Question about E-Machines (T2824) PC Desktop
EMachine T2824 does not turn on. Power cord/power supply seems O.K.
  • myahyaicsat Nov 20, 2008
    Yes I see green light. I will try power supply. thank you!
    Scholar:
  • 78 Answers
There are just too many eMachine models to be familiar with every one, however, as a preliminary inspection, remove the side panel, and turn the computer on to see if you see a green "Health" light. This will give you an initial clue as to how to pursue the problem. eMachines have historically had power supply problems. If you do not see a green health light on the motherboard, then your power supply is defective. A power supply supplies various voltages + - 5V, + - 12V ,etc. A power supply can be easily tested by a local shop with the proper test equipment. You might start there if you are a DIY! Short of that, you can purchase a power supply for under $65.00.
Posted on Nov 20, 2008
  • comment
    comment Nov 20, 2008
    Just to clarify..
    If the green light is ON, it is probably NOT the power supply, especially if you hear the drives power / spin up.. If you find the green light, and it is not on, then likely it IS the power supply..
T2824 emachine turning on and off by itself. Sometimes it will be on for a 3 or 4 hours and go off and then turn its self back on in a couple hours later or even the next day come back on. I replaced the...
Take the side cover off and use compressed air to clean the dust off the heatsink fins atop the processor. If that doesn't help, take any cowling off, and make sure no dirt is plugged between the heatsink fins.
Feb 15, 2018 | E-Machines (T2824) PC Desktop
My computer won't turn on. I cleaned the Air spinner thing, checked the mother board, and everything was fine. The computer is an Emachines T2824. Can i have some assistance on how to get it to turn on?
If the machine is doing nothing at all when you press the power button, chances are your Power Supply Unit (PSU) has failed. If this is the case, the only way to fix it, is to get a new PSU.
Nov 03, 2010 | Computers & Internet
Does not boot. Installed defective Power Supply
If you would let me know the booting problem slightly, i hope i can help you in a way or two.. Boot up failure, or file missing or restart problem, please let me know..
Apr 26, 2010 | Intel Desktop Board D845EPIL Motherboard
Emachine will not come on
Reseat the power cord that is on the motherboard. Sometimes if you pull that cord from the motherboard (be careful there is a clip that is holding it to the board) wait about 1 minute then plug the cable back onto the motherboard your machine will possibly turn on. Also unplug your power supply cord from the computer when you do this. The other issue could be that the battery on the motherboard is dead.
I’m happy to assist further over the phone at https://www.6ya.com/expert/barbara_87cfe34e34050f26
Jun 30, 2009 | E-Machines eMachines W2686 PC Desktop
EMachines 2824 not powering on
you can check also by removing the boards.you can check the mainboard outside in the box..you remove the mainboard and check if the mainboard is not shorted with another devices.
Mar 07, 2009 | E-Machines (T2824) PC Desktop
Emachine with XP home edition doesn't start
Hi hearalso, down to the basic's. Replace power cord.
No help there than, remove the case's side panel to expose the motherboard. (Normally it is the left side panel while facing the front of the PC.)
Look closely for a small (green in color) led light. The power cord must be connected to the PC & connected to you're power strip but do not press the power on button on the PC.
The green led tell's you the board is receiving 5volts. Check all connections. Un-plug & reconnect every data & power connector in your PC. (Double check). There is a fuse inside your power supply that may have blown. Check you're manual page, Approva Statements B-1. Fuse Warning Instruction Caution.
Check fuse in power supply. (Unplug power cord before opening).
If you can not power up the PC after all of the above than if possible, swap out the power supply.
Replacing the power supply is the last step.
If you have more questions, feel free to ask.
Good Luck!
Mike
Apr 09, 2008 | E-Machines eMachines Desktop PC
Mobo problems
Assuming the power supply is ok, and the pc is a few years old, it could be a flat cmos battery so check for the disc shaped 3V battery and see if it's flat. Whilst you have done that look for the JBAT1 terminal and put jumper on pins 2-3 for a few seconds then back to 1-2. Look at the capacitors (tube shaped things) for the tops and sides swelling, if so mobo needs replacing. You need also to check the power supply leads to the motherboard and check its connected to mobo ok. Start up pc if it will and set the time and date in standard bios settings.
Jan 24, 2007 | E-Machines (T2824) PC Desktop
E-Machines (T2824) PC Desktop Logo
368 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
