Question about Aiptek ISDV2.4 Flash Media Camcorder
Shutter button on top is stuck
Posted by eddie_scott on Nov 18, 2008Report abuse
Camera = Aiptek ISDV2.4
The shutter button on top is suppressed and will not pop back up (no play in the button anymore). I took the screws out and looked inside. All I found was a long grey tab. I'm not sure what it attaches to or what it is supposed to come in contact with to take a picture. I did not find a loose spring inside either.
I wanted to see an exploded view of the inside of the video camera, but cannot find one.
If someone would please respond by Friday, Nov 21st, that would be great!
Thanks in advance for your help.
  • 21 Answers
SOURCE: Wont read sd card..screen shows card locked..card ok
Aiptek is not so good at answering emails. If Nitrotrike's suggestion doesn't work, try posting this question at
http://forums.steves-digicams.com/forums/view_forum.php?id=92
Those guys are more likely to help you (or at least try) more quickly than Aiptek.
Posted on Jan 19, 2008
  • 37 Answers
SOURCE: aiptek - Video and sound is out of sync
In order to play hi def movies without upgrading anything on your PC, download Quicktime for windows, It supports hi-def video, and the PRO version ($20) lets you change the format without quality loss.
Posted on Sep 26, 2008
  • 3 Answers
SOURCE: AIPTEK PROBLEMS
Do what I do- take out the SD card and transfer files directly to the computer without the camera.
Posted on Nov 09, 2008
tostitosmith
  • 11 Answers
SOURCE: I have an aiptek DZO-V3T camera.I got vidio and
Hey try plugging in the cord to the USB Prt on the Hard-Drive, if you are plugging it into the Monitor or vice-versa. I have the same camera, and I plug it into the monitor. If all else fails, take out the memory card and put it into a digital camera, or something like that and connect the camera.
Posted on Aug 18, 2009
  • 3 Answers
SOURCE: My camera's monitor/screen is black with no picture
My AIPTEK 1080p was powering on but the screen was turning off within one second of turning the unit on. I verified that the camera was still working and just the output onto the screen failed. I was able to resolve this by hooking the camcorder up to the TV and viewing the menus on the TV and then turning the camcorder off with the power button. I think this problem happened because I didn't do a "clean" shutdown the last time I had my aiptek hooked up to the TV. It is now working perfectly!
Posted on Jan 17, 2010
What makes the screen stay black when camera is
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't help...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 14, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera works but the screen went black A640 except for video and color swap. Did I press a button? I was shooting in cold weather.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
But if you've already tried this, have you also tried downloading any of your photos taken with the black screen to your computer? Are the photos also black? If so, you might instead be experieincing a stuck shutter (possibly due to the cold weather).
Jan 03, 2010 | Canon PowerShot A640 Digital Camera
Camera shows no image through the viewfinder or on the lcd screen.pressing shutter button will actuate the camera, but only image is of a black box.using the display button to turn off the lcd does not...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Dec 18, 2009 | Canon PowerShot S3 IS Digital Camera
Fuji S5200. Shutter stuck in the open position.
Hello
Thank you for using FixYa for your problem
Do you live in a humided area, this can cause the shutter to stick or has the unit been sitting for a while?
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 02, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
Screen is black on camera Cannon PowerShot SD750
Am assuming that you've already tried pressing the DISP button, and that didn't fix it. Have you tried downloading the photos since this occurred? Are they also black? If so, then you're likely experiencing a stuck shutter.
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 03, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
The pictures I take outside are white.
Jul 03, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
My canonpowershot SD750 digital camera is coming as a black scree
Jul 02, 2009 | Canon PowerShot A550 Digital Camera
Auto is stuck on and I can't zoom in or out or review pictures - shutter button stuck also
Being very careful, follow this pictorial disassembly (it's in Estonian, but just follow the pictures). Don't go any further than popping the top off the camera! Look for anything obviously broken off near the vicinity of the shutter button, or looking very different than what's in the pictorial. Keep in mind it's amazing what you can do with a little glue and scrap pieces of plastic:
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
Also, pay attention to the following post as there is some potential for electrical shock:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
Oct 19, 2007 | Canon PowerShot A95 Digital Camera
Stuck shutter-button
Either just drip small amount of methilated spirits or benzine at the rim of the release button and lift with tweezer ( tweezer into the center of the button ) repeat several times . If this fails remove top cover and clean the shutter relase from inside.
Nov 22, 2006 | Canon EOS-AE-1 35mm SLR Camera
Open Questions:
Aiptek ISDV2.4 Flash Media Camcorder Logo
132 people viewed this question
Top Aiptek Video Cameras Experts
tomikles
Level 1 Expert
Larry Stiles
Larry Stiles
Michael Galve
Michael Galve
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
