Question about Quasar SP-3235 32" TV
Vertical Diffusion I am having a problem with one of the TV/VCR Combo sets, it has not diffusion of the picture vertically. I have a lot of experiance in electronics, I will resolder the board. But if this does not work, I would like to know what it is I have to repair and if at all possible what it looks like. Thanks you
    Scholar:
  • 119 Answers
Completely resolder the virtical circuit, including the vert. ic. i have also at times found an open resistor near the flyback that provides b+ to the vert. ic. if you can find a pinout if the ic, find the b+ pin & trace it back to the fluyback. good luck.
Posted on Dec 18, 2006
I have a tv that has line going side to side
The line is horizontal but means no vertical deflection (set deflects picture from middle to top and bottom.
Either bad solder connections at vertical output chip or a bad part somewhere in that circuit.
Jun 16, 2012 | Toshiba 26 inch HD monitor TV, DVD and VCR...
I only see one solid horizontal line on my tv
It lost Vertical sweep either due to open fuse resistor feed the Vertical output circuits, failed vertical/oscillator IC, failed Vertical york (on the neck of the picture tube). Those are what you need to check. This is CRT TV, the repair shop will charge at lest $35 to tell you what I just indicate, to repair it iwll more likely to be in $100 range.
Please leave rating if it helps.
Feb 01, 2011 | Panasonic PV-DM2792 Triple Play 27 in....
Horizontal hold troubleshooting. Can hear but pic is like a line on the screen. Tried adjustments on back
If the line is half way up the picture. This is a vertical problem. Most likely the vertical output IC or a bad solder joint near the IC.
Jan 26, 2011 | RCA 27F501TDV 27 in. TV/VCR/DVD Combo
I have a three year old model pvc2542 tv/vcr combo the picture is just a line in the center of the screen
Bad vertical deflection circuit, unless you have a bad connection (bang on set to set it it fills out for a second) . you will need components replaced such as the IC, capacitors possibly a fuse from the power source to the vertical IC.
If its a bad connection soldering the IC pins is not to hard if you are OK with taking it apart yourself.
gd lk
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 21, 2009 | Televison & Video
Broken the plate( F and L )difussion
Here are part numbers of plate diffusion of Sony KP-48S75 TV
4-070-280-11 PLATE (L), DIFFUSION
4-058-455-11 PLATE (F), DIFFUSION
Oct 24, 2008 | Sony KP-48S75 48" Rear Projection...
When turned on only gets a straight line of color in middle of screen
You lost your vertical sweep. most likely the vertical output IC or a power supply source is the problem.
Jun 07, 2008 | Panasonic PV-DF2700 27 in. TV/VCR/DVD...
No picture
if there is only one horizontal line you have a problem with vertical deflection section
May 28, 2008 | Panasonic PV-DM2794 27 in. TV/VCR/DVD...
TV picture
This set will need to be serviced by a tech shop as you have a problem called "vertical foldover"...accordianman
Apr 09, 2008 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
PVQ-2510 service menu
If you fix the vertical cirrcuit correctly, there is no need to go into service menu as your vertical should go back to normal. Re-check your work. I remember one cap on this set that gets overlooked all the time so you may want to check it. It is cap C413 - ceramic cap and sometimes it shorts causing a vertical shrinking as you described. Good luck.
Feb 01, 2008 | Panasonic PVQ-2510 25 in. Combo
Tv toshiba vertical problem
I had white lines 4" thick vertically for about a week, then one day powered the unit up and with in 3 seconds there was a loud pop from the rear or the unit. Any one know what needs to be replaced?
Jan 23, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Quasar SP-3235 32" TV Logo
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
