Question about iLO DVDR05 DVD Recorder
ILO DVDr05 Powersupply board down, 2200 uf (1) 1000 uf (2) all three at 10 volt, partially expanded. No power out at all. Can capacitors with same uf, but different voltage be used to replace originals ?
  • 1 more comment
  • Wayne McEathron
    Wayne McEathron Dec 28, 2008
    Thankyou !!!!
  • tom63h Jan 06, 2009
    I had the same problem with the 1000mF and 2200mF capacitors bad and slightly swollen on the ends. Replaced them with higher voltage 16v and 25v respectively. (That was about the highest voltage that would physically fit) and the unit is functional again.
  • DupontGordon Jan 23, 2009
    I have the same problem but I am not able to replace the caps because of my eyesight not being what it used to be. Is there anyway I can buy a replacement board?
  • 3 Answers
As long as the voltage rating is higher, not lower, it is fine, actually better, especially since this seems to be a fairly common problem, the capacitors used may not have a high enough rating to survive transients that may occur. As long as you are replacing them, I would use a higher rating, to make it more robust.
Posted on Dec 28, 2008
I have much Samsung TV that turns on but turns off after cycling picture has lines up and down and a loud high pitch noise comes out
The TV has a chip that check to see if the circuits are OK before turning on the set. Samsung has a power, input and video boards. The problem is when it check the high voltage circuit and it does not have 390 volts, the chip turn-off the power instead. You can buy a new power board or fix it yourself. The power board is where the 120 volts AC is plugged in, and near the 120 volts is small transformer, then you will see a capacitor rated 100 uf at 450 volts. Check for 390 volts here. If the voltage is less, then replace this capacitor with a 350 uf at 400 or at 450 volts.Samsung used a "small" capacitor when it should have ordered at large capacitor. Good luck.
Nov 28, 2017 | Samsung Televison & Video
Hy i have samsung ue40d5003bw and half of display (up) is horisontal lines with picture and half of the diplay (down) is clear picture.
Samsung uses a power board with one capacitor. (Ignore the video and input boards.) Check high voltage across the capacitor - should be 390 to 400 volts DC. If not the capacitor needs to be changed. Samsung uses 100 uf rated at 450 volts. I replaced it with 370 uf rated at 400 volts. (Did not have a 450 volts lying around.)
Nov 25, 2017 | Samsung Televison & Video
SAMSUNG TV UN65JU6700F RED LIGHT BLINKS 6 TIMES SET DOES NOT COME ON
High voltage circuit is bad and usually is the capacitor that needs to be changed. Open up the back of the TV, and there are three boards. The one with the power cord is the power board/circuit. Change the capacitor - a 450 volt 100 uf. It should be at least 300 uf if not 400 uf at around 400 to 450 volts.. Samsung was trying to save money.
Oct 27, 2017 | Samsung Televison & Video
Hi, my LCD Polaroid FLM-3701 went through a power outage and now doesn't get power any more. The power led doesn't show any light. I saw a capacitor repair kit available, and four 680 uF capac
The power supply fuse should be next the the ac input plug on the power supply. It should be a long cylinder type fuse, probably a T6.3AH/250V. You will want to replace those caps ASAP
Nov 05, 2012 | Polaroid FLM-3701 Television
1 year old samsung 50b550 1080p 50inch plasma...working fine one minute then screen went black, audio is ok. menus do not come up either. audio changes with channels ok. Have back off, capacitors look ok,...
Samsung has three board. The power board is the one on the right and is where the 120 volts plugin. There should be only one capacitor rated at 100 uf at 450 volts. Measure this voltage - should be 390 volts. If not, change this capacitor to 350 uf with a rating of at least 400 volts (to 450 volts). I was lucky to have a old microwave and a old power supply laying around the house. I have a 120 uf and 220 uf both rated at 400 volts, and when I connected them in parallel (370 uf) and changed out the old one. The TV works fine now.
Nov 23, 2017 | Televison & Video
Wont start
Hi all. I came across this forum after "Googling" this particular model ilo TV. (LCT27HA36) Like a lot of you, mine would not turn on. It was just like lambon48's TV. Since I could not find an answer online, I took it upon myself to solve the problem. I am a retired radio engineer, and have experience in repairing a vast assortment of electronic equipment. The problem with my TV was isolated to the power supply board. I found several capacitors to have bulged. That is, the tops were swelled outward. This usually is a sure sign the capacitor is bad. The ones that were bad were all of the 1000 uf capacitors and one 470 uf capacitor. Now these caps were rated at 16 volts and 25 volts. When I replaced them, I used 35 volt rated capacitors. These caps can be bought at Radio Shack for about $1.60 each. It cost me $10.50 to fix my TV. I recommend you having only basic knowledge of soldering to do this. Just take your time and notate how the caps are installed before you remove them.. Please make sure you install the caps properly. That you put the positive and negative legs of the capacitor in the proper holes. If your board is like mine, the positive side is marked on the circuit board. If you are hesitant on soldering, I bet you know someone who can do this for you. Good luck.
Mar 21, 2008 | iLO 2600 Television
Ilo dvdr05 needs power supply
Most electronic components are available at any large parts warehouse, except maybe the power transformer, and other indigenous parts. What part of the power supply do you need?...accordianman
Mar 05, 2008 | iLO DVDR05 DVD Recorder
ILO DVDR05 DVD Recorder
Same problem and I'm seeing two obviously bad capacitors on the power supply card on mine, a 2200 uf and a 1000 uf. I'm thinking that's the problem, though I haven't tried replacing yet.
Dec 07, 2007 | iLO DVDR05 DVD Recorder
Unit want come on
I ordered new Capacitors for my DVD Player 2 Panisonic 1500uf 10v 105° caps and 1 Panisonic 1000uf 10v 105° cap and soldered them into the powersupply where the oviously swolen / leaking capasitors were and walla it powers up and no more high pitch noise but I can't get it to eject the cd or anything. It shows on the screen but it just says loading. My guess is it did some dammage to other components inside the machine. I suppose it was worth a shot but now I am going to toss it and get a name brand. ILO isn't in business anymore... Oh and yes I did try the reset button abov the DVI connector...
Oct 20, 2007 | iLO DVDR05 DVD Recorder
iLO DVDR05 DVD Recorder Logo
109 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
