Question about Samsung SpinPoint P80 SP1604N 160 GB Hard Drive
I Lost 20gb from my 160gb harddrive
I recently bought a new 160gb hdd however during the xp install process the system sees 160gig in the bios setting but when windows ready to install it reads only 131gb with 8gb reserved which means i am missing about 20gb please help me i have jumper settings on master and its on primary ide cablei also have just that one hdd.
My harddisk is detect,but it display in read error, and cannot be formatted and cann't display partion
Posted on Aug 02, 2008
  • 624 Answers
Also the 160 GB rating is raw data, a fair chunk of that ?missing? space is being consumed by the operating system when it formats the hard drive.
Posted on Mar 01, 2007
    Sergeant:
  • 310 Answers
Hi, you aint lost 20gb. 1mb is 1024 1gb aint 1000mb for a example i have a 40gb hard drive here, it displays 34.3gb 200gb hard drive is usually 186gb its normal dont worry. :-) all the best John
Hi, I have a HP NX6310 notebook with Win Xp Pro installed. I need to reformat it after it was heavily virused, and reinstall Win Xp but without the recovery disks I am rather helpless. The recovery...
You can't see any HDD's when trying to install because your BIOS system was set the IDE controller to an AHCI, you can set this to native IDE and windows XP setup will read a HDD's..
If you need set the IDE controller to AHCI you need Intel AHCI controller driver for your system, you can see it during installation process to press F6, you must use floppy diskette and put the driver onto it.
Another way to install AHCI driver is Integrate the driver into Windows Installation directory..See here for more details..
Aug 10, 2011 | HP Compaq nx6310 Notebook
Hello, im having trouble with my motherboard (Gigabyte GA-8IPE775-G) im trying to re-install Windows XP on a brand new HDD and it can see it in Bios (set 1st boot to CD 2nd HDD) but won't let me...
Owners manual can be found here : http://www.retrevo.com/support/Gigabyte-GA-8IPE775-G-manual/id/23285bh940/t/2/
As to the boot process, its been my experience that if you can actually get into bios, then there isn't any problem with it. Problems usualy arise becoase of a setting chianged inside bios. Have you tried resetting bios to defaults to see if that changes anything?
BTW, have you formatted the new harddrive? Re-install works a heck of a lot better with a properly formatted harddrive.
Hope that helps.
Cheers from NZ
May 24, 2011 | Gigabyte GA-8IPE775-G (818313002198)...
I just bought a harddrive because my old drive went. so I hooked up the new drive and turned it on, but i get nothing but a blank screen
hi there,
please unplug new harddrive and see if computer boots up without it.
if it does list all the other cd/dvd drives, then you did someth. wrong upon installing the new drive.hook up again, see the jumper settings in the back(must be set to single ) if attached to 1st IDE-channel, else if you hook it up to a cd-drive, set jumper on cd to master, onharddisk to slave, check power connection, reassemble pc, boot up.
Got a screen now? hdd should belisted! now insert windows installation cd and proceed...
if system still does not recognize the drive, then enter BIOS(press F2 or Del or F1 during booting)set all drive detection to automatic, leave saving BIOS-settings, press F10), reboot.
Problem solved?else come back on fixya.Good Luck
Sep 24, 2009 | Computers & Internet
Mecer wont load wi xp sp2 on 160gig hardrive
The BIOS is seeing the drive but your computer can only see about 120-130 GB of harddrive. If the drive has a pin option to limit it's size you may be able to limit it then install windows but if it doesn't you're back to looking for a smaller drive.
Hope this helps
Chris
Aug 17, 2009 | Computers & Internet
Harddrive space problem.
When the HDD was fornatted, was it formatted appropriately? It's quite possible to format a 160GB HDD to present a smaller amount of space.
Mar 08, 2009 | Trekstor (21202) 160 GB USB 2.0 Hard Drive
Lost system restore functionality after installing second xp pro
My computer properties system restore check if system restore is turned off.
If yes turn on all drives and restart.
If system restore is on then you need to create a new admin account and check system restore settings.
Also you need to have 6gb of free space in windows partition
Enjoy this will solve
Feb 08, 2009 | Microsoft Windows XP Professional
Thinkpad T20 2647 HDD problem
on restart enter setup or bios and set to default settings
then restart and press f7 choose option to boot from cd
then press enter should boot.
if not then this is the site i use for bios updates www.wimsbios.com
don't forget to rate me
thanx
Feb 02, 2009 | IBM ThinkPad T20 2647 Notebook
I have a western digital (WD1600BB) harddrive that i want to install into my pc so it replaces my 17.2gb one that i have at the moment. I have a windows XP disc, but everytime i hook it up to my computer...
OK... Either your PC uses CS (Cable Select) or MS (Master/Slave) designation to ID drives found on the internal cablesets. Find yours for the 160gb here: http://www.wdc.com/en/images/products/drives/10_pin_jumper.gif
OK, you can't mix types, and you cant put 2 Masters or 2 Slaves on the same cable. Soooooooo
You need to find out what the current HDD uses... so pull the current HDD out, turn it so that you are looking at the backside (where the cable and power plugs in) and look for a group of 6, 8 or 10 tiny pins in a row ( Jumpers)
moz-screenshot.jpgLook where the Plastic pin(s) are if any and then look on the BACK, Top, PCB and Rear cover for the diagram that explains the position of each.
If your current Drive is CS, then just set your new drive to CS and plug it in (on the same cable)
If your current drive is all alone on the cable and there is a free connector hanging loose, it is most likely set to SINGLE MASTER, and will have to be changed to DUAL MASTER... then set your new drive on DUAL SLAVE and plug it in (on the same cable)
If your current drive is NOT all alone on the cable and there is CDROM attached to it too, it is most likely set to SINGLE MASTER, andyou will leave it alone and you will set your new HDD to SINGLE MASTER as well, and put it on the OTHER cable.
You may have to alter your BIOS settings to see the new 160Gb HDD IF your motherboard is capable of handling that size. Press F2 or DEL or Cntl-S or F12 during boot to get there, then make your changes, save and get out
Once you can SEE both HDD in your system, then you either use a program like GHOST and do a bit-by-bit copy of the old HDD to the NEW, and then make IT MASTER and the OLD one SLAVE (and reset BIOS settings to reflect this) or just leave it in there as 2nd BIG HDD with lots of space.
Good luck
Jan 16, 2009 | Western Digital Caviar WD1600BB 160 GB...
New hard drive
you got a problem there.
may be you can return it and get a 80GB harddrive. e-mail me fo rinstruction how to install update BIOS.
Sep 30, 2008 | Fujitsu LifeBook B2131 Notebook
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Samsung SpinPoint P80 SP1604N 160 GB Hard Drive Logo
507 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
