turn it on the fan... (More)
Answer
I have a gateway gm5478 model pc with a 22inch lcd gateway fpd2275w monitor(purchased 12/07) for... (More)
Answer
power surge emptied d drive/disc all data gone.computer will not shut down on it's own.
Answer
i have an office jet 6210 and can't get the scanner to work on my computer/printer. downloaded HP... (More)
Answer
Hello, new problem. My uncle has asked me to fix his iWin media player. It plays it all and has an... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Compaq Evo D500 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
