My laptop only has one light in front, whereas before it had 4
I tried to charge it , but it want turn on.
  • yasminymp Nov 20, 2008
    The Toshiba Satellite A85-S1072 ----- I did plug it up, but it did not charge, nor turn on.Soooooo
    Sergeant:
  • 237 Answers
What laptop do you have? The good thing about laptops is, they have two methods of power consumption, battery and AC. I may be asking an already dun it question, but have you used the AC adapter plugged into a wall outlet to turn on the laptop?
Posted on Nov 20, 2008
  • zabrina liang Nov 21, 2008
    So pretty much, it's either the laptop or the AC adapter that's the problem. To make sure before you go anywhere, try different wall outlets. Next step if that doesn't work, What you can do to check is go to a computer store and take your AC Adapter with you (or if you have a friend or neighbor with a toshiba) Ask a salesperson to take out the battery of a toshiba laptop and use the AC adapter to power on. If the laptop powers on, you'll know it's something with your hard drive that will  not boot up.If the AC adapter
    will not power on the laptop, you're at the store, pick up a new adapter (try it on your laptop first)
It is plugged into computer for 2 days still only showing 1/4 charge. Cord connection feels loose?
Could be a faulty cable....more likely that you are plugging into the front usb socket when you should use rear ones as these are direct onto motherboard whereas front are cable connected to mobo.be aware that it is a 5volt rail in both cases but the amps are less than 1 whereas some external power socket chargers are rated as high as 2 amps hence less charging times.
Jul 02, 2015 | Tablets & eReaders
ASUS laptop will not charge and now will not turn on even with plug in as charging light does not come on.
If charger is ok, problem with power jack or motherboard. probably the charging circuit in the motherboard. contact a good chiplevel service technician. hope it helps
Dec 01, 2012 | ASUS Computers & Internet
My Gateway M-6847 will not turn on. When I press the power button the wireless light and power button light just flashes quickly. Also the battery light in front stays lit while plugged in.
Hi
silly question sorry
but have you charged the battery or plugged the power cord into plug and switched on to try to charge the battery for a couple of hrs without using the laptop
Jun 23, 2011 | Gateway M-6847 Notebook PC
My hp 540 in battery mode while powered on switches off automatically within 4 second even before display appears, booting takes place whereas in adaptor it is reatsrting automatically
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Apr 21, 2011 | Computers & Internet
My computer won't turn on at all, the green light comes on but only a black screen shows. When it was plugged in to power the light wasn't showing that it was charging so took out the battery and then...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
Sep 09, 2010 | Acer Aspire One Netbook 8.9" Notebook
HP G60-120US 15.6" Widescreen Laptop PC Notebook: when trying to turn the computer on, the 3 lights ...
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
If the Notebook boots up you may fix the battery back. Try restarting the computer only with the AC power, without the battery & vice-versa. If the issue still persists then I request you to reset the memory modules, as sometimes the memory module connection get loose.
May 17, 2010 | HP G60-120US Laptop
My eee pc charger wont charge my laptop...
we had a similar problem the ac jack socket burnt out so we got a replacement part from ebay and my husband put it in and hey presto it works it cost 6 pounds for the part whereas a company to fix it wanted 100
Jul 01, 2009 | ASUS Eee 4G Notebook
Every time i try to turn on my Gateway model MA7
  • the battery may need full charging, charge it for 4-5 hours, and it the problem persist it needs replacement.
  • for it works in power cord.
May 03, 2009 | Computers & Internet
Laptop won't power up
when u get power on of your laptop .u seen Red/orange light blink 4 times on front panel.it means your laptop battery is not getting charge.please get charge for minimum 6to 8 hrs & then try to on .if y u laptop battery is get charge u r laptop will started on (also confirm your A/c adapter is working .green light is display on front panel it indicates charging on )
Jul 09, 2008 | Gateway MX6124 Notebook
Does not turn on
if your laptop not charging better change the ac adaptor to charge but if your laptop not booting but the charger charge the the laptop the problem is you motherboard just try to reset you CMOS then try to boot again
Apr 06, 2008 | Acer Aspire 1690 Notebook
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
